Question involving Uncertainty Principle.
The discussion focuses on applying the uncertainty principle to estimate the range of the strong interaction through pion exchange, specifically a pion with a rest mass of 140 GeV. The uncertainty principle states that ΔT x ΔE ≥ ħ, where ħ is given as 4.14 x 10^-21 MeV s. The participant struggles with deriving the range (ΔX) after calculating ΔT, considering methods involving kinetic energy and momentum. The lifespan of pions, approximately 2.6 x 10^-8 seconds, is relevant for determining the time of exchange, which can be related to the range of the strong force.
  • Understanding of the uncertainty principle in quantum mechanics
  • Basic knowledge of particle physics, specifically pions and their properties
  • Familiarity with Einstein's mass-energy equivalence (E = mc²)
  • Concept of wave functions in quantum mechanics
  • Research the derivation of Yukawa's potential related to the strong force
  • Study the relationship between energy and momentum for relativistic particles
  • Learn about the properties and calculations involving pions in particle physics
  • Explore advanced applications of the uncertainty principle in quantum field theory
Students and researchers in particle physics, particularly those studying quantum mechanics and the strong interaction, as well as educators looking to clarify concepts related to the uncertainty principle and particle exchange processes.
brat-sampson
Using the uncertainty principle for energy and time, estimate the range of the Strong interaction if it is due to the exchange of a pion with rest mass 140GeV (Take the value of h as 4.14x10^-21MeV s)
Now I know that Delta T x Delta E is > or = to hbar
and that I want DeltaX as a solution. But after having worked out DeltaT using basic algebra it's hard to know where to go. Should I head with E = 1/2 mv^2 to get the velocity then use speed x time to get distance? If so how do I find the mass of a pion? Or I could try and get the momentum but encounter similar problems.
If there's a simple way using the wave function then I might not know it as I really wasn't sure about that lecture and am working on finding out more.
Any help appreciated, thanks.
pions have a lifespan of 2.6x10^-8 seconds. Does that help?
Your lecturer is probably asking you to derive something similar to what Yukawa originally postulated regarding the strong force. Your approach seems to be backwards however. At that time, they didn't know the mass of this once non-existant particle. The answer can be verified, as this 'range' is approximatey the size of atomic nuclei. If we assume that the pion can travel near the speed of light, then the time it would take to exchange would be:
[tex]\Delta t = \frac{r}{c}[/tex]
For some r (range) you don't know. You can then relate this to an uncertainty in energy using the uncertainty principle. Subsequently, relate this to an uncertainty in mass using what else other than Einstein's famous [tex]E = mc^2[/tex]
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 32 ·
