Circle has infinite sides how many sides does a semi circle have?
In summary, the conversation discusses the concept of a circle having infinitely many "sides" and how this relates to finding the number of "sides" in a semicircle. It is suggested to continue dividing regular polygons in half to determine the number of "sides." However, this definition of a circle as having sides is considered questionable. It is also mentioned that any curve can be seen as having an infinite number of "sides."
Noj Werdna
If a circle has infinite sides how many sides does a semi circle have?
i have asked my teachers at school but they have ll said u wud have 2 divide infinity by 2 and +1 which obviously isn't possible cos infinity isn't reli a number is it...
Thanks
Mathematics news on Phys.org
A circle is said to have infinitely many "sides" due to the analogy with regular polygons.
(i.e. a triangle has 3, a square 4, and so on)
Eventually you get a shape with so many sides that it "becomes" a circle.
If you want to find how many "sides" a semicircle has, just continue in the same way...
Cut regular polygons in half and work out how many sides they have
(i.e. half a triangle has 3 sides half a square has 4, half a pentagon... etc)
Do you see the idea?
(It's just a bad/weird definition of a circle, since it doesn't really have sides, does it?)
Any curve can be looked at as having an infinite number of 'sides' whose length goes to zero, no matter how big.
there are two sides to a circle - inside and outside. (posted lest someone begin to take this more seriously than the topic deserves)
1. How can a circle have infinite sides?
A circle is a geometric shape that is perfectly round, with no edges or corners. It is defined as the set of all points in a plane that are equidistant from a given point, known as the center. This means that no matter how small we make the sides of a circle, we can always divide it into smaller parts, making it have an infinite number of sides.
2. Does a semi-circle have half the number of sides as a circle?
No, a semi-circle is a half of a circle and therefore has the same number of sides as a full circle - infinite. The number of sides does not change, regardless of how much of the circle is visible.
3. Is a semi-circle considered a polygon?
No, a semi-circle is not considered a polygon. A polygon is a 2-dimensional shape with straight sides connecting at angles, while a semi-circle is a curved shape with a circular boundary. Therefore, it does not fit the definition of a polygon.
4. Can a semi-circle be divided into smaller parts like a circle?
Yes, a semi-circle can be divided into smaller parts just like a circle. The difference is that a semi-circle can only be divided into 180 degrees, while a circle can be divided into any number of degrees. This is because a semi-circle is only half of a circle.
5. How many sides does a semi-circle have in terms of radians?
In terms of radians, a semi-circle has a total of π (pi) radians. This is because a full circle has 2π radians, and a semi-circle is half of a circle. Therefore, a semi-circle has half of the number of radians as a full circle.
  • General Math
17K
  • General Math
  • General Math
