Specific Heat and Phase Change/Latent Heat Problems PLEASE HELP
The discussion revolves around problems related to specific heat, phase changes, and latent heat. Participants are exploring calculations involving energy transfer in heating water and the energy required for phase changes in water and aluminum in a refrigeration context.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to apply the specific heat formula and energy conservation principles to two distinct problems involving heating water and freezing water. Some participants question the accuracy of the calculations and suggest clarifying the steps involved in energy transfer.
Participants are actively engaging with the problems, offering guidance on how to approach the calculations. There is an acknowledgment of the need to break down the problems into multiple steps, particularly regarding the energy changes associated with phase transitions. Some confusion remains about the application of specific formulas and the correct sequence of calculations.
Participants note the importance of understanding vocabulary and phrasing in physics problems, which may affect communication and comprehension. The original poster expresses a preference for numerical explanations over written descriptions, indicating a potential barrier to understanding the discussion.
kris24tf
Hello,
I have a couple problems that I have tried but I'm not sure if I worked them properly. Any advice or help is appreciated.
One problem is: An electric immersion heater has a power rating of 1500W. If the heater is placed in a liter of water at 20 degrees C, how many minutes will it take to bring the water to a boil? Assum no heat loss except to the water.
I tried it this way. Q-Pxt, P=1500W Q=mcDeltaT=1kg(4186)(-80 (change in temp))=334880. Then I took 334880 and divided by 1500 to get t... Is this the right way to do it or do I need to use a different equation?
The other isA volume of .5 L water at 16 deg. C is put into an aluminum ice tray of mass .25 kg at the same temp. How much energy must be removed from this system by the refrigerator to turn the water to ice at -8 deg. C?
I tried it by saying .5L=.5kg, Qgained=.25kg(920)(-8-16)=-5520
Qlost=.5(4186)(-24)=-50232, dividing these gives -.11 J... I am sure this is not the correct way. If someone could steer me in the right direction, I'd appreciate it...
Also, I do better with numerical explanations then written ones. What may sound normal to you might be over my head or sound completely different. Not trying to be weird, but it's true! And if anyone checks older posts, if there are any I haven't responded to in the past, it is only because I didn't get a response for a long time and did it on my own...
Please help me with these. I'd liek to know what I'm doing here...
in the first one, the temp change is +80 K ... keep track of signs!
In the second, you need to remove Energy from the *water* and the metal.
First take out enough E to make liquid water @ 273 K
then take out E to make solid water @ 273 K
then take out E to make it solid water @ 265 K .
Part of the subject (any subject) is the vocabulary ...
another part is the preferred phrasing and syntax.
You have to learn to USE these to communicate with.
So I did the first question correctly?
I understand this, I am just not sure whether to apply Q=mcdeltaT or Q=mL and to which part... I am confused how to apply these concepts.
I know that the vocab is important, I was just saying that sometimes it is difficult to understand some things when they are written on a casual message board where people don't necesarily speak the clearest...
I have another problem. The wall of a house is composed of solid concrete with outside brick veneer and is faced on the inside with fiberboard. The fiberboard width is 2 cm, the concrete width is 15 cm, and the brick width is 7 cm. If the outside T is -10 degrees, and the inside T is 20 degrees, how much E is conducted through the wall with dimensions 3.5mx5m in 1 hour?
I want to try something along the lines of k1A(T-T1)/d1=k2A(T2-T1)/d2 or something along those lines, but I know I have to use a T3, but I'm not sure how to find the third T. If you or anyone could help me set that up, that would be great.
You need to listen to lightgrav,
You must do the problem in 3 steps (+1 for the Al.)
Take the energy lost. (You do this correctly) but do it three times just as lightgrav says but you can use energy instead of Kelvin. Use Q=mL only for the phase change Water to Ice.
Then you must do 1 extra step for the energy for the tray.
Add everything up and that will be the total Q you are looking for.
curly
Ahh, I see it now,
Thanks
Aliminum is not changing its state your calculation is correct.
Water is changing its state.Total heat energy is losted by water will be addition of heat lost to cool 0 C, Heat lost during melting and heat lost to cool -8 C.
16K
