How Do I Solve a Translational Equilibrium Problem in Aerospace Engineering?
The discussion revolves around solving a translational equilibrium problem in aerospace engineering, specifically involving the analysis of forces in a system of cables under tension. The problem includes determining the maximum force that can be applied at a point and the corresponding angle, with a focus on applying equilibrium conditions and resolving forces.
  • Homework-related
  • Rob describes the problem involving two cables and seeks guidance on applying equilibrium conditions to find the maximum force P and angle α.
  • Rob mentions using a free body diagram and resolving forces, but expresses uncertainty about including the term for P in his equations.
  • Some participants suggest that Rob is on the right track and confirm that he should have two equations for the two unknowns, P and α.
  • There is a discussion about the correct setup of the equations, with emphasis on maintaining consistent directional conventions for forces.
  • One participant hints at rearranging the equations to express tan α in terms of other variables.
Participants generally agree on the approach to setting up the equations for equilibrium, but there are variations in how to express the terms and some uncertainty remains regarding the inclusion of certain components in the equations.
Rob's understanding of the problem is limited due to missing lectures, and he is self-teaching from a textbook. The discussion does not resolve all uncertainties related to the setup of the problem or the use of maximum tension values.
Students in aerospace engineering or related fields who are learning about translational equilibrium and force analysis in cable systems may find this discussion helpful.
rc flyer uk
I started my aerospace enginnering degree this year but have missed the first 7 weeks of lectures due to being in hospital, i was sent all lecture notes but am strugling with my mech module. I have my first assignment questions due in this week and am having dificulty thought you guys might be able to give me some guidance! Thanks
Question?
Two cables AC and BC are tied together and loaded at C as shown. The maximum allowable tension in each cable is 800N.
Find the magnitude of the largest force P Which could be applied at C.
Also find the corresponding value of the angle α
I have attached a word document of the diagram!
My workings so far have been something like this:
I have drawn a free body diagram to help make things more simple!
I have resolved the forces and renamed bc to T1 and ac T2
Apply the equilibrium conditions-
ΣFx=0= T1cos50- T2cos35 (+Pα) unsure if (+Pcosα) is nessacery as i have never completed an angular question like this!
ΣFy=0= T1sin50 + T2sin35 - Psinα
Next i am gusing as i am teaching myself from a book! i use these to equations as simultaneous equations and solve them. I was wondering if i should use the value of 800N for T1 and T2 as this is there max allowable tension but i am not sure!
Please can some one point me in the right direction, thanks a lot your help is much apreciated.
Rob
I don't know what "Attachment Pending Approval" means, but I'm not able to open your attachment. Hopefully it will get approved before your HW is due...
You are on the right track. You will have two equations and two unknowns, P and [tex]\alpha[/tex]. Here is a hint: When you have your two equations, you will be able to rearrange the terms to get [tex]tan \alpha =[/tex]...
Make sure you are consistent with which is the +x and +y directions in your equations. It looks like you have set up to the right being +x and up as being +y. If you stick with that through the whole problem you'll be fine.
Just adding to what Fred mentioned
ΣFx = 0 = T1 cos50 - T2 cos35+Pcos α by the convention that forces to the right are + and forces to the left are - (convention in Cartesian coordinates).
ΣFy = 0 = T1sin50 + T2sin35 - Psinα is correct.
Thanks a lot guys managed to complete the question and got it handed in on time!
Much apreciated!
Rob
12K
9K
