Newton's Cradle 2 Balls: What Happens When You Release?
In summary, the conventional 'Newtons cradle' consists of 5 freely hanging steel balls in a frame of some sort. When you let go of one ball at one end you know what happens. Rlease one ball and the other side has a ball oscillating higher. But if you release two balls (with a 5 ball cradle), why is that two balls on the other side of the middle ball also rise in response. How does the system "Know" we have released two balls? Why doesn't the other side just have one ball oscillating higher?Can you work out the one ball case mathematically?The system conserves momentum and energy by transferring it along the lines of balls. The energy gets transferred
skydivephil
474
We have a Newtons cradle , when you let go of one ball at one end you know what happens. Rlease one ball and the other side has a ball osciallte.
But if you release two balls (with a 5 ball cradle) , why is that two balls on the other side of the middle ball also rise in response. How does the system "Know" we have released two balls? Why doesn the other side just have one ball oscillating higher?
Conservation of energy and momentum. This is, of course, assuming that all balls have the same mass.
Well i get that the system is conserving the momentum and tranferring the energy along the lines of balls, but I don't understand why doesn't the enrgy just get transferred into a higher arc?
Have you tried wikipedia? It's got actually quite a good analysis of the subject.
Long story short, you can treat the two-ball case as if it was a single ball hitting the stationary ones, and then another one hitting the now-stationary first one.
Conservation of momentum and energy don't limit the result to just one possible outcome. For example, the released balls could end up bouncing backwards a bit and momentum and energy will be conserved. In the real world, a single released ball will bounce backwards at a small velocity (slight rebound). Link to a website with the details:
http://www.lhup.edu/~dsimanek/scenario/cradle.htm
Keep in mind two things: (1) the balls are not perfectly rigid but deform slightly during a collision, and (2) the "information" about the collision takes some time to travel from one ball to the next.
You can rethink what is going on if you imagine there is a very small gap between each pair of adjacent balls, including the two balls that are initially raised and simultaneously released. It's not a perfect model, but it builds a time delay into the system that would account for the time it takes balls to deform during a collision, or the time it takes the deformed wave to travel across the diameter of a ball.
Thought about this way, every collision involves only two balls (of equal mass), one moving and one at rest. See if you can work out the entire process of these single-pair collisions, and what finally happens with the two balls at the other end. (Hint: this model predicts exactly what is observed. :smile:)
Newton's cradle is usually used to demonstrate conservation of momentum.
This means that the momentum IN will equal the momentum OUT.
2 balls In will give 2 balls OUT
3 balls in will give 3 balls OUT
4 balls IN will give 4 balls OUT
5 balls IN will give 5 balls OUT (think about it !)
Try all combinations !
If you could not see the 5 balls (a piece of card can be used to hide them) and you pretend that you can't hear any collision you would not realize that a collision had occurred.
The fact that collisions may not be perfectly elastic complicates matters slightly (KE is not conserved) but can be safely ignored if all you want is to use the cradle for what it was intended to show.
Not from conservation of momentum alone. You could get 1 ball out at twice the speed of the 2 balls in, and you'd still conserve momentum.
However, this would require an increase in kinetic energy.
The conventional 'Newtons cradle' consists of 5 freely hanging steel balls in a frame of some sort.
My list of possible collisions is based on the given number of balls pulled together to one side and released together.
I have never seen 2 balls (or 3 or 4 or5) released produce anything other than 2 (or 3 or 4 or 5) balls come out of the other side.
This is very easy to confirm by experiment. You should try this before making any unequivocal comment.
I am sure that with some trickery, like sticking balls together you can get other combinations.
With no such trickery I think that I can guarantee that number IN = number OUT
There are many possible combinations that should be tried...
2 in from 1 side, 1 in from the other side...I won't list them all
Nobody is disputing that. Certainly I don't.
My comment was directed at the statement that we only need conservation of momentum, and nothing else, to completely explain what we all agree happens in reality.
Consider this scenario, which we agree does NOT happen:
2 balls in → 1 ball, at TWICE the speed, out.​
Fact: the above does NOT happen.
Fact: momentum is conserved in the above scenario
1. What is Newton's Cradle 2 Balls?
Newton's Cradle 2 Balls is a popular desk toy that demonstrates conservation of energy and momentum using a series of swinging spheres.
2. How does Newton's Cradle 2 Balls work?
When one or two balls are lifted and released, they will swing back and forth, hitting the remaining balls and transferring energy and momentum through the chain. This causes the ball on the opposite end to swing out with the same force that was applied to the first ball.
3. What is the purpose of Newton's Cradle 2 Balls?
The purpose of Newton's Cradle 2 Balls is to demonstrate the laws of conservation of energy and momentum in a visually engaging way. It is also used as a stress reliever and a decorative item.
4. Can you change the number of balls in Newton's Cradle 2 Balls?
Yes, the number of balls in Newton's Cradle can vary, but the most common version has five balls. However, the more balls you add, the more complex the motion becomes.
5. Is Newton's Cradle 2 Balls an accurate model of physics?
While Newton's Cradle 2 Balls is not a perfect representation of the laws of physics, it is a simplified and fun way to understand and observe the principles of energy and momentum.
  • Mechanics
  • Mechanics
  • Mechanics
  • Mechanics
