Rocket Sled Motion Equation and Free Response Models | Question Check
The discussion revolves around the motion of a rocket sled described by a differential equation. Participants are analyzing the sled's motion to determine the time required to travel a specific distance and exploring the free response of a related model.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants are attempting to solve a differential equation for the sled's motion and are questioning the validity of their approaches. Some are integrating to find velocity and position, while others are considering different methods to derive expressions for motion.
Multiple interpretations of the problem are being explored, with participants providing different approaches to solving the equations. Some guidance has been offered regarding the need to maintain variables instead of setting them to zero prematurely, and there is a recognition of the need for clarity in the initial conditions.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. There is an emphasis on ensuring that assumptions about initial conditions and variable definitions are clearly understood.
mpm
Ive got 2 questions that I would like looked at.
Question 1:
A rocket sled has the following equation of motion: 6vdot = 2700 - 24*v. How long must the rock fire before the sled travels 2000 m? The sled starts from rest.
I took the integral which of that equation which gamve me v(t) = 2700*t - 24*x. At rest v = 0. So 0 = 2700t - 24*(2000)
Solve for t and you get t = 17.78 seconds.
Does this look right? If not please let me know.
Question 2:
For each of the following models, obtain the free response and time constants if any.
16*xdot + 14*x = 0, x(0) = 6
I changed it to v's, which gave me 16*v + 14*vdot = 0, v(0) = 6
For time constant its c/m so tau = 14/16 = .875
Then for the free response its v(t) = v(0)*e^-t/tau
So for my final answer, v(t) = 6*e^-1.143*t
If there are any problems with this, can you please let me know where.
I just want to make sure I am doing this right.
Question 1:
The question says that the sled starts from rest, not that it is at rest after it has traveled 2000m.
So I should have a variable still I guess for my v(t) instead of setting it to equal 0. Can you give me an idea of what it might equal?
I would go with another approach entirely: Solve the differential equation for v, then integrate to get an expression for x(t) with no v terms.
I did it a different way for Problem 1.
I made the equation into 6*vdot + 24*v = 2700.
Then I solved for V(t) which is the free response and force response.
Since v(0) = 0, the free response goes away.
leaving v(t) = F/c(1-e^(-ct/m) = 2700/4*(1-e^-4t)
I then took the integral of that to get x(t).
This game me x(t) = (225*e^-4t*(4t*e^(4t)+1))/8
I then set x(t) = 2000. Solving for t I come up with 17.78 seconds which is what I originaly came up with the first time.
Was I just right the first time? Is this coincidental or did I do it wrong this time?
  • · Replies 175 ·
28K
