Maximum positive integer that adds up to a perfect square?
In summary, the conversation is discussing the problem of finding the largest positive integer x such that 4 to the power of 27 plus 4 to the power of 1000 plus 4 to the power of x adds up to a perfect square. The conversation includes attempts at solving the problem and clarifying the question. The final statement acknowledges that the speaker is unable to answer the problem due to difficulties with basic arithmetic.
gundu
4 to the power of 27 + 4 to the power of 1000 + 4 to the power of x.
x is the maximum positive integer and it adds up to a perfect square?
To clarify your question, you are asking for the largest integer x such that [tex]4^{27}+4^{1000}+4^{x}[/tex] is a perfect square?
What have you tried so far? Can you give any value of x that makes this a perfect square?
Assuming that x> 27,
[tex]4^27+ 4^1000+ 4^x= (4^{27})(1+ 4^{983}+ 4^{x- 27})[/tex]
[tex]4^{27}= (4^{26})(2)[/tex]
and
[tex]1+ 4^{983}+ 4^{x- 27}[/tex]
is an odd number. What does that tell you?
I think Halls meant [itex]4^{27} = 4^{26} \times 2^2[/itex].
Halls also means:
[tex]4^{27}+ 4^{1000}+ 4^x= (4^{27})(1+ 4^{973}+ 4^{x- 27})[/tex]
(1000-27=973)
But the problem is to prove nothing is possible after that, hall.
Anyway gundu has to first clear what he has done as shmoesaid.
Which I interpret to mean "What is the largest positive integer such that this adds to a perfect square.
Of course, since I clearly can't do basic arithmetic, I can't answer this!
1. What is the maximum positive integer that adds up to a perfect square?
The maximum positive integer that adds up to a perfect square is 9. This is because 9 is the largest perfect square that is less than the total sum of all positive integers from 1 to 9.
2. How do you determine if an integer adds up to a perfect square?
An integer adds up to a perfect square if the sum of all positive integers from 1 to that integer is a perfect square. For example, the sum of all positive integers from 1 to 9 is 45, which is a perfect square (9 x 9 = 81).
3. Is there a formula for finding the maximum positive integer that adds up to a perfect square?
Yes, there is a formula for finding the maximum positive integer that adds up to a perfect square. It is given by the equation: n(n+1)/2 = x^2, where n is the maximum positive integer and x is the perfect square.
4. Can there be more than one maximum positive integer that adds up to a perfect square?
No, there can only be one maximum positive integer that adds up to a perfect square. This is because the sum of all positive integers from 1 to that integer must be a perfect square, and there is only one perfect square that is less than the total sum.
5. Are there any real-world applications for knowing the maximum positive integer that adds up to a perfect square?
Yes, knowing the maximum positive integer that adds up to a perfect square can be useful in fields such as cryptography and computer science. It can also be used in number theory and mathematical puzzles.
  • Math POTW for Secondary and High School Students
