wdlang
- 307
a basic problem
but i have no idea how to measure it
The scattering cross section is measured by analyzing the intensity of scattered particles at different angles. This is done by using specialized equipment, such as a particle detector or spectrometer, which can detect and measure the scattered particles.
The scattering angle is an important parameter in measuring the cross section as it directly affects the intensity of the scattered particles. By varying the scattering angle, scientists can gather information about the scattering process and determine the cross section for a specific angle.
The incident particle energy is a key factor in determining the scattering cross section. Higher energy particles will generally have a larger cross section compared to lower energy particles. This is because higher energy particles have a greater chance of interacting with the target particles, resulting in a larger scattering cross section.
Yes, the scattering cross section can be calculated theoretically using various mathematical models, such as the Rutherford scattering formula. These calculations take into account the properties of the incident and target particles, as well as the scattering angle, to determine the expected cross section for a given scenario.
The scattering cross section is an important measurement in particle physics research as it provides valuable information about the interactions between particles. By studying the cross section, scientists can gain insights into the fundamental properties of matter and the underlying forces that govern the behavior of particles.
