Solving a Complex Equation Using Binomial Formula with Cosine and Sine Functions
  • Context: Graduate
  • Thread starter Thread starter Bob19
    Binomial Formula
The discussion revolves around solving the polynomial equation z^4 + z^3 + z^2 + z + 1 = 0 using the binomial product formula and exploring related equations involving powers of z, specifically z^8 + z^6 + z^4 + z^2 + 1 = 0. Participants are examining the implications of these equations in the context of complex numbers and roots of unity.
  • Bob presents the equation z^4 + z^3 + z^2 + z + 1 = 0 and seeks to use the binomial product formula to demonstrate a relationship involving z.
  • Some participants question the application of the binomial product formula and suggest that Bob's initial formulation does not align with the theorem he referenced.
  • There is a discussion about the nature of z as a root of unity, with some participants asserting that multiplying the equation by (z - 1) leads to z^5 = 1.
  • Bob introduces a second equation, z^8 + z^6 + z^4 + z^2 + 1 = 0, and expresses confusion about how to manipulate it similarly to the first equation.
  • Some participants suggest that the second equation can be treated as a polynomial in z^2, while others clarify that z^2 is not a root of the polynomial.
  • There are differing opinions on whether dividing or multiplying by z^2 is a valid approach, with some participants indicating that it complicates the problem.
  • Participants explore the transformation of the second polynomial into a form that can be analyzed using the properties of roots of unity.
Participants generally do not reach a consensus on the best approach to manipulate the second polynomial equation. There are competing views on the validity of certain mathematical operations and the implications of treating z^2 as a variable in the context of the equations.
Some participants note that the equations involve geometric progressions and emphasize the need to clarify the relationships between the variables involved. There is also mention of unresolved steps in the manipulation of the equations.
Bob19
Hello
I'm suppose to show
Given z^4 + z^3 + z^2 + z + 1 = 0 where
[tex]z = cos(\frac{2 \pi}{5}) + i sin(\frac{2 \pi}{5})[/tex]
by using the binomial product formula.
r^n - s^n
Is that then
if r,s = z then z^4 - z^4 = 0 ?
Sincerely and Best Regards
Bob
i don't see any binomial product formula in your post, i just see r^n-s^n, surely that should equal something...?
Theorem
[tex]r^n - s^n = (r-s) \sum_{j=0} ^{n-1} r^{j} s^{n-j-1}[/tex]
where r,s are numbers in the Ring R and n is a natural number.
I'm presented with the following polymial
z^4 + z^3 + z^2 + z +1 = 0
where [tex]z = cos(\frac{2 \pi}{5}) + i sin(\frac{2 \pi}{5})[/tex]
To show the above I'm told to use the theorem:
Do this then imply that
z^4 - z^4 = (z-1)(z^4 + z^3 + z^2 + z +1) = 0
/Bob
Bob19 said:
Hello
I'm suppose to show
r^n - s^n
Is that then
Bob
Yes, it is certainly the case that z^4- z^4= 0 no matter what z is!
But, also certainly, that is not the question you intended to ask.
It is true that r^n- s^n= (r- s)(r^(n-1)+ r^(n-2)s+ ...+ rs^(n-1)+ s^(n-1). (Although that is not what I would call the "binomial product formula.)
So if z^4 + z^3 + z^2 + z + 1 = 0, multiplying both sides by z-1,
z^5- 1= 0 ro z^5= 1 and so z is a "root of unity". Was that what you intended?
Bob19 said:
Theorem
good, now how can you get z^4+z^3+z^2+z+1 into a formula like that? setting r=z will help, now what about a choice for r?
[/quote]where [tex]z = cos(\frac{2 \pi}{5}) + i sin(\frac{2 \pi}{5})[/tex]
/Bob[/QUOTE]
the fact that z^4=z^4 implies that z^4-z^4=0.
your last line of maths is not an example of the binomial product formula
Hello Hall,
it is that thank Yoy :smile:
But there is a second equation which has caused me some trouble too:
z^8 + z ^ 6+ z^4 + z^2 +1 = 0
z is the same as in the first one, but how I get i simular result as in the first one? If I multiply left and right by (z-1). I don't get an equation on the form z^n = 1.
Any idears on how I solve this one?
Sincerley
Bob
all of the powers of z are even, aren't they,so it really is an equation in z^2,m isn't it?
yes but if I divide the equation with z^2 I get
z^4 + z ^ 3 + z ^2 + z + 1/z^2 = 0
how do You get z^ 2 from that?
Sincerely
Bob
Firstly dividing by z^2 won't help, and secondly, even if you did divide by z^2 that isn't the result.
Okay I misunderstood
I have now multiplied it by (z^(2) -1) and got
z^16 + z ^12 - 1 = 0 or z^16 + z^12 = 1
Am I on the right track now ?
Sincerley
Bob
why are you making it more complicated? when i said it was a polynomial in z^2 what did I mean by that?
Also, you're starting from the answer. you should not equate z^8+z^6+z^4+z^2+1 to zero to begin with since that is what you are trying to show.
let's use some different letters.
if i write
a^4+a^3+a^2+a+1
and
b^8+b^6+b^4+b^2+1
can you see a simple way to transform the second quantity into the first?
You meant that z^2 is a root for the polynomial ?
thereby (z^2)^4 + (z^2)^3 + (z^2)^2 +1 = 0
/Bob
if i write
a^4+a^3+a^2+a+1
and
b^8+b^6+b^4+b^2+1
z^2 is not a root of the polynomial, though two things are being conflated there. but you managed to get the correct notion about making it a polynomial in z^2
If I don't divide or multiply by z^2 and z^2 is not a root of the polynomial, how in God's name is it transformed into z^2 = 0 ??
The only way I can see that is
z^8 + z^6 + z^4 + z^2 +1 = z^8 + z^ 6 + z^4 + 1
and then get z^2 = 0
Sincerely
Bob
who said it was transformed into that?
you know that
w^4+w^3+w^2+w+1= (w^5-1)/(w-1)
that was the first thing you proved.
and you know that w=z^2 gives what you want to examine. and you know that z is a fifth root of unity.
incidentally, you do realize these are just geometric progressions?
Hi Matt and thank You,
Sorry that I have been slow to understand your surgestions.
Following the first equation,
then the second eqaution:
z^8 + z^6 + z^4 + z^2 +1 = (z^10 + z^8 + z^6 + z^4 + z^2)/(z^2)
Am I on the right path now?
Sincerely and Best Regards,
Bob
you know that
