Register to reply
RCC structures and load bearing walls
by rollingstein
Tags: bearing, load, structures, walls
Share this thread:
rollingstein
#1
Nov2-13, 01:48 AM
PF Gold
P: 330
In modern buildings (I'm talking about taller structures, apartments, etc. not houses) that have a reinforced concrete framework are the internal / external walls (usually brick, masonry etc.) ever load bearing?
In the sense is the strength / integrity of the structure ever depending or taking credit for the walls? Just curious.
Looking at the way they are constructed, i.e. RCC framework & then later walls it doesn't seem like walls are essential to structural integrity but that's just a naive observation.
Or is there no typical case and every building is a different situation.
Phys.Org News Partner Engineering news on Phys.org
Identifying long-distance threats: New 3D technology could improve CCTV images
Intelligent system that predicts when alarms might be triggered could greatly improve the management of industrial plant
3D printed nose wins design award
Baluncore
#2
Nov5-13, 10:03 PM
Sci Advisor
Thanks
P: 1,910
Hanging walls must be hung from an internal structure. A building should be secure, even if the cladding is removed and changed.
Heavy external walls must be capable of carrying their own mass safely.
Where external walls carry the mass of higher floors and walls they are designed to be thicker and stronger as they are then an essential part of the structure.
gloriasakins
#3
Nov10-13, 03:28 AM
P: 4
The use of RCC framed structure is unnecessarily propagated by people with vested interests like Steel manufacturers,Cement manufacturers etc.History shows that LOAD BEARING buildings have stood the test of time and are still standing tall and strong even after several centuries. That too depend upon the structural designs and analysis done by the engineers and architects. But on the on the other hand RCC structures have a life span of 30 to 100 years only.For low rise buildings it's always better to go with Load bearing construction.
Register to reply
Related Discussions
Bearing load beam equation Engineering, Comp Sci, & Technology Homework 5
Load on a journal bearing in a vertical shaft Mechanical Engineering 3
Minimum strength of pipe for load bearing General Engineering 1
Load bearing structure made of matchsticks Introductory Physics Homework 3
Bearing Load Calculations - Urgent please General Engineering 2
