New Reply
Gravity on a Planet Sized Ring
Share Thread Thread Tools
Jan24-13, 05:43 PM   #1
Hello,
I was wondering what the effect of gravity in a planet sized ring would be. If any of you have played the Halo game series, the ring structure is what I have in mind.
-Would you be able to walk on the inside of the ring, and what forces will or will not permit you to?
-Would you be able to walk on the outside of the ring, and what forces will or will not permit you to?
-And can you explicitly identify where the center of mass and gravity are and how they are involved with the forces above?
My line of reasoning is that center of mass and gravity would be in the center of the ring, which would mean that you are able to walk on the outside of the ring, provided that it rotates fast enough.
However, I'm not sure what would happen if you were to try to walk on the inside of the ring. My intuitions compares it to a centrifuge, where if something was spinning fast enough, the contents on the inside would be pushed against the wall, but it conflicts with how I think about the scenario where I walk on the outside of the ring. I hope this makes sense.
Thanks!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Jan24-13, 05:56 PM   #2
Recognitions:
Homework Helper Homework Help
Unlike a hollow sphere where the field is zero inside the sphere, the field inside a thin cylinder or ring is not zero and is strongest near the surface of the cylinder or ring. Previous thread on this:
http://www.physicsforums.com/showthread.php?t=586813
Jan24-13, 05:57 PM   #3
Recognitions:
Gold Membership Gold Member
do a forum search. This topic was beat to death here recently. Probably searching for "ringworld" or "larry niven" will turn it up since they were mentioned incidentally in the thread.
EDIT: I see rcgldr beat me to it.
New Reply
Tags
centripetal, gravity
Thread Tools
Similar Threads for: Gravity on a Planet Sized Ring
Thread Forum Replies
planet sized diamond... General Astronomy 10
Gravity: Earth-sized platinum sphere with 3 meter empty center - behavior General Physics 9
Jupiter-sized Planet Lurking in Oort Cloud? Astrophysics 1
~Gravity on a distant planet Introductory Physics Homework 6
escaping gravity of a planet... General Physics 18
