Is there something strange with the gravity during total solar eclipses?
In summary, the strange effects on gravity during a total solar eclipse are caused by the alignment of the sun, moon, and Earth. This change in gravity is very small and only occurs in the path of totality, where the moon completely blocks out the sun's gravitational pull. Other factors, such as the position of other planets and objects in the solar system, may also play a role but their impact is minimal. To study these effects, scientists use specialized instruments and analyze data from satellites and other sources.
Tilemachos
I have found some papers about strange observations in the Earth gravity during total solar eclipses. There is a very small difference (~10^-9) but there is a differnce (see the attachment).
Is there the possibility to be a new gravity phenomenon?
I think that it can be an atmospheric phenomenon, there are a lot of air turbulence during eclipses which maybe can cause these differences...
Your opinions please.
  • gravity_paper.pdf
Astronomy news on Phys.org
1. What causes the strange effects on gravity during a total solar eclipse?
The strange effects on gravity during a total solar eclipse are caused by the alignment of the sun, moon, and Earth. When the moon passes between the sun and the Earth, it blocks out the sun's gravitational pull, causing a temporary decrease in gravity on Earth.
2. Is the change in gravity during a total solar eclipse noticeable?
The change in gravity during a total solar eclipse is very small and not noticeable to most people. It has been measured to be about 0.00005% less than the normal gravitational pull on Earth.
3. Does the strange gravity only occur in the path of totality during a solar eclipse?
Yes, the strange gravity effects only occur in the path of totality during a solar eclipse. This is because the moon completely blocks out the sun's gravitational pull in this area, causing the most significant changes in gravity.
4. Are there any other factors that could affect gravity during a solar eclipse?
There are other factors that could potentially affect the gravity during a solar eclipse, such as the position of other planets and objects in the solar system. However, their impact on gravity during a total solar eclipse is very small and not significant.
5. How do scientists study the effects of gravity during a total solar eclipse?
Scientists use special instruments, such as gravimeters, to measure the changes in gravity during a total solar eclipse. They also analyze data from satellites and other sources to better understand the effects of the eclipse on gravity.
  • Astronomy and Astrophysics
13K
11K
