Thread Closed
Angular momentum in a particle system
Share Thread Thread Tools
Nov19-05, 10:09 PM   #1
Figure 11-26 shows three particles of the same mass and the same constant speed moving as indicated by the velocity vectors. Points a, b, c, and d form a square, with point e at the center. Rank the points according to the magnitude of the net angular momentum of the three-particle system when measured about the points, greatest first (use only the symbols > or =, for example a>b>c=d=e).
Okay, so angular momentum is equal to mass (radius cross product velocity). Since velocity is constant and the mass is the same, this leads only the radius or distance to compare. However, I am not quite sure how I should judge the distance of the particles. I mean what is the origin or the reference point that should use to judge these particles from?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Nov19-05, 10:49 PM   #2
Admin
Perhaps label each ball with 1, 2, 3 and decide which balls contribute the angular momentum with respect to each point, a, b, c, d, e.
Thread Closed
Thread Tools
Similar Threads for: Angular momentum in a particle system
Thread Forum Replies
If a particle and a system have zero momentum... Introductory Physics Homework 1
Angular momentum of a particle Introductory Physics Homework 1
Angular momentum multiparticle system Introductory Physics Homework 2
Momentum in a Many-Particle System Introductory Physics Homework 1
angular momentum of a two-particle system Advanced Physics Homework 3
