Energy in a Fundamental Standing Wave Vs. The Energy in its Harmonic Waves
In summary, the energy in a standing wave is less than the energy in its first three harmonics. The energy in the fundamental frequency will transmit energy to its adjacent harmonics, but if you place energy into any of the harmonic modes, you will see little effect on its fundamental frequency.
Pathways33
I am seeking to understand the relationship of energy within a standing wave vs. the energy in its first three harmonics.
Is the energy latent within the fundamental wave the same as the energy in its first three harmonics, or is the energy and exponential increase.
IE How much energy is required to encourage the fundamental to oscillate compared with the energy required to encourage the three harmonics to oscillate?
Any assistance much appreciated.
Aren't the first three harmonics all standing waves of different frequencies?
I'm not sure what you mean when saying energy depends on the harmonic. Energy doesn't have much to do with harmonic, since harmonic is defined by the frequency the system vibrates at (though in the energy's formula, frequency may appear).
Thanks. I'm looking for a link between whether the fundamental wave has embedded within it the harmonic waves also?
As each wave whether a moving or standing wave contains kinetic and potential energy, I'm looking for the energy difference inherent in the wave.
From my deductions it appears that there is less energy embedded in the fundamental wave than embedded in the harmonics of that fundamental.
I'm seeking if there is a mathematically formula to confirm this.
I'm looking for the energy relationship (or variance if any) between the fundamental wave and the harmonics of that wave.
Thanks
What do you mean by "fundamental wave"? Do you mean wave at fundamental frequency?
Anyway why don't you show us your work? :smile:
Yes, that's correct.
The fundamental frequency, and its first three harmonics.
I want to know that if I put energy into the fundamental frequency, will that also transfer to the harmonic frequencies.
Conversely, if you place energy into say the third harmonic frequency, how much of that energy (if any)will permeate back into the fundamental frequency.
My thinking is that in an electromagnetic medium the fundamental frequency will transmit energy to its adjacent harmonics.
My postulation is that if you 'pump' energy into the fundamental frequency, it will easily transpose (resonate) into its harmonic modes, but if you place energy into any of the harmonic modes, you will see little effect on its fundamental frequency. I would tend to think that if you pump energy into an harmonic frequency, it itself will become a fundamental frequency and will only transpose energy 'down' to its harmonic frequencies and NOT up to its original fundamental frequency where it originated from.
Is there any study of this?
I am linking it to a superposition theory I am exploring.
Cheers
You seem to have some misunderstanding of a standing wave. That's OK.
Say you have a wave A = sin(kx-ωt). As time advances, holding x constant, the wave moves to the right. Add this to another, B = sin(kx+ωt). This wave moves to the left.
A+B is a standing wave. The sum is not composed of harmonics, but can be expressed as a the product of two waves; one stationary in time, and the other, stationary in space:
A+B = 2 cos(ωt) sin(kx)
Cheers
I'm not sure what you meant by transferring energy from fundamental frequency to its harmonics, because, you know, energy is stored in the vibrating system, not frequency. Can you give us an example or illustrate your point in some way?
Sorry, no.
Energy does not spontaneously transfer between the modes of vibration of a system (including EM waves).
If you have a perfect guitar string on a perfectly solid guitar and you pluck it precisely in the middle, you will get the fundamental. The fundamental will continue to sound until all the energy dissipates.
If you do the same thing but this time cause the second harmonic to sound (bell tone technique) that too will simply continue to sound.
Only when the string and guitar are not 'perfect' will any transfer take place and even then, very little.
EM waves are even more perfect.
1. What is a fundamental standing wave?
A fundamental standing wave is the simplest form of a standing wave, where the nodes (points of no displacement) and antinodes (points of maximum displacement) are fixed and do not change over time. It is the lowest possible frequency at which a standing wave can occur in a system.
2. How does the energy in a fundamental standing wave compare to the energy in its harmonic waves?
The energy in a fundamental standing wave is equal to the sum of the energies in all of its harmonic waves. This means that the energy in a fundamental standing wave is higher than the energy in any of its individual harmonic waves.
3. What are harmonic waves?
Harmonic waves are standing waves that have a frequency that is an integer multiple of the fundamental frequency. These waves are formed by the combination of the fundamental standing wave and its overtones (higher frequency standing waves).
4. Why is energy important in standing waves?
Understanding the energy in standing waves is important because it helps us understand the behavior of these waves in different systems. For example, knowing the energy distribution in a guitar string can help us predict which harmonics will be produced when the string is plucked.
5. How does the energy in standing waves affect the stability of a system?
The energy in standing waves can have a significant impact on the stability of a system. High energy standing waves can cause destructive interference, leading to a decrease in amplitude and potentially causing the system to become unstable. Additionally, standing waves with a low energy level may not produce enough energy to sustain the system, leading to a loss of stability.
  • Classical Physics
  • Classical Physics
