Newton's Third Law: Two Blocks Situation 1 & 2
The discussion focuses on the application of Newton's Third Law in a two-block system under different friction conditions. In Situation 1, the purple block remains stationary on the green block due to static friction, resulting in a net force on the green block equal to the applied force F plus the static friction force. In Situation 2, when kinetic friction takes over, the net force on the green block is the applied force F minus the kinetic friction force acting on the purple block. The interaction between the blocks demonstrates that the friction forces are equal and opposite, confirming Newton's Third Law.
  • Understanding of Newton's Third Law of Motion
  • Knowledge of static and kinetic friction concepts
  • Basic principles of force and motion
  • Familiarity with free-body diagrams
  • Study free-body diagrams for multi-body systems
  • Explore the coefficients of static and kinetic friction
  • Learn about the effects of friction on motion in physics
  • Investigate real-world applications of Newton's laws in engineering
Physics students, educators, and anyone interested in understanding the dynamics of forces and friction in multi-body systems.
Lisa...
Two blocks standing on oneanother are pulled with a force F. There's friction between them. With a certain force F the purple block is standing still on the green one (situation 1) because of static friction. Is the netto force working on the green block F+ static friction of the purple block (because Newtons third law implies the static friction on the purple block= the opposite static friction of the purple block on the green block)?
http://img363.imageshack.us/img363/3448/situations9qp.gif
And in the second situation the static friction is overcome and replaced by kinetic friction. Is the netto force working on the green block now F- kinetic friction of the purple block (again thanks to Newtons third law)?
When the purple block does not move - there is no work done by the purple on the green block (static situtation, whereas as work is a product of force and distance). However, the purple block adds its weight to the green block, and if friction is involved between the green block and supporting surface, that is where the weight of the purple block will be manifest, i.e the friction depends on the combined weights of the purple and green blocks.
In the second situation, the Fk acts on the purple block accelerating it to the right, but it acts oppositely on the green block, opposing the motion of the green block. Again, friction between the green block and its supporting surface would still involve the combined weight of the purple and green block.
I don't understand how you've drawn your arrows representing the friction force between the blocks. Since the friction arrows are on the top block, I assume you mean to show the friction acting on that top block. If so, those friction arrows should point to the right in both cases.
And, from Newton's 3rd law, you realize that the top and bottom blocks will exert equal and opposite friction forces on each other. Thus the friction that the top block exerts on the bottom block will be to the left in both cases.
  • · Replies 45 ·
