What Distinguishes Photons from Gluons Despite Their Similar Properties?
  • Context: Graduate
  • Thread starter Thread starter taylordnz
    Gluons Photons
The discussion centers around the distinctions between photons and gluons, focusing on their properties, interactions, and the implications of these differences within the context of quantum field theory. Participants explore theoretical aspects, interactions mediated by these particles, and related concepts such as positronium and glueballs.
  • Some participants note that both photons and gluons are massless and have spin 1, serving as mediators of interactions, but differ in the types of interactions they mediate (electromagnetic vs. strong).
  • It is mentioned that photons do not interact directly with each other, while gluons can interact directly due to their "strong" charge, leading to self-interactions.
  • A participant describes a process where two high-energy photons can produce an electron-positron pair near a massive nucleus, suggesting this interaction is mediated by the electromagnetic force.
  • Another participant clarifies that the interaction between photons involves intermediate states and does not constitute a direct interaction, referencing Feynman diagrams to illustrate this point.
  • Questions arise regarding glueball interactions and the availability of Feynman diagrams for gluon-gluon interactions, with some participants noting the complexity of these diagrams.
  • Participants discuss the concept of positronium as a bound state of an electron and a positron, contrasting it with the absence of bound states for photons.
  • References to literature on quantum chromodynamics (QCD) and Feynman diagrams for gluon interactions are made, indicating the complexity and difficulty in finding such diagrams in common resources.
Participants express differing views on the nature of interactions between photons and gluons, with some asserting that photons do not interact directly while others provide examples of photon interactions through intermediate states. The discussion remains unresolved regarding the specifics of gluon interactions and the availability of relevant diagrams.
Participants acknowledge the complexity of Feynman diagrams for gluon interactions and the potential limitations in available literature on the topic. There is also mention of the speculative nature of future scenarios involving positronium and dark matter.
taylordnz
photons and gluons have the same mass, charge, width and GeV?
so what tells them apart?
The main things in common between photons and gluons are that they are both massless (rest mass = 0), they have both spin 1 and are both carrier (or mediator) of interractions.
The main differences are that the photons mediate the electromagnetic interraction while the gluons mediate the strong interraction. One major difference is that although the photon mediates the electromagnetic interraction, its electric charge is zero, so that there is no electromagnetic interraction between 2 photons. However, gluons mediate the strong interraction and the have a "strong" charge (called color). So that gluons interract among themselves.
1100f said: there is no electromagnetic interraction between 2 photons
But, two photons in the gamma range of frequencies, having sufficient total energy and getting close to each other near a massive nucleus, change into an electron and a positron. The sufficiency of total energy means enough total energy to produce the total energy of the two charged particles. Any excess energy becomes the total kinetic energy of the particles. This happens in nuclear experiments all the time. In a bubble-chamber photograph, in the vicinity of a magnetic field, this pair shows up as a pair of back-to-back spirals coming from the point where the charged particles were produced.
This reaction is evidently done by the electromagnetic force. The production of electron-positron pairs figures into quantum electrodynamic calculations. In this case, the two particles don't separate, but just turn right back into gamma ray photons again.
This reaction is evidently done by the electromagnetic force. The production of electron-positron pairs figures into quantum electrodynamic calculations. In this case, the two particles don't separate, but just turn right back into gamma ray photons again. [/B]
What you describe here is not a direct interraction between two photons but an interraction between photons by intermediate states.
When I said that there is no interraction between photons, I meant that you do not have any vertex that includes just photons. And if you look at the lowest order at which an interraction between two photons occur, the Feynman diagram will look as follows: (I tried to draw the diagram but I didn't succeed, so I will describe the diagram) Draw a square and at each corner of the sq2uare, draw a photon. Each line in the square represents an electron (positron).We see that we have at the lowest order, 4 vertices. So that the cross section of the photon-photon scattering will be proportional to e^2 at the fourth power. So that this process will be highly suppressed.
On the contrary, for gluons, you have vertices containing only gluons (3 or 4). So we see that gluons have a direct interractions among them.
Would that be glueball interactions, for example? It is hard to find Feynman diagrams for gluon-gluon interactions outside of (maybe) some hairy research reports. There is certainly nothing like that with photons.
A glueball will act a lot like a meson. The vertices with multiple gluons are not glueballs, unless two or more of the gluons are co-confined before leaving the box in the Feynman diagram.
For photons, you will not see bound states of photons with other photons, but there are positronium bound states that can exist. That's the closest you can get to glueballs in a QED analogy.
Positronium - I forgot about that. Thanks.
Positronium... *jogs memory* isn't that the state in which an electron orbits a positron for a very short amount of time?
Correct. A very, very short period of time.
Except in the far, far distant future, where electrons and positrons are all that's left (all black holes have evaporated, all protons have decayed), and they orbit each other at a distance of approx 15 billion light-years
Of course, we may learn something about dark matter or dark energy that renders this somewhat bleak picture invalid. :wink:
Tarrach's book on practical QCD surely has some.
There is a really good, but old, book called "Introduction to Quarks and Partons" that has quite a few diagrams you won't find in many other places. Feynman diagrams for gluon-gluon interactions can indeed get really hairy, i.e. multi-gluon vertices and such.
In any book on QFT, go to the QCD section, after the Lagrangian is written, the Feynman rules are given, including the Feynman rules for gluon-gluon vertex.
  • · Replies 17 ·
