Gravitional Potential Energy and Mass of Earth
The discussion revolves around gravitational potential energy, specifically comparing two equations for calculating changes in gravitational potential energy (U) of a mass (m) in relation to the Earth. The original poster presents a problem from a physics textbook that requires finding the height at which the simpler equation (U=mgy) deviates from the more complex equation (U=GMm/r) by a certain percentage.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to derive an error formula using both gravitational potential energy equations and expresses confusion over the results obtained from their calculations. Participants question the correctness of the formulas being used, particularly regarding the squaring of terms and the setup of the equations.
Participants are actively engaging with the original poster's approach, providing feedback on the formulas used and suggesting corrections. There is an ongoing exploration of the mathematical setup, with no clear consensus yet on the correct method or outcome.
There is mention of a specific percentage error (1%) that needs to be accounted for in the calculations, as well as the requirement to express the height as a fraction of the Earth's radius. The original poster also notes an upcoming test, indicating a time constraint that may affect the discussion.
Tirokai
This question is 12.59 from University Physics 11e.
"There are two equations from which a change in the gravitational potential energy U of the system of mass m and the Earth can be calculated. One is U=mgy. The other is U=GMm/r (M=mass of earth). The first equation is correct only if the gravitational force is a constant over the change in height delta-y. THe second is always correct. Actually, the gravitational force is never exactly cosntant over any change in height, but if the variation is small, we can ignore it. Consider the difference in U between a mass at the Earth's surface and a distance h above it using both equations, and find the value of h for which mgy is in error by 1%. Express this value of h as a fraction of the Earth's radius, and also obtain a numerical value for it."
The correct answer, from the rear of the book, is 0.01Re and 64 km.
My strategy, thus far, was to use the two gravitational potential energy formulae in an error formula. So I tried several different variations on (mgh-(-GMm/(Re+h)^2+Gmm/(Re)^2))/mgh=.01
Re= radius of Earth M=mass of earth
Having set up the formula, I used the solve function of a TI-89 to punch them out, all of them eventually coming out to be some random number in the millions or tens of millions.
Any help is greatly appreciated :D
In your formula you are squaring the R, why? For potential energy you don't square the r... :(
You know what, I accidentally copied that from a formula someone else gave me (a physics major, too! shame on them) and so let me update the formula I used.
(mgh-((-GMm/Re+h)+(GMm/Re)))/(mgh)=.01
I simplified that down to
((gRe^2+GMe)h+(gRe)h^2)/((gRe^2)h+(gRe)h^2)=.01
Which gave me some bogus answer like -1.3x10^7
Thanks for the response, at any rate.
.01 = (mgh - accepted value)/accepted value
thats it... you have an idea how to find the accepted value i think so that shouldn't eba problem... but i still see those squares there... there shoudnt be squares anywhere... if I am wrong please prove me wrong because I've got a test on this and waves tomorrow (curses at waves) :P
