Are polaritons simply photons propagating in medium?
In summary, in a vacuum, a photon has a 4-momentum (E, p) with E^2 - p^2 = 0, making it massless. However, when entering a medium with refractive index n, the photon retains its energy but its momentum is reduced by a factor n, leading to a 4-momentum of (E, p/n). This implies that the photon gains mass in a medium. The term "polariton" is not clearly defined and its usage differs in different fields, but it can generally be used to describe a quasiparticle that represents a photon in an optical medium with refractive index n. However, a polariton is not exactly the same as a photon and
Heirot
151
In vacuum, the photon has a 4-momentum (E, p) with E^2 - p^2 = 0, i.e. it's massless. However, upon entering a medium of refractive index n, we expect that the photon retains its energy, while reducing its momentum by a factor n (due to increased wavelength). We then have for the 4-momentum of a photon in the medium (E, p/n) with E^2 - p^2 / n^2 != 0 which implies that the photon gains mass in a medium. Would it be correct to identify this particle not as a "photon in a medium" but as a polariton?
PS I'm a particle physicist, so take it easy on me :)
Thanks!
As long as n is constant, the photon (or polariton) will still be massless. However n will vary with frequency and wavevector, so that the polariton can gain an effective mass as m_eff=d^2E/dp^2.
OK, so the question is, can I identify a polariton with a particle of energy E and momentum p/n?
Heirot said:
IWould it be correct to identify this particle not as a "photon in a medium" but as a polariton?
That question is a bit difficult to answer as the usage of the word "polariton" differs in different fields. Some fields, especially some subfields in semiconductor physics reserve the term polariton for strongly coupled systems. That means that you have strong light-matter interaction and avoided crossings when plotting the dispersions. It also means that a perturbative treatment of the light-matter interaction fails. In these fields, the term "photon" is also used in the regime of weak light-matter interaction.
However, strictly speaking a bare photon only describes the electromagnetic field in vacuum. The changes introduced by the medium can also always be described in terms of polaritons. Some fields use that stricter definition of what a polariton is.
For my purposes, I need a word for a quasiparticle that represents a photon in an optical medium of refractive index n. That is, a particle that travels at the speed of c/n, carries energy E and momentum p/n, where E and p are energy and momentum of a photon with the same frequency propagating through vacuum. I am not particulary interested in the microscopic describtion of a medium or the strength of the coupling. All that matters it that light couples to matter and the information about the coupling is contained in one number: n. Would a "polariton" be a suitable word?
I assume that you are thinking about the polaritons created by the coupling of the optical phonon field to the electromagnetic wave field. Then, I would use the word "photon-like polariton" to describe the excitation corresponding to a mass less particle. There are "phonon-like" polaritons that correspond more closely to the optical phonons. The optical phonon has a "non-zero rest mass."
"Polaritons" have a dispersion curve consisting of two branches that are split by the coupling interactions. There is a forbidden gap in wavevector between the two branches. The boundaries of the gap are the frequencies of the transverse optical and longitudinal optical phonons.
The dispersion curves of the polariton are very important in understanding the jargon. I am currently looking at Figure 11 on page 287 of the following reference:
"Introduction to Solid State Physics" 7th edition by Charles Kittel (Wiley, 1996).
A "photon-like polariton" is not really the same as a photon. Strictly speaking, a true photon can exist only in a vacuum. However, the word "photon" is often applied to those excitations in a solid that travel at a phase velocity of "c/n", where "c" is the speed of light in a vacuum and "n" is the index of refraction.
The velocity of light in a solid is really the speed of the photon-like polariton in a vacuum. Similarly, the "optical phonons" in a solid are really "phonon-like" polaritons. The dispersion curves of the uncoupled phonon and the uncoupled photon cross. The branches are split at the point of crossing. Near the forbidden gap, polaritons have a mixed phonon-photon nature.
1. What are polaritons?
Polaritons are quasiparticles that arise from the strong coupling between photons and excitons in a medium. They exhibit both particle-like and wave-like properties, and can propagate through the medium with a fraction of the speed of light.
2. How do polaritons differ from photons?
Polaritons are different from photons in that they have a finite mass and can interact with matter, while photons have zero mass and do not interact with matter. Additionally, polaritons can travel slower than the speed of light, while photons always travel at the speed of light.
3. Are polaritons simply photons in a different form?
No, polaritons are not simply photons in a different form. While they do have some similarities, such as being able to propagate through a medium, polaritons have distinct properties and behaviors that make them different from photons.
4. What are the potential applications of polaritons?
Polaritons have potential applications in fields such as optoelectronics, quantum information processing, and sensing. They could also be used to create new types of lasers and improve the efficiency of existing technologies.
5. How are polaritons studied and observed in experiments?
Polaritons are typically studied using techniques such as angle-resolved photoemission spectroscopy and time-resolved photoluminescence spectroscopy. These experiments involve shining light on a sample containing polaritons and measuring the resulting emission or reflection of light to observe their behavior and properties.
  • Atomic and Condensed Matter
  • Classical Physics
  • Quantum Physics
