Proving continuity of two-variable function
The discussion centers on determining the continuity of the two-variable function defined as f(x,y) = (xy³)/(x²+y⁴) - 2x + 3y for (x,y) ≠ (0,0) and f(0,0) = 0. The limit as (x,y) approaches (0,0) is evaluated using polar coordinates, leading to the conclusion that the limit is zero as r approaches zero, regardless of the angle φ. The participants confirm that once simplified, the limit indeed approaches zero, establishing continuity at the origin.
  • Understanding of two-variable limits in calculus
  • Familiarity with polar coordinates conversion
  • Knowledge of continuity in multivariable functions
  • Basic algebraic manipulation of limits
  • Study the concept of continuity in multivariable calculus
  • Learn about polar coordinates and their application in limits
  • Explore advanced limit techniques for two-variable functions
  • Investigate the epsilon-delta definition of continuity
Students of calculus, mathematicians, and educators seeking to deepen their understanding of continuity in multivariable functions and limit evaluation techniques.
twoflower
Hello to everybody.
Yesterday we wrote a fake test, in which I encountered problem I haven't benn able to solve so far.
The problem is given this way:
Let
[tex] f(x,y) := \left\{\begin{array}{cc}\frac{xy^3}{x^2+y^4} - 2x + 3y,&[x,y] \neq [0,0]\\0, &[x,y] = [0,0]\end{array}\right.[/tex]
Find out, whether the function [itex]f[/tex] in point [0,0] is continuous[/itex][itex] <br /> Well, to be continuous in origin, it has to have zero limit as [x,y] approaches [0,0].<br /> <br /> I get<br /> <br /> [tex] \lim_{[x,y] \rightarrow [0,0]} \frac{xy^3}{x^2+y^4} - 2x + 3y[/tex]<br /> <br /> after converting to polar coordinates (which proved to be very useful when limiting two-variable functions) I have<br /> <br /> [tex] \lim_{r \rightarrow 0} \frac{r^4\cos \varphi \sin^3 \varphi}{r^2\cos^2 \varphi\ +\ r^4\sin^4 \varphi}\ -\ 2\lim_{r \rightarrow 0} r\cos \varphi\ +\ 3\lim_{r \rightarrow 0} r\sin \varphi = \lim_{r \rightarrow 0} r\cos\varphi \sin^3 \varphi\ \frac{r}{\cos^2 \varphi\ +\ r^2 \sin^4 \varphi}[/tex]<br /> <br /> The first part goes to zero so it would be sufficient to show that the second part is bounded. And that's where I got stuck. <br /> <br /> Horse sense tells me this: if [itex]\varphi[/itex] is such that [itex]\varphi[/itex] is non-zero, the whole limit is zero. If [itex]\cos \varphi[/itex] is zero, then the limit is still zero...but I'm not sure of this and definitely it's not an acceptable mathematical solution. But I'm unable to prove this elegantly at this point...<br /> <br /> Thank you very much for pointing me to the right direction.[/itex]
after you convert to polar and simplify all you have to do is find the limit as r goes to zero, phi can do anything. when r goes to zero your limit is zero.
Are you sure? Can it be so easily seen? I still have some doubts...
And one more question, can you see some further simplification there?
  • · Replies 40 ·
