What Do You Do When A/B Forces Aren't Shown?
  • Thread starter Thread starter markow202
    Diagram
The discussion addresses a common issue in statics involving the calculation of shear and bending diagrams for a beam with unknown forces at supports A and B. Participants clarify that if a load is applied at the center of the beam, the reactions at supports A and B are equal, calculated as RA = W/2 and RB = W/2. If the load is offset, moments about either support must be taken to determine the reactions accurately. The absence of shown forces at A and B raises questions about the problem's validity in the context of statics.
  • Understanding of basic statics principles
  • Familiarity with shear and bending moment diagrams
  • Knowledge of calculating reactions at supports
  • Ability to apply the moment equilibrium equations
  • Study the principles of shear and bending moment diagrams in statics
  • Learn how to calculate reactions at supports for various loading conditions
  • Explore the concept of moment equilibrium and its applications
  • Practice solving statics problems involving beams with different load configurations
Students in engineering or physics courses, particularly those studying statics, as well as educators looking for examples of problem-solving techniques in structural analysis.
markow202
Hi everyone,
I have a problem question in my statics class and one problem askes to draw the shear and bending diagram for the problem.
It shows the beam ------------------------ with the reaction pushing down on the top/middle of it and A and B on each side but shows no forces pushing up on each side which I am stuck on.
A B
Every other example in the book shows forces pushing up on A/B but not the questions.
If it showed them I wouldn't be stuck...what do I have to do in this case?
Thanks so much!
Hint: If you wrap "code" tags around your "diagram" (in the post/editing area) then it will show up better.
Question:Is there a force (load) acting down in the middle of the beam AB ? Or is it slightly offset from the centre ?
If it's in the middle, then the reactions at A and B are: RA = W/2 and RB = W/2.
If it's slightly offset, then you will have to take moments about A, or B, to determine the exact value of RA and RB.
Well if there's a load on the beam and A and B are labeled but no forces are shown... there better be forces at A and B or this isn't statics my friend!
  • · Replies 35 ·
  • · Replies 25 ·
