Deriving the Shortest Path in Radial Co-ordinates Using Variational Principle
The discussion revolves around deriving the shortest path in radial coordinates using the variational principle. The original poster presents a problem involving the expression of curve length in radial coordinates and attempts to derive the shortest path between two points.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to set up a functional for the length of a curve and calculates partial derivatives, leading to a nonlinear differential equation. They express uncertainty about the correctness of their approach and seek guidance on the next steps.
  • Another participant suggests a specific equation to obtain from varying the path length and notes that a constant radius does not satisfy this equation, indicating that a circle is not the shortest distance. They recommend exploring the equation for a line in polar coordinates.
  • A third participant draws parallels to a similar problem in Cartesian coordinates, outlining the steps taken to arrive at a solution and suggesting that the same principles apply.
Participants are navigating the complexities of variational principles in polar coordinates and are considering the implications of cyclic variables and conservation laws. The original poster's uncertainty about their setup and the nonlinear nature of the resulting equations are noted as constraints in the discussion.
No Name Required
I have this question,
Express the length of a given curve [tex]r = r(\theta)[/tex] in radial co-ordinates. Using the Variational principle derive the shortest path between two points is a line.
Ive drawn a picture with two angles (measured from the x-axis) [tex]\theta_1[/tex] and [tex]\theta_2[/tex] so that [tex]r(\theta_1) = r_1[/tex] and [tex]r(\theta_2) = r_2[/tex].
I found the legth of the infinitesimal [tex]dl[/tex] to be
[tex]dl = \sqrt{r'^2 + r^2} \; d\theta[/tex] so that
[tex]\displaystyle{L = \int^{\theta_2}_{\theta_1} \sqrt{r'^2 + r^2} \; d\theta}[/tex]
So my functional is [tex]f = \sqrt{r'^2 + r^2}[/tex]
I have calculated [tex]\displaystyle{\frac{\partial f}{\partial r} = \frac{r}{\sqrt{r^2 + r'^2}}}[/tex] and [tex]\displaystyle{\frac{\partiall f}{\partial r'} = \frac{r'}{\sqrt{r^2 + r'^2}}}[/tex]
Also [tex]\displaystyle{\frac{\partial f}{\partial \theta} = 0}[/tex]
I have tried setting up
[tex]\displaystyle{\frac{d}{d\theta} \frac{\partial f}{\partial r'} - \frac{\partial f}{\partial r} = 0}[/tex] but this is leading to a nasty nonlinear second order differential equation which i presume is not correct.
I know that [tex]\theta[/tex] is cyclic so a conservation law exists but I am not sure how to go about using this.
If someone could give me a plan of how to do the next couple of steps it would be great.
Thankyou
I think the equation you should obtain from varying the path length is
[tex] \frac{d}{d\theta}\left(\frac{r'}{f}\right) = \frac{r}{f},[/tex]
where [tex]f(r,r') = \sqrt{r^2 + r'^2}[/tex]. First, let me note that a circle ([tex]r[/tex] constant) does not satisfy this equation. You should expect this since the arc of a circle is not the shortest distance between two points. Second, you should probably write out the equation for a line in polar coordinates. It is kind of messy in general, but you could pick a representative type of line and show that it solves the equation. Once you know this, you can always rotate your coordinates to show that all other lines satisfy the differential equation too.
I worked it out myself so it can be definitely be done. Let me know if you have any more trouble.
In cartesian coordinates you have:
[tex]\int{\sqrt{1 + \dot{y}^2}dx}[/tex]
[tex]\frac{\partial f}{\partial y} - \frac{d}{dx}\displaystyle{(}\frac{\partial f}{\partial \dot{y}}\displaystyle{)} = 0[/tex]
... thus:
[tex]f = \sqrt{1 + \dot{y}^2}[/tex]
[tex]\frac{\partial f}{\partial y} = 0; \frac{\partial f}{\partial \dot{y}} = \frac{\dot{y}}{\sqrt{1 + \dot{y}^2}}[/tex]
[tex]\frac{d}{dx}\displaystyle{[}\frac{\dot{y}}{\sqrt{1 + \dot{y}^2}}\displaystyle{]} = 0[/tex]
[tex]\frac{\ddot{y}}{\sqrt{1 + \dot{y}^2}^3} = 0[/tex]
... thus:
[tex]\ddot{y} = 0[/tex]
... and:
[tex]y = ax + b[/tex]
Thankyou very much for your time and thoughts. I have solved the problem in polar co ordinates and if anyone is particularly interested i will write it up for them. I will check back tomorrow.
  • · Replies 18 ·
