Statistics: Null hypothesis/chi-squared question.
  • Thread starter geoffreythelm
  • Tags
    Statistics
In summary, the student is seeking clarification on the wording of parts i and iii of the Chi-squared test for independence and has been advised to search for more information using Google.
geoffreythelm
http://img687.imageshack.us/img687/7963/screenshot20120102at185.png
I understand how to compute a Chi-squared test, but I'm a bit confused about the wording of parts a) and c). Could someone possibly simplify it for me?
Thanks a lot.
Thanks a lot.
Google is your friend; search "chi squared test for independence".
RGV
Thanks a lot.
There are no parts a and c. Did you mean i and iii?
1. What is a null hypothesis in statistics?
A null hypothesis is a statement that assumes there is no significant relationship between two variables or that there is no difference between two groups. It is typically denoted as H0 and is used as a starting point for statistical tests.
2. What is the purpose of a null hypothesis?
The purpose of a null hypothesis is to serve as a baseline or default assumption. It allows researchers to test whether there is enough evidence to reject the null hypothesis and accept an alternative hypothesis. This helps to determine whether the observed data is due to chance or if there is a significant relationship between variables.
3. How is a chi-squared test used to test the null hypothesis?
A chi-squared test is a statistical test that compares the observed data to the expected data under the null hypothesis. It calculates the difference between the observed and expected values and determines whether this difference is significant. If the difference is significant, the null hypothesis is rejected in favor of an alternative hypothesis.
4. What are the assumptions of a chi-squared test?
The assumptions of a chi-squared test include:
- The data must be in the form of frequencies or counts.
- The sample must be representative of the population.
- The expected frequency for each category must be at least 5.
- The observations must be independent.
- The variables being tested must be categorical or discrete.
If these assumptions are not met, the results of the chi-squared test may be unreliable.
5. How do you interpret the results of a chi-squared test?
The results of a chi-squared test are typically presented as a p-value. This p-value represents the probability of obtaining the observed data if the null hypothesis is true. If the p-value is less than the predetermined significance level (usually 0.05), the null hypothesis is rejected and the results are considered statistically significant. If the p-value is greater than the significance level, the null hypothesis cannot be rejected and the results are not considered statistically significant.
