Calculating mass of an isotope
by enternaL
Tags: isotope, mass
enternaL
enternaL is offline
#1
Nov29-05, 09:44 PM
P: 2
I'm trying to find the mass of a given isotope in terms of amu. The isotope is [latex] ^{210}_{84} Po [/latex], which has a mass of 209.98285u.
I've tried 84(1.007276u) + 126(1.008665u)
thinking that #protons(proton mass in amu) + #neutrons(neutron mass in amu) = mass in amu, give or take.
Can anyone help?
Phys.Org News Partner Science news on Phys.org
NASA's space station Robonaut finally getting legs
Free the seed: OSSI nurtures growing plants without patent barriers
Going nuts? Turkey looks to pistachios to heat new eco-city
mrjeffy321
mrjeffy321 is offline
#2
Nov29-05, 09:54 PM
Sci Advisor
P: 882
The mass your using, 209.982 amu, is the average atomic mass. This means that, on average, taking all the isotopes and thier abundances into account, a sample of Polonium will have a mass of 209.982 g/mol.
But isotopes have whole number masses (you cant have parts of a proton or neutron). The form in which you wrote the isotope gives you the answer,
means that the isotope has a mass of 210 gram/mol and an atomic number of 84.
enternaL
enternaL is offline
#3
Nov29-05, 10:13 PM
P: 2
That makes sense. So, how would I get any given isotope's average atomic mass?
mrjeffy321
#4
Nov29-05, 10:43 PM
Sci Advisor
P: 882
elements have an average atomic mass, not isotopes. There maybe several isotopes of a certain element, each isotope having its own, whole-numbered, mass. When you do a weighted average based on the abundance of the isotope, you can get the average atomic mass of the element.
To get the mass of an isotope, just add the protons and neutrons together.
tauceti
tauceti is offline
#5
Apr10-11, 03:44 PM
P: 3
Actually, it is not 210 g/mol.
Its more like 209.98 g/mol. Isotopes doesen't have whole mole mass numbers.
http://www.wolframalpha.com/input/?i=Polonium+210
ehild
ehild is offline
#6
Apr10-11, 04:36 PM
HW Helper
Thanks
P: 9,818
The mass of a nucleus is smaller than the sum of the masses of its free constituents, because of the binding energy.
ehild
tauceti
tauceti is offline
#7
Apr10-11, 04:57 PM
P: 3
Quote Quote by ehild View Post
ehild
But if you sum up the weight of every particle you would get: 126*(1.008664u) + 84*(1.007276u) = 211,702848 u
Greater, not equal to 210.
ehild
ehild is offline
#8
Apr10-11, 11:30 PM
HW Helper
Thanks
P: 9,818
I think you need to convert the mass in amu to kg-s, don't you?
ehild
tauceti
tauceti is offline
#9
Apr10-11, 11:45 PM
P: 3
They are the same, 1 amu = 1 g/mol
ehild
ehild is offline
#10
Apr10-11, 11:59 PM
HW Helper
Thanks
P: 9,818
The unified mass unit is unit for mass and converts to kg in the SI system. 1 amu = 0.001/NA kg = 1.660538782 * 10-27 kg.
ehild
I like Serena
I like Serena is offline
#11
Apr11-11, 02:22 AM
HW Helper
I like Serena's Avatar
P: 6,189
From: http://en.wikipedia.org/wiki/Binding_energy#Mass_excess
Quote Quote by Wikipedia
It is observed experimentally that the mass of the nucleus is smaller than the number of nucleons each counted with a mass of 1 a.m.u.. This difference is called mass excess.
The difference between the actual mass of the nucleus measured in atomic mass units and the number of nucleons is called mass excess i.e.
Mass excess = M - A = Excess-energy / c2
with : M equals the actual mass of the nucleus, in u.
and : A equals the mass number.
This mass excess is a practical value calculated from experimentally measured nucleon masses and stored in nuclear databases. For middle-weight nuclides this value is negative in contrast to the mass defect which is never negative for any nuclide.
Apparently, to find the exact atomic mass in amu, you have to look it up in a table with experimental results.
Register to reply
Related Discussions
Determining mass of isotope Advanced Physics Homework 10
lab-calculating mass Introductory Physics Homework 1
One isotope of a metallic element has mass number 59 and 31 neutrons in the nucleus. Biology, Chemistry & Other Homework 1
Atomic mass: Isotope question Chemistry 3
calculating mass Introductory Physics Homework 2
