Is there a constant value for b in b^x (ln b) = a^x for any x?
  • Context: Undergrad
  • Thread starter Thread starter Werg22
    Constant
The discussion revolves around the possibility of finding a constant value for b in the equation b^{x}(\ln b) = a^x for any value of x, exploring the relationship between b and a, and the implications for various values of a.
  • One participant questions whether a constant value for b can be determined for any x in the equation b^{x}(\ln b) = a^x.
  • Another participant asks for clarification on the nature of a, suggesting it may depend on the field of numbers being considered.
  • It is proposed that a can be any value, leading to the inquiry of how b relates to a independently of x.
  • A mathematical manipulation is presented, leading to the conclusion that for the equality to hold independently of x, a must equal b, specifically when both are equal to 1.
  • One participant challenges the mathematical steps of another, pointing out a potential error in the logarithmic transformation.
  • Further analysis suggests that if a and b are not equal, the equality cannot hold for all x, leading to the conclusion that a must equal b and both must equal e for a unique solution.
  • A question is raised regarding the existence of an integral function for a^x if a is not equal to e.
  • A clarification is provided regarding the anti-derivative of a^x, confirming that it exists regardless of whether a equals e.
Participants express differing views on the conditions under which the equality holds, with some proposing specific values for a and b while others challenge the mathematical reasoning. The discussion remains unresolved regarding the generality of the findings.
The discussion includes assumptions about the nature of a and b, particularly their domains within real numbers, and the implications of logarithmic properties. There are unresolved mathematical steps and dependencies on specific values that are not fully explored.
Werg22
Is it possible to find a constant value for b in the following equality for any value of x?
[tex]b^{x}(\ln b) = a^x[/tex]
what is a? Is it given? If so, in what field is it an element.
a can be any value, so the real question is to find b in relationship to a, independantly of x.
Since you didn't answer the question "in what field is it an element?" I assume this is in the real numbers.
Taking ln of both sides:
[tex]ln(b^x ln b)= ln b^x + ln b= xln b+ ln b= x ln a[/tex]
so
[tex]x(ln a- ln b)= x ln\frac{a}{b}= ln b[/tex]
That will be "independent of x" if and only if
[tex]ln \frac{a}{b}= 0[/tex]
or
a= b= 1.
I think you made a mistake
You're development:
[tex]\ln(b^x \ln b)= \ln b^x + \ln b[/tex]
When it should be
[tex]\ln(b^x \ln b)= \ln b^x + \ln(\ln b)[/tex]
Suppose [tex]a,b\in\mathbb{R}^+[/tex]. If [tex]b^x\ln b=a^x[/tex] then we have
[tex]x\ln b+\ln\ln b=x\ln a[/tex]
or
[tex]\ln\ln b=x(\ln a-\ln b)[/tex].
If [tex]a\neq b[/tex] then this will not hold for all [tex]x\in\mathbb{R}[/tex]. Then we have a=b and [tex]\ln\ln b=0[/tex]. This means the unique solution is [tex]a=b=e[/tex].
Does that mean that the function a^x has no integral function if a is not equal to e?
[tex]a^x= e^{ln a^x}= e^{x ln a}[/tex]
so the anti-derivative (I guess that's what you mean by "integral function") is
[tex]\frac{e^{x ln a}}{ln a}= \frac{a^x}{ln a}[/itex].<br /> <br /> Yes, werg22. Thanks for the correction.[/tex]
