Why Is a Complex Index of Refraction Necessary?
The discussion centers around the necessity and implications of using a complex index of refraction in various materials, particularly in the context of absorbing materials and lossy dielectrics. Participants explore theoretical and practical scenarios where the ordinary index of refraction may not suffice.
  • Some participants propose that complex indices of refraction are essential for describing absorbing materials, where the electric field's amplitude diminishes as it propagates.
  • One participant mentions that imperfect conductors exhibit a complex index of refraction, leading to phenomena such as skin depth.
  • Another example provided is that of dilute atomic vapors, which also have a complex index of refraction to account for light attenuation.
  • Concerns are raised about the applicability of complex versus real optical indices, particularly in the context of Snell-Descartes law, which yields different results depending on the index used.
  • Participants discuss the relationship between the optical index and dielectric function, questioning how to handle critical angles when the dielectric function is complex.
  • One participant asserts that adapting Snell's law to a complex index is straightforward using specific mathematical relationships.
Participants express differing views on the use of complex versus real indices of refraction, indicating that the discussion remains unresolved with multiple competing perspectives on the implications and applications of complex indices.
There are limitations in understanding the transition between complex and real indices, particularly regarding mathematical relationships and their physical interpretations. The discussion highlights unresolved questions about the application of these indices in various scenarios.
dimensionless
Why would one need to use a complex index of refraction? Are there circumstances in which the ordinary index of refraction breaks down? What are they?
Science news on Phys.org
Complex indices of refraction are used to describe absorbing materials where the electric field is diminished in amplitude as it propagates. For example, an imperfect conductor has a complex index of refraction which leads to the well known result that the field only penetrates to certain depth called the skin depth. More generally, there are a whole class of lossy dielectrics that have complex indices of refraction. A system like a dilute atomic vapor can also have a complex index of refraction where again it describes the attenuation of light that passes through the gas.
But it is rather hard to understand if we might use complex or real optical index sometimes... Examples:
1/ Snell-Descartes law in complex gives different results than with real indexes. So, which one is true ?
2/ Link between optical index and dielectric function. Usually, n=sqrt(epsilon). But epsilon is complex. Then index is complex. What about critical angle = arcsin(n2/n1), then ? arcsin(Re(sqrt(epsilon_2)/sqrt(epsilon_1)) ? Or Re(arcsin(sqrt(epsion_2)/sqrt(epsilon_1))) ? Different results.
There many relations like this, in which complex formulation makes everything harder to feel.
The imaginary part of the index of refraction corresponds to absorption (or gain). Adapting Snell's law (or any other relationship using the refractive index) to a complex index of refraction is straightforward by using the relationship sin(i*q) = i sinh(q) and cos(i*q) = cosh(q).
http://link.aip.org/link/ajpias/v44/i8/p786/s1
  • · Replies 33 ·
