Using an identity to find the sum to n terms of a series
The discussion revolves around using a specific identity to find the sum of the series \(\sum_{r=1}^n r(r+1)\). Participants are exploring the relationship between the identity \((r+1)^3 - r^3 \equiv 3r^2 + 3r + 1\) and the series in question.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the potential to use a telescoping series and the implications of simplifying the series into separate sums. There is also a focus on how to apply the given identity effectively.
Some participants have offered rearrangements of the identity and suggested methods for approaching the sum, while others express uncertainty about the necessity of using the identity versus simpler methods. Multiple interpretations of how to proceed are being explored.
There is a mention of homework constraints that may limit the methods allowed, specifically the requirement to use the identity provided in the problem statement.
mr bob
Just working through my FP1 book and have got stuck on a question.
Use the identity [itex](r+1)^3 - r^3 \equiv3r^2 + 3r + 1[/itex]
to find [itex]\sum\limits_{r = 1}^n r(r+1)[/itex]
I've tried using the method of differences to get [itex]n^3 + 3n^2 + 3n[/itex], but can't see how to get it back into its original form, not sure how the identity corresponds to r(r+1).
at a glance, i would say that you need to find a telescoping series somewhere.
wait, so youre not allowed to simplify it to the sum of r^2 + r? because then you change just separate it to the sum of the first n r^2 plus the first n of r. which should give (n)(n+1)(2n+1)/6 + (n)(n+1)/2.
this is what i see.
I could simplify it, but the question asks to use the identity. I am not sure how to use that with that series. Although splitting it down into its standard results would be a lot easier.
rearrange the identity like this,
3r(r+1) = (r+1)^3 - r^3 - 1
Then
Sigma r(r+1) = (1/3) Sigma {(r+1)^3 - r^3 - 1}
Now use the http://thesaurus.maths.org/mmkb/entry.html?action=entryById&id=3935" in the rhs (right hand side) and simplify.
It would be a lot simpler doing it the other way though, like hypermonkey suggested.
Why would you ever want to use the sum of cubes formula for that sum?
Alright I made it shorter; so here is what you need to show
[tex]\sum_{k=1}^{n-1} (k + 1)^{3} - k^{3} = \sum_{k=1}^{n-1} 3k^{2} + 3k + 1[/tex]
[tex]{\left(\sum_{k=1}^{n} k^{3}\right)} - 1 -\left(\left({\sum_{k=1}^{n} k^{3}}\right) - n^{3}\right) = \sum_{k=1}^{n-1} 3k^{2} + 3k + 1[/tex]
[tex]\sum_{k=1}^{n-1} 3k^{2} + 3k + 1 = n^{3} - 1[/tex]
[tex]3\sum_{k=1}^{n-1}k^{2} + 3\sum_{k=1}^{n-1}k + n - 1 = n^{3} - 1[/tex]
[tex]; 3\sum_{k=1}^{n-1}k = \frac{3n(n-1)}{2}[/tex]
[tex]3\sum_{k=1}^{n-1}k^{2} + \frac{3n(n-1)}{2}= n^{3} - n[/tex]
[tex]3\sum_{k=1}^{n}k^{2} + \frac{3(n+1)(n)}{2}= (n+1)^{3} - (n+1)[/tex]
[tex]3\sum_{k=1}^{n}k^{2} = \frac{n(n+1)(2n + 1)}{2}[/tex]
[tex]\sum_{k=1}^{n}k^{2} = \frac{n(n+1)(2n + 1)}{6}[/tex]
Then knowing that [tex]\sum_{k=1}^{n}k = \frac{n(n+1)}{2}[/tex]
[tex]\sum_{k=1}^{n}k^{2} + k = \frac{n(n+1)(2n + 1)}{6} + \frac{n(n+1)}{2}[/tex]
This simplifies down a bit further to,
[tex]\sum_{k=1}^{n}k^{2} + k = \frac{n(n+1)(n + 2)}{3}[/tex]
