How Do You Determine the Direction of Coriolis Force?
The Coriolis force is a fictitious force that affects the trajectory of moving objects on the Earth's surface due to its rotation. When a ball is thrown vertically upward, it retains the eastward velocity of the Earth's surface. As the ball ascends, it cannot increase its eastward speed, resulting in a perceived westward deviation from its original position when it falls back down. This phenomenon is a direct consequence of the Earth's eastward motion and the principles of relative motion.
  • Understanding of fictitious forces, specifically Coriolis and centrifugal forces.
  • Basic knowledge of Newtonian physics and relative motion.
  • Familiarity with the Earth's rotation and its effects on moving objects.
  • Concept of inertia and how it applies to objects in motion.
  • Research the mathematical formulation of the Coriolis effect in physics.
  • Explore real-world applications of the Coriolis force in meteorology and oceanography.
  • Study the differences between Coriolis and centrifugal forces in rotating systems.
  • Investigate how the Coriolis effect influences weather patterns and ocean currents.
Students of physics, meteorologists, and anyone interested in understanding the effects of Earth's rotation on moving objects.
madking153
hi,
i read lots of book regarding fictitious force - coriolis and centrifugal forces, but i am not clear how to determine the direction of the force..
example. if we throw a ball vertical up , how we can know the deviation from the original position ( from book we know that if the ball drop from a height - it will deviate to east )
pls explain or show the links regarding this two forces
thanks thansk
THe Earth's surface is moving toward the east. If you threw a ball straight up, it would initially be moving eastward at the same speed as the Earth's surface. Ignoring any air resistance, the ball will continue to have this eastward speed.
As the ball gets higher, it would have to move eastward at a faster speed in order to stay above the same spot on the earth. This is just like the fact that the outside horse on a merry-go-round moves faster than the inside horse because it is at a larger radius.
Since the ball can not gain speed in the eastward direction, it "lags behind" the point on the Earth where it was launched. From the point of view of the Earth's susrface, it seems as if a force is pushing the ball westward, when actually it is the lack of an easterly force that causes the effect.
  • · Replies 18 ·
  • · Replies 21 ·
10K
