Bell's theorem proof. Does it really proofs anything?
In summary, Bell's theory states that the measurement of spin of one twin-light photon affects the spin of the other, which is supported by experiments with the SPOT detector. However, this does not rule out the possibility of a hidden variable theory. The results of the experiment can be explained by assuming that both twin-photons have defined spin from the beginning. However, this does not prove that the measurement of spin impacts the spin of the other photon. Additionally, there is no data set that can match the experimental results and any rule set provided will not match the predictions of Quantum Mechanics. Therefore, it is important to learn about Bell's theorem from a credible source before discussing it further.
  • #36
0xDEAD BEEF said:
Not exactly - there is no polarization filters between them and crystals! ;)
Beef
P.S. i still totaly disagree and do not accept this idea, but i guess that is because of my incomplete knowledge!
Well... some things you say... do make sense… (sorry bad joke :biggrin:)
0xDEAD BEEF said:
BTW - so say i do conduct this experiment using normal light polarized using polarization fitlers (two polarizations filters polarizing light) - what results would i get?
Not that great I would say. Let’s assume we have the Source (S), Polarizer1 (P1), Polarizer2 (P2), and the Measuring apparatus (M), setup like this:
S----->-----P1----->-----P2----->-----M
Unpolarized normal light will go thru P1. Independent of the angle of P1, 50% of the light will pass thru. Let’s say we set P1 to 90º. Now P2 will have to 'relate' to the angle of P1. If P2 is set to 0º, no light will pass. If P2 is set to 45º, 25% of the (original) light will pass. If P2 is set to 90º, 50 % of the (original) light will pass.
You can play with different settings in this http://www.lon-capa.org/~mmp/kap24/polarizers/Polarizer.htm" , but I don’t think it will help you design a LHVT.
  • #37
DevilsAvocado said:
You should know that spontaneous parametric down-conversion in BBO crystals is not a very effective process. Only one out of 10^6 photons converts into two entangled photons, one in a million.
This means that most photons that hit the detectors are "dummies". They don’t show any sign of QM correlations. I guess that this is a parallel to your "laser experiment"... :rolleyes:
There are not so much dummies. Pump photons are separated from downconverted photons (they usually have slightly different direction) and they do not arrive at detectors.
But if pump photon is downconverted there are always two downconverted photons leaving the source. Of course you can loose some along the way.
Anyways it's possible to make setup where more than 50% of detections at one detector are paired with detections at other detector (but not vice versa). Actually for me it's clearest demonstration that photons are particles (at macro scale).
  • #38
So I think is start to see the problem here!
All this proof is based on this formula output
N(+30°, -30°) ≤ N(+30°, 0°) + N(0°, -30°)
not matching measurements, right?
And this N function is function, which describes error (mismatch?). Right?
So - can i remove "two parameters" from this function and convert to one, since "error" is always calculated comparing output at Alise's detector to output at Bob's detector and absolute angle does not play role here, since polarization of photons is not known from very beginning?
So, should this also be true?
N(60°) ≤ N(30°) + N(30°)
Beef
EDIT: BTW - what is "two-channel polariser" and where do i get one! :)
EDIT2: two-channel polariser is same thing as "Wollaston prism" ?
  • #39
YES!
Not only measurements, it does not match the theoretical predictions of Quantum Mechanics (which is the most precise theory we have).
YES!
YES!
We could 'simplify' this even more and say:
50% = 25% + 25%
And more, by dividing by 25:
2 = 1 + 1
Or reversed, that works even for kids! :smile:
1 + 1 = 2
This is what we expect. This is the how "the normal world" should work. But, then comes the 'weird' QM-world and tell us that – This is how it works!
1 + 1 = 3
This video explains the basics in EPR-Bell experiments:
https://www.youtube.com/watch?v=<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/c8J0SNAOXBg&hl=en_US&fs=1&rel=0&color1=0x006699&color2=0x54abd6"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/c8J0SNAOXBg&hl=en_US&fs=1&rel=0&color1=0x006699&color2=0x54abd6" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
And here you find more info on the equipment: http://www.didaktik.physik.uni-erlangen.de/quantumlab/english/"
And if you really going to have a experimental shot at this, you should read this:
http://arxiv.org/abs/quant-ph/0205171"
  • #40
Hey DrC! Nice pink! (me want! :cry:)
  • #41
Thanks for clarifying.
Well, some say it’s particles, and some say wave/particles, and some only wave + a "click".
I have absolutely no idea what’s really true... (and I guess I’m not alone :smile:)
  • #42
So i wrote program which generates photons with random orientation and throws them at detectors. Now i got linear output comparing detectorA to detectorB. I wrote my detectors so, that they fire, if photon angle +- 45 degrees matches with detector angle. Is this correct detector setting?
So - if we assume, that measurement of one photon changes orientation of other... Why do we get random data output at Alisa's or Bob's detector? Why is not it so, that one detector returns more + than - or vice versa (thus - if detector has affected orientation of photon should not this detector fire more often, since photon's direction is changed to "suite" that(first) detector) ?
Beef
  • #43
Beef
First, 45 degree angles usually won't show much relative to Bell's Theorem. Second, it is very difficult to follow some of your questions - so I will try as best I can.
The general rule for a polarization entangled photon pair is that a measurement on Alice acts "AS IF" it causes a matching change to Bob. (Note the AS IF because no one is actually saying that can be proven. It is one of several possibilities. However it is useful for the rule, which is correct.) So if you measure Alice at 45 degrees, Bob will act as if he is likewise polarized at 45 degrees. Stats can then be calculated for any subsequent measurement on Bob (or Alice for that matter).
An important note because I think this can be confusing if it is not explicitly pointed out: Entangled photon pairs can be created either I) so Alice and Bob have the same polarization; or II) Alice and Bob have orientations 90 degrees apart. This is controlled by the choice of PDC crystals (called Type I or Type II).
Finally, any sequence of Alice will be random + and -, more or less equal, and Bob will be random too. Depending on the relative angle theta between then, their matches will show a pattern or not. Cos^2(theta) is the rule for Type I, Sin^2(theta) is for Type II. I always provide examples as Type I because it is easier to discuss.
  • #44
So how i now see this is that if instead of twin photons i would use simple photons with same polarization, then this same experiment would produce linear graph, not cos. Right?
So this would mean, that measurement on Alisa's photon has affected Bob's photon to be the same, BUT Alisa's photon somehow matches betters Alisa's detector? So we should see more + photons than - (or vice versa) photons at Alisa's detector?
Edit: or does this measurement says, that now that photons (both) know their polarization for Alisa's detector, they will respond with same value, but since they don't know polarization value for Bob's settings, they have not made that up yet so when Bob measures his photon, his photon wonders what value should it return to Bob, since Alisa did not measure exactly same "setting" so Bob's photon comes up with some new random value? :)
Edit2: And if so, should not those two photons have decided their polarization values earlier already (traveling through space and hitting various magnetic/electric fields or dust) ?
Beef
  • #45
I’m not sure what you’re aiming at... do you mean the polarizing beam splitter?
This is 'just' to be able to measure all arriving photons (both Up/Down, +/-, 1/0, Yes/No), to get better 'precision'...
Try to think of it like this: Basically at each end Alice & Bob receive unpolarized light that they run thru a polarizer. As you can test by yourself in the http://www.lon-capa.org/~mmp/kap24/polarizers/Polarizer.htm" , no matter what angle you set there will always be a 50% chance for the light (photon) to go thru, when the light is unpolarized.
To make more precise measurements, we take care of both "thru" & "stopped" by a polarizing beam splitter. This means there is always 50/50 chance for the photon to be detected at each detector after the beam splitter.
The EPRB 'mystery' lays in the correlations in the sequence of photons between Alice & Bob.
For example, let’s say we have a relative angle of 60º between Alice & Bob, meaning there’s a 75% mismatch. When counting 8 photon pairs, we could get this:
Alice: 0000 0000
Bob..: 1111 1100
But, more probably we will see something like this:
Alice: 0101 0101
Bob..: 1010 0011
Get it?
  • #46
0xDEAD BEEF said:
1. So how i now see this is that if instead of twin photons i would use simple photons with same polarization, then this same experiment would produce linear graph, not cos. Right?
2. So this would mean, that measurement on Alisa's photon has affected Bob's photon to be the same, BUT Alisa's photon somehow matches betters Alisa's detector? So we should see more + photons than - (or vice versa) photons at Alisa's detector?
3. Edit2: And if so, should not those two photons have decided their polarization values earlier already (traveling through space and hitting various magnetic/electric fields or dust) ?
Beef
1. No, it is a completely different formula that involves 3 variables but follows classical rules (Malus).
2. I cannot follow your question. I assume English is not your native language so if you could rephrase that would be helpful. There is no reason you would see more + than - anywhere, not sure what your thinking is on that but it is not correct.
3. Free space fields generally will not affect photon polarization in any way. Many times the effects cancel out. Now, if you go through an optical device such as a polarizing beam splitter or a wave plate you can see effects.
  • #47
Sorry! I don't get it! :)
I would really apreciate, if you could answer this question-
What i mean is - where does it start to make difference between twin-photons and photons with same polarization. How would this change results of experiment. Let's say - i have black-box device which creates "twin-photons", which actualy are not twin photons, but simply photons with same polarization. Where would this change output of these measurements.
The big idea behind this theory/experiment is, that polarization of these photons becomes "known" only as they get measured (pass thru polarization filter (Wollaston prism?)).
Am i right?
Beef
P.S. english is not my native language, sorry.
  • #48
No, it would produce cos^2(a)*cos^2(b) where a and b are angle between polarization axis of photons and polarization axis of respective polarizer.
In case of entanglement you get something like:
cos^2(a)*cos^2(b)+sin^2(a)*sin^2(b)+1/2*sin2a*sin2b=cos^2(a-b)
this third term (1/2*sin2a*sin2b) is called interference term and it's the one that complicates things.
  • #49
zonde! regarding
as i said, i would use black-box, so, whatever "polarization axis of respective polarizer" is, i can no know that! So - what output would i get?
Beef
  • #50
Am i right?
Well, now we are talking! :smile:
First, two photons with the same "pre-polarization" will not do any good in EPRB = dead end. Just check the math.
The second part is touching the real juicy stuff in EPRB! This almost makes me throw up! :yuck: And I know that it 'troubled' John Bell as well...
Who decide, Alice or Bob??
According to Einstein’s Special Relativity, BOTH DECIDE! In different frame of reference!
It doesn’t make sense, right? Only one can decide, anything else is just pure stupidity, right? :grumpy:
But this is the way it is, in current science, and to me this is more shocking than any locality or reality... the future is probably going to show us some real interesting "features" of nature... :rolleyes:
  • #51
DevilsAvocado: "Bubuubibeebuu. Bububeee! Babubabubee?"
0xDEAD BEEF: "Eat this porridge son, it is good for your teeth!"
OK - that was just a joke!
I just really did not get your idea here..
EDIT: we allways have one, who decided first, don't we? But if this decison affected results of other - should not it affect the results of first one as well?
  • #52
Part one or two?
  • #53
Nope!
The problem here is that from the perspective of observer Chris, Alice will always measure her photons first, thus Alice is not forced by any rules of EPRB to make correlations with Bob. Alice should always have random 50/50 evenly spread out.
From the perspective of observer Dave, Bob will always measure his photons first, thus Bob is not forced by any rules of EPRB to make correlations with Alice. Bob should always have random 50/50 evenly spread out.
This is pure madness!
Get it??
  • #54
Ok ok!
0xDEAD BEEF: "Bubuubibeebuu. Bububeee! Babubabubee?"
DevilsAvocado: "Eat this porridge son, it is good for your teeth!"
I really would like to understand this case, because - i have come up with one cool experiment. And i, of courese, will share it with you (but only, if it makes sense)!
So - my question still remains - where is the catch! What is the difference between simple photons having same polarization, but not linked together and twin photons?
In fact - here is my idea:
--- simple case ---
Polairty of two photons is same before they enter Anna's and Bob's polarity detectors. Those photons were generated by our black-box, which generates 2 photons having same polarization, BUT, to match experiment with twin-photons, we have placed our apparatus in black box, so no one can actually see, what is that polarization of those photons.
--- wtf is going on case ---
twin-photons, same polarization (maybe) hitting Anna's and Bob's detectors.
As I understand - it does not matter, what was polarization of those two photons (but it was same), BUT after Annas detector photon has changed. But - it is still not determined, because, if it would be, then this case would be same as "simple case".
Now - the funky experiment which allows data to be exchanged faster than light. (Of course not!, but just idea).
So - let's have this configuration -
Bob has same detector as allways and he is measuring photon orientation at 45 degrees.
Anna has boosted her detector! Instead of one detector, she has 3 detectors(not 3 detectors but 4! she has 3 polarization crustals) with same angle now.
So -
first photon hits Anna's A detector (set at angle 0), next it hits Bob's detector (45). Now - here the tricky part - Anna has 2 more detectors after detector A. She has detector A1 and A2. These detectors are exactly same as detector A, but they are located so in time, that photon first hits A, then B, then A1/A2.
Anna's detector setup would look like this
A1+
A1-
...A
A2+
A2-
So - what we would expect is, that Anna almost allways gets either A1+ or A2-. How ever - if this all strange quantum stuff is reall, then as soon as Bob turns his detector away from 0 (same as Anna), Anna should start receiving also (more than before) A1- and/or A2+.
This would be totaly cool. I agree! Faster than light communication!
However - would that happen? If no. What is the difference betwen twin-photons and simple photons with same polarization?
Beefs
  • #55
here picture.
- goes down,
+ goes up
So - does this theory says, that after Bobs measurement (taking place in time between A and A1/A2) we could get A1- or A2+ or we allways will see A1+ or A2-
EDIT: it would make more sense to call A1 A+ and A2 A- :)
  • #56
DevilsAvocado: "Eat this dead beef son, it is good for your teeth!"
:rofl:
With two photons that have a fixed polarization from start, this will happen (at best! :wink:):
Alice polarized 0º
Bob polarized 0º
Alice hit the detector at 0º, and she passes thru 100% of the time.
Bob hit the detector at 30º, and he passes thru 75% of the time.
The relative angle between Alice & Bob is 30º and the mismatch is 25% which seems OK, right?
Next test:
Alice hit the detector at 30º, and she passes thru 75% of the time.
Bob hit the detector at 60º, and he passes thru 25% of the time.
The relative angle between Alice & Bob is now also 30º... but the mismatch is now 50%!? This is not OK!
Babubabubee? Get it? :biggrin:
  • #57
Thats because you were firing photons at angle about 0.
To be honest - i don't get it. If i would - would i start this weird (nonsense) topic from very begining? By the way - what do you think of my experiment setup with 3 polarizers and 4 detectors at Anna's place?
Beef
Edit: Nope - i got your experiment! That was exactly what my program outputed. Only - i tried out all different options of photon polarization. Now the question is - where is the catch!
  • #58
What is it?? Julian Assange’s contact network!:eek:?
(terribly sorry, extremely bad joke! :biggrin:)
  • #59
The catch (that I have tried to inform you for TWO WHOLE DAYS) is – QM does not behave in the expected classical way, it’s weird; 1 + 1 = 3! :grumpy: (:rofl:)
Seriously, I have to leave now. You've got some reading to do. I’m sure it will come to you.
Good luck and Cheers!
  • #60
Ha ha! (irony, but maybe not).
So, how i see this-
Anna got polarization filter and Bob has. Standart setup.
What if we further extend this setup, so that Anna has 3 polarization filters all set at same angle.
So, Anna would have 4 detectors. 2 for each "second" filter like this -
dA++
... pA+
dA+-
...... pA
dA-+
... pA-
dA--
So pA (first polarization filter) decides polarization and redirects photon to either pA+ or pA- polarization filters. In the mean time twin-photon hits Bob's polarizer, which is set at 45 degree angle.
If we forget about this QM weird stuf, no mater what/when/ever second twin-photon hit Bob's polarization filter, Anna should always get either dA-- or dA++, because, if photon once choose to go through Anna's 0 polarizer in + direction (up), why shoul it choose differnetly, when facing second one pA+ (or vice versa - facing pA-).
In this case standart physics predict, that Anna should only get dA-- or dA++ output! How ever - if this QM stuff is real and Bob's detector has given new properties to photon, while it was traveling through Bob's polarizer set at very different angle than Anna's was - we should see Anna's dA-+ and dA+- detectors fire as well!
This really would prove everything! Scienitifcal brekathrough - i would say. Otherwise... sorry guys, but we are just creating our own virtual reality to play with (wich ain't that bad, since we can learn new thing from it as well).
Beef
  • #61
@0xDEAD BEEF
Maybe unfair to leave in an "outburst" like that... :blushing: you did ask me a specific question...
The "catch" (that your predefined photon polarization will never ever work), is because the relative angle between Alice & Bob can be anything between 0-360, but "your" photons doesn’t care one bit about this relative angle. The only thing that they will "respond" to is their own polarization and the setting of their own polarizer.
I.e. there is no "communication" or "link" between Alice & Bob in your "design", and this is crucial.
Don’t ask what this "communication" or "link" really is and how this works – no one knows.
There are two main "explanations" for this paradox. One is the so called non-locality, meaning some sort of "communication" between Alice & Bob is present (that we don’t know what it is). The other is non-separability, which means that the physical reality is not what we think; one object can be at two places at once, or something like that (I think it involves holism as well).
This is why I won’t get into details in your program; I know it will never work they way you hope. Yes, it’s "cocky and rough", but it’s the truth. You will win some substantial time if you first study the problem in detail, to learn everything, and then try to build something on your own. Just by guessing, you will not get anywhere.
Good luck & Take care!
  • #62
So, how i see this-
What if we further extend this setup, so that Anna has 3 polarization filters all set at same angle...
If they are all set the same way, you can pretty well predict the results. Same all around, as any polarized photon can be sent through a series of similarly oriented splitters and nothing changes.
It would be helpful if you would ask a specific question. You are wandering all over the place and it seems as you ignore the rules I keep trying to explain. There is difference between entangled photons (emerging from a PDC crystal) and a pair of photons of known and identical polarization, such as emerge directly from a laser beam. You should learn this difference first, and understand their statistics.
  • #63
I suppose that you mean you don't know polarization axis of photons (and they have different polarizations) not polarizers i.e. black-box is source not measurement equipment.
If that is so then you will have classical output like that:
N(a,b)=1/4+1/2*cos^2(a-b)
If we want to look at real life example we can take PDC source without walkoff compensators.
In that case we have only H and V polarized non-entangled photons. And result is like this:
N(a,b)=1/2*cos^2(a)*cos^2(b)+1/2*sin^2(a)*sin^2(b)
  • #64
What is PDC source with with walkoff compensators?
Yes - my black box device would be photon source which would output two photons to Anna and Bob. These two photons would have same polarization (photon a polarization == photon b polarization), but those polarizations would change on random (photon a == photon b == random value).
Beef
  • #65
So QM states, that particle can have only one "property" at time?
For example - i send p (particle) through 0 angle polarizer. It goes either up or down and now it has its 0 angle property set to up or down. Then (p) travels through another polarizer, this time set at 90 angle, so particle now forgets? its 0 angle and decides either to go up or down at 90 angle. And now if i send this particle through 0 angle polarizer again, then it could choose different direction to go this time, because previously it was measured against 90 angle detector?
Example:p --> (0) -- up/down --> (90) -- up/down --> (0) -- same as first time or different? --> (detector).
EDIT:
What i am aiming at is:
a) photons have some invisible quantum bound between them.
In such case (time line):
Alisa measures photon polarization at angle 0
Bob measures twin-photon polarization at angle 90
Alisa again measures photon polarization at angle 0, but gets different result, since Bob's measurement on his photon has made Alisa's photon to "forget" it's 0 angle polarization value.
Result - faster than light information exchange.
Setup (Alisa) -
Code:
BOB0  \
        p(0) \
BOB90 /
                p(0) <----- photon
BOB90 \
        p(0) /
BOB0  /
where BOB90 has 50% chance of firing, if Bob's polarizer is set at 90 degrees and 0% percent chance, when Bob's polarizer is at 0 degrees.
b) we are just measuring different properties of photon.
Bob measures photon polarization at angle 90
Alisa measures photon polarization at angle 90
Bob measures photon polarization at angle 0
-- Bob's and Alisa's all 4 measurements match, so there is actually no reason to have Bob at all and Alisa could have measured photon both on 0 and 90 angle bu her self.
Setup would be -
Code:
D0+90+ \
        p(90) \
D0+90- /
                p(0) <----- photon
D0-90+ \
        p(90) /
D0-90- /
So - if Alisa's D0+90- fires, that means, that photon had 0+ polarization and 90-.
If we have Bob in this scenario, then D0+90- or D0-90- should fire, when Bobs (90 angle) - fires and vice versa.
EDIT2:
I guess, there is also c) option.
c) Alisa can measure photon's polarization at one angle (and that is it), and Bob can also do so, so they both can measure different polarization values of "same" photon, which is cool, since we get more information about that photon, but that is it .
EDIT3:
There might also be option d).
Alisa measures her photon at 0 angle, so Bob's photon now can not be longer measured against 90 angle and vice versa.
Twin-photon hits Bob's polarizer always first.
In this case Alisa could have multiple detector chain
Code:
BOB0  \
        p(0) \
BOB1 /
                p(0) <----- photon   ------> p(0/90)
BOB1 \
        p(0) /
BOB0  /
so - if Bob DOES NOT measure his twin-photon polarization angle at 90, then Alisa always gets BOB0. If, however, Bob does measure his twin-photon's polarization before Alisa's photon enters Alisa's first polarizer p(0), then Alisa's photon starts giving random data when measured against p(0), so it should start hitting BOB1 detectors. In this case we would again clearly see at Alisa's end, that Bob has measured his photon (at 90) or has not, thus, we could make conclusion about Bob's setup -> faster than light information exchange.
So is it a), b), c) or d) ?Beef
  • #66
It is usual source of polarization entangle photons.
Then I understood you correctly and my answers hold.
  • #67
Example:
Different
Only if you talk about photons and polarizers then it's 0° and 45° not 0° and 90°. Photons that pass 0° polarizer are completely blocked by 90° polarizer.
No
No, because after first measurement photons are not entangled any more.
0xDEAD BEEF said:
c) Alisa can measure photon's polarization at one angle (and that is it), and Bob can also do so, so they both can measure different polarization values of "same" photon, which is cool, since we get more information about that photon, but that is it.
I would rather say no. It's not photon that behaves the same way. It's the wavefunction that behaves the same way. So you don't get more information about the "same" photon.
And you always get BOB0 irrespective of Bob's measurement.
  • #68
So you are saying, that after first measurement photons are not entangled any more. If so - does it matter at all that they were entangled from very beginning.
Or maybe i am just getting this wrong, but - does entanglement gives any other extra properties to photons than just that they have all same properties?
In this experiment they use that crystal to create entangled photons with same polarization and send them to Alisa and Bob. Why would it make any difference if i replace "twin-photon crystal" with "black box", which also outputs same photons, only with difference, that they are "manually created" (two "light bulbs" and bunch of polarization filters) .
  • #69
Apparently it matters. After first measurement they are not entangled but they are correlated nevertheless i.e. if you detect them results are correlated.
Well maybe it's better to take it as speculation but anyways I would say that entanglement is specific correlation of photon phase not only for paired photons but for whole ensemble.
In your "black box" setup you can't control phase of created photons.
  • #70
Well, this is not an ensemble of personal speculations; it’s the current professional mainstream scientific view.
Trust me, or http://www.phy.mtu.edu/faculty/Nemiroff.html" :
<object width="640" height="505">
<param name="movie" value="http://www.youtube.com/v/KJhSP2zAfiI&fs=1&amp;hl=en_US&amp;rel=0&amp;color1=0x402061&amp;color2=0x9461ca"></param>
<embed src="http://www.youtube.com/v/KJhSP2zAfiI&fs=1&amp;hl=en_US&amp;rel=0&amp;color1=0x402061&amp;color2=0x9461ca" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed>
</object>
<param name="movie" value="http://www.youtube.com/v/tAwnR89rp3I&fs=1&amp;hl=en_US&amp;rel=0&amp;color1=0x402061&amp;color2=0x9461ca"></param>
<embed src="http://www.youtube.com/v/tAwnR89rp3I&fs=1&amp;hl=en_US&amp;rel=0&amp;color1=0x402061&amp;color2=0x9461ca" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed>
</object>
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
