Pressure of Liquid in Slanted Container at Depth
In summary, the pressure of liquid at a depth would be in a container which is slanted, but the shape of the container is irrelevant.
batballbat
127
what would the pressure of liquid at a depth be in a container which is slanted?
i suspect [tex] h.d.g.sinAngle [/tex]. correct me if i am wrong
in the derivation of the pressure of liquid, the weight is assumed to act perpendicular to the column of liquid. Plz comment
Gravity pulls straight down, so...
of course but i find similar case to the inclined plane. can somebody give a reasoning?
What do you find similar about an inclined plane? What is YOUR reasoning?
somebody reply
The pressure depends on the depth beneath the surface, which is not slanted. As already stated, the shape of the container--whether slanted or vertical--is irrelevant.
If you want more, give a specific example of what you have in mind with a diagram.
Sorry, we don't spoonfeed here. If you want to learn/want help, you need to show some effort at trying to figure it out for yourself. Then when you make a wrong turn, we'll nudge you back in the right direction.
wouldnt this imply that the liquid would accelerate at g in slanted tubes?
No. Please describe exactly what you have in mind. Are you talking about hydrostatic pressure? (Which is what I assumed.) Or fluid dynamics?
g is acceleration due to gravity. If you block that acceleration, the required force is f=mg. Aka, weight.
Since you're talking about pressure-at-depth then you're talking about a container full of fluid (as opposed to, say, an air-filled container with an amount of water placed in it).
Water suspended in water is neutrally buoyant, so its not like some arbitrary mass of water is going to start sliding to the bottom, accelerating under gravity.
I am not familiar with the terms but i guess you are asking whether i am talking about stationary fluids or flowing ones. Eg. in an inclined plane, there is a mass a top, even though its weight acts exactly downward, it would rather move along the plane. And the force with with it moves along the plane is lesser according to its slope. Same for liquids. But as dave said while the liquid is continuous and stationary, the force with with a finite upper part of liquid exerts on the lower part will be the same as for the case of liquids in vertical column. This is not clear to me.
Eg. let's take a column of liquid standing upright and pour some water into it. And then slant it a bit. Then the depth of the liquid increases even though it is not continuous on the upper part (i hope this is understood). So as the depth increases although not uniformly, the pressure in one side must increase. Help me out with this.
Pascal's vases:
Another set:
Notice that no matter how weird the shape, the tops of the liquid surfaces in the different containers are at the same level. The pressure difference in some container from bottom to top does not depend on shape. It depends only the height of the liquid.
i haven't learned any of hydrodynamics or hydrostatics. So i think this phenomenon is taken as as true. Is there a proof for it?
The diagram and image (real) I posted in [post=3643843]post #16[/post] are pretty solid evidence. Hydraulic pumps rely on this principle.
This is getting very frustrating for me because a bunch of people are putting a bunch of effort into helping you learn, but it doesn't seem like you are trying at all. For example, you said you don't know terms like "hydrostatic", but that term is defined in the very first sentence of the link i gave you in the first reply!
"Learning" is not something we can give you: we can tell you where to find the knowledge, but you have to get it into your head.
OP , when I was a kid (well now also I am a kid in class 10th ! :biggrin:) I also used to think the same way as you are currently.
I used to say :
Pressure = (Force x sin θ)/Area
Now I know that I was wrong because - Pressure is "thrust upon area." It is defined this way. Thrust is defined as force acting perpendicularly on a body.
Hence always ,
P=hρg x sin 90o or P = hdg x cos 0o
As sin 90o = cos 0o = 1
So P=hρg
Do you get it now ?
the diagram is clear, and i asked the question, and i had seen before, so i asked the question. to, sankalpmittal
take a glass of water, then slant it slightly so as not to drop the water, As the depth increases on one side, doesent the pressure increase?
so the pressure depends on the vertical distance of he column irrespective of the shape. Am i correct?
Yes. Pressure depends on the vertical distance below the fluid surface. Shape of the container has nothing to do with it.
Whether the pressure increases or not depends on the shape of the object and where you measure the pressure. When you have a rectangular container with 1x1x1 m dimensions and you have 1 cm of water on the bottom, and when you turn the container at a 45 degree angle, the water will accumulate in one corner and the height from the bottom of the container to the water level will be higher than before, therefore also the pressure on the bottom of the container. However, if you have a narrow tube and a lot of water in it, 10 m tall and 1 cm wide, with 2 m of water in it, if you then turn it at an angle the water level from the bottom of the container will be less, meaning the pressure on the bottom would also be less.
So to find out whether or not the pressure will increase, you will have to calculate the water level when straight and the water level when slanted. Then you can compare these to find the pressure difference.
thank u chingel, that's what i wanted.
1. What is the equation for calculating the pressure of liquid in a slanted container at a given depth?
The equation for calculating pressure at a given depth is P = ρghcosθ, where ρ is the density of the liquid, g is the acceleration due to gravity, h is the depth of the liquid, and θ is the angle of the slanted container.
2. How does the angle of the slanted container affect the pressure of the liquid at a given depth?
The angle of the slanted container, θ, affects the pressure of the liquid at a given depth because it changes the effective depth of the liquid. The greater the angle, the greater the effective depth and therefore the greater the pressure.
3. What is the relationship between the density of the liquid and the pressure at a given depth in a slanted container?
The density of the liquid, ρ, has a direct relationship with the pressure at a given depth in a slanted container. As the density of the liquid increases, so does the pressure at that depth.
4. How does the pressure of a liquid in a slanted container at a given depth change with an increase in depth?
The pressure of a liquid in a slanted container at a given depth increases with an increase in depth. This is because the weight of the liquid above the given depth increases, resulting in a greater force and therefore a higher pressure.
5. Can the pressure of a liquid in a slanted container at a given depth be negative?
No, the pressure of a liquid in a slanted container at a given depth cannot be negative. Pressure is always a positive quantity and increases with depth in a liquid. However, the pressure at a given depth may be less than the pressure at a different depth due to variations in density or depth of the liquid.
  • Mechanics
