Two blocks and pulley systemhelp on small part
The problem involves a pulley system with two blocks, one resting on a table and the other hanging. The setup includes a block of mass m1 on a table with friction, a block of mass m3 hanging, and a pulley with mass m2. Participants are exploring the dynamics of the system, including forces, tensions, and acceleration.
  • Mixed
  • Participants discuss the equations of motion for each mass, including forces in both the horizontal and vertical directions. There is a focus on the torque equation for the pulley and the relationships between tensions and acceleration. Questions arise regarding the correctness of the equations and sign conventions used.
Some participants have provided guidance on correcting torque direction and sign conventions. There is ongoing exploration of the equations, with one participant noting a discrepancy in the calculated acceleration. The discussion reflects a collaborative effort to clarify the problem setup and equations.
Participants are working under the constraints of a homework assignment, which may limit the information they can share or the methods they can use. There is an emphasis on ensuring consistent sign conventions throughout the equations.
Juntao
You got to see the picture 1st.
A block of mass m1 = 2 kg rests on a table with which it has a coefficient of friction µ = 0.66. A string attached to the block passes over a pulley to a block of mass m3 = 4 kg. The pulley is a uniform disk of mass m2 = 0.5 kg and radius 15 cm. As the mass m3 falls, the string does not slip on the pulley.
a) With what acceleration does the mass m3 fall?
b) What is the tension in the horizontal string, T1?
c) What is the tension in the vertical string, T3?
Okay, shouldn't be that HARD of a problem. But this is what I've done so far.
mass 1 (right is positive)
Summation of forces in x direction
T1-u*m1*g=m1a
Summation of forces in y direction
N-m1g=0
N=m1g
mass 3 (up is positive)
T3-m3*g=m3*a
My biggest question is the following equation correct:
mass 2
(T1-T3)R=I*alpha
simplifies to
(T1-T3)R=.5*m2*R^2*(a/R)
or
(T1-T3)=.5*m2*a => is this right for mass 2 for net torque
From here I manipulated the equations until I got a=...
This is what I have so far, but I'm not getting the acceleration value right, unless I made an algebra error.
But the equations look right so far, right?
It looks like you've got your torque acting in the wrong direction. Try
[tex]\tau_{net}=T_3r-T_1r[/tex]
as your torque formula instead.
Ok, I did what NateTG said, and it gave me a different accerlation of -15.008 m/sec^2 for m3. But its not the right answer. Was there something else I'm supposed to do?
To avoid premature insanity, pick a consistent set of sign conventions. You know that m1 moves to the right, the pulley moves clockwise, and m3 goes down. So... use those directions as the positive direction in all your equations.
The way you currently wrote your equations, what you call "a" in one equation equals "-a" in another. Yikes!
Thanks for the tip DocAl! I figured out the answer. Yes!
I learn something new everytime I post here. :smile:
  • · Replies 34 ·
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 102 ·
9K
