Question about number operator and density operator
In summary, the average value of a dynamic variable, \omega, is given by: \langle k| \hat{\Omega}|k\rangle=\bar{\omega}
KFC
488
In quantum harmonic oscillator, we define the so called number operator as
[tex]\hat{N} = \hat{a}^\dagger\hat{a}[/tex]
Apply [tex]\hat{N}[/tex] to the state with n number of particles, it gives
[tex]\hat{N}|n\rangle = n |n\rangle[/tex]
so
[tex]\langle n| \hat{N}|n\rangle = \langle n| n |n\rangle = n[/tex]
But in other textbook about statistical mechanics, it gives
[tex]\langle n |\hat{N}|n\rangle = \bar{n}[/tex]
Why these two results are not the same? For later one, it seems to consider something related to the statistics, but how?
I still have another question by the trace, in harmonic oscillator, the density operator is given by
[tex]
\hat{\rho} = \sum_n |n\rangle\langle n|
[/tex]
But sometimes, for a specific state, says [tex]|\varphi\rangle[/tex], the density operator just
[tex]
\hat{\rho} = |\varphi\rangle\langle \varphi|
[/tex]
why there is no summation? When do we need to consider the summation?
Did you type this first one in correctly? This doesn't look right.
[tex]\langle \hat{N}|n\rangle = \langle n |n\rangle = n[/tex]
The [tex]\hat{N}[/tex] is an operator, not a vector. So it shouldn't be in a bra. Also [tex] \langle n |n\rangle[/tex] is equal to 1, not n.
What I think it should say is either
[tex] \hat{N}|n\rangle =n |n\rangle[/tex]
or
[tex]\langle n |\hat{N}|n\rangle =\langle n |n|n\rangle= n\langle n |n\rangle =n[/tex]
The second result being exactly consistent with what the statistical mechanics book says (except for the bar over the n).
or
The second result being exactly what the statistical mechanics book says (except for the bar over the n).
Yes. I just correct that.
But in [tex]|n\rangle[/tex], how come will it be average?
A density operator
[tex]\sum_i w_i|\alpha_i\rangle\langle\alpha_i|[/tex]
can be interpreted in two different ways:
1. It represents an ensemble of identical physical systems, prepared so that a fraction wi of the systems are in state [itex]|\alpha_i\rangle[/itex].
2. It represents one physical system that is known to be in one of the [itex]|\alpha_i\rangle[/itex] states, but it's unknown which one. (Note that this means that it's not in a superposition of two or more of them). wi is the probability that it's in state [itex]|\alpha_i\rangle[/itex].
The first of your "density operators" is just the identity operator.
This should probably be
[tex]\langle \psi |\hat{N}|\psi\rangle = \bar{n}_\psi[/tex]
When [tex]|\psi\rangle=|n\rangle[/tex], the right-hand side is just n.
Note that
[tex]\langle \psi |\hat{N}|\psi\rangle = \sum_n\langle \psi |\hat{N}|n\rangle\langle n|\psi\rangle= \sum_n n\langle \psi|n\rangle\langle n|\psi\rangle= \sum_n n|\langle n|\psi\rangle|^2 [/tex]
and that [itex]|\langle n|\psi\rangle|^2[/itex] is the probability that a measurement will yield result n. So the expression above represents the average value of a large number of measurements on identical systems that are all prepared in state [itex]|\psi\rangle[/itex].
Thanks Fredrik, it helps.
Let's say we want to find the average value of any dynamic variable, which we'll call [tex]\omega[/tex]. Let's suppose we're working in some basis, which we'll call k. Then a general formula for the expectation value (average) is:
[tex]\langle k| \hat{\Omega}|k\rangle=\bar{\omega}[/tex]
So with your formula
This is the same formula I quoted above, but for the operator [tex]\hat{N}[/tex] in the n basis. Since it's the same formula, it gives the average, [tex]\bar{n}[/tex]
Now, in this particular case, the basis vectors happen to be eigenvectors of the operator. As a result, the eigenvalue, n, happens to be equal to the expectation value, [tex]\bar{n}[/tex]
In this derivation:
note the importance of this particular step:
[tex]\langle n |\hat{N}|n\rangle =\langle n |n|n\rangle[/tex]
The reason we can take this step is because of the fact that:
or in other words, we can take this step because the vector happens to be an eigenvector of the operator. Because of this, the same formula that gives the average value also gives the eigenvalue. In the general case I noted above:
I would not be able to take that same step. So in this case, [tex]\omega[/tex] and [tex]\bar{\omega}[/tex] wouldn't follow from the same formula, so I wouldn't necessarily get [tex]\omega=\bar{\omega}[/tex]
In quantum stat. mech. the average of any quantity is defined as [tex]\overline{A} = Tr(\rhoA)[/tex] Where "rho" is the density operator.
1. What is a number operator?
A number operator is a mathematical operator used in quantum mechanics to describe the number of particles in a particular state. It is represented by the symbol "N" and its eigenvalues represent the possible number of particles in a given state.
2. How is the number operator related to the density operator?
The number operator is related to the density operator through the spectral decomposition of the density operator. The eigenvalues of the density operator correspond to the probabilities of finding a certain number of particles in a given state, which can be obtained using the number operator.
3. What is the significance of the density operator in quantum mechanics?
The density operator is a fundamental tool in quantum mechanics used to describe the state of a quantum system. It allows us to calculate the probabilities of obtaining a certain measurement result and to analyze the dynamics of the system over time.
4. How is the density operator used to calculate expectation values?
The density operator is used to calculate expectation values of observables in quantum mechanics. The expectation value of an observable A is given by the trace of the product of the density operator and the operator A. This provides the average value of the observable in a particular quantum state.
5. Can the density operator be used for both pure and mixed states?
Yes, the density operator can be used for both pure and mixed states. For pure states, the density operator is a projection operator onto the state vector. For mixed states, the density operator is a statistical mixture of projection operators onto the various pure states that make up the mixed state.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
