If H and K are subgroups of G, and K is normal, then HK is a subgroup of G.
In summary, the proposition states that if H and K are subgroups of G and K is normal, then HK is also a subgroup of G. The proof shows that HK satisfies the closure, identity, and inverse properties. It also suggests using the fact that K is closed under conjugates instead of the given fact that aK=Ka.
jmjlt88
96
Ignoring the fact that it is redundant at times, is this proof correct? Also, is there a way to show that same result using the fact that K is closed with respect to conjugates rather than the fact that for all a in G, aK=Ka. Thank you! :)
Proposition: If H and K are subgroups of G, and K is normal, then HK is a subgroup of G.
Proof: Let H,K be subgroups of G with K normal. We wish to prove that HK is a subgroup of G.
Closure
Take any two elements of HK, say hk and h’k’. Then, we want to show that (hk)(h’k’) is in HK. We note that K is normal, which implies that for kh’, there is some k’’ in K such that kh’=h’k’’ since for all a in G, aK=Ka. Thus,
(hk)(h’k)’=h(kh’)k’=h(h’k’’)k’=hh’k’’k’. Then since hh’ is in H and k’’k’ is in K, we have that hkh’k’ is in HK.
Identity
Since H and K are both subgroups and therefore contain e, we have that HK must also contain e.
Inverses
Take any element hk in HK. We wish to show that (hk)-1 is in HK. We note that (hk)-1=k-1h-1. Then since K is normal and for any a in G, we have that aK=Ka, there exists some k’ in K such that k-1h-1= h-1k’. And, we have that h-1k’ is in HK. Hence, k-1h-1 is HK and every element in HK has an inverse in HK.
Therefore, we conclude that HK is a subgroup of G.
QED
That seems alright.
If you want to work with conjugates, then perhaps doing something like follows could work:
[tex](hk)(h^\prime k^\prime)=hh^\prime [(h^\prime)^{-1} k h^\prime] k^\prime[/tex]
and use that K is closed under conjugates.
1. What is a subgroup?
A subgroup is a subset of a group that maintains the same group operation as the original group. This means that when the elements of the subgroup are combined using the group operation, the result is still an element of the subgroup.
2. How do you know if a subgroup is normal?
A subgroup is normal if it is invariant under conjugation by any element of the original group. In other words, for any element k in the subgroup K and any element g in the original group G, the element gkg^-1 is also in the subgroup K.
3. What does it mean for a subgroup to be normal?
If a subgroup is normal, it means that it is a special type of subgroup that is closed under conjugation by any element of the original group. This allows for certain simplifications and properties in group theory.
4. What is the significance of HK being a subgroup of G?
If HK is a subgroup of G, it means that the elements of HK can be combined using the group operation of G and the result will still be an element of HK. This is useful in simplifying calculations and proving certain properties of the group.
5. Can you give an example of a group where HK is a subgroup?
One example is the group of integers under addition. If H is the subgroup of even integers and K is the subgroup of multiples of 3, then HK is the subgroup of even multiples of 3, which is still a subset of the integers and maintains the group operation of addition.
