What is the Mass of the Planet?
The discussion revolves around calculating the mass of a planet based on the gravitational forces acting on a space probe positioned between the planet and the sun. The problem involves understanding gravitational interactions and applying relevant equations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the gravitational force equation and its application to the problem. There are attempts to use Kepler's Third Law, which leads to confusion about the variables involved. Some participants suggest setting up equations based on the balance of forces acting on the probe.
Several participants are exploring different approaches to the problem, with some providing guidance on how to set up the equations correctly. There is an ongoing exchange of ideas, and while some calculations are presented, there is no explicit consensus on the correct method yet.
Participants question the assumptions regarding distances between the probe, planet, and sun, and whether certain simplifications can be made in their calculations. There is also mention of confusion regarding the application of gravitational force equations and Kepler's laws.
ConfusedStudent
Space probe, planet, and sun...
Correcting test again, and I don't know where to start on this problem:
A space prob lies along a line between a planet and the sun so that the sun's gravitational pull on the probe balances the planets pull. The distance of the probe from the planet is 1.0 x 10^11m. The distance between the planet and the sun is 1.5 x10^12m. Find the mass of the planet. Mass of the sun = 2x10^30kg.
I got 0/15 on this problem so nothing I put down was right...help?
Start with:
what is the equation for the gravitational force between two objects?
Fg = ?
F1,2=[(G *m1*m2)/(r1,2^2)]*r1,2
That's what it says in my book, it looks weird when you type it.
But I tried this problem another way, and tell me what you think:
I used t^2=Cr^3 compared to the Earth to get the period of the planet which I got was 6.53x10^15.
Then I used that in the eq:
T^2=(4*pie^2)/(G*Mp)*r^3
6.53x10^15m^2=(39.5)/(6.67x10^-11*Mp)*1.5x10^12m^3
and I got the mass to be 4.69x10^16 kg
Is this completely off??[?]
Yes, it's completely off. The M in that equation (Kepler's Third Law) is MS, not MP. It's the mass of the sun. You can't use that equation to find the mass of the planet.
But, back to the other equation, the last r1,2 that you see there has a little ^ on top of it, right? That is a unit vector to indicate the direction of the force. It has no effect on the magnitude of the force, which is all we're concerned with here (because here we know that the two forces act along the same line, in opposite directions).
So, leave off that last r.
Now
1. call the planet X, so it's mass is MX, and the distance from the sun to the planet is rSX and the distance from the planet to the probe is rXp. And let's call the mass of the probe Mp.
2. You know that FSp = FXp
3. Find rSp
4. Can you set up an equation for the two forces using
F = GM1M2/(r122)?
By the way, do you realize that r1,2 in the gravitational force equation is just the distance between the two objects?
(In other words, it is not the radius of the objects' orbits around the sun, which is what Kepler's equation is all about.)
I must really be dense, I've been looking at this screen for 15 min, I still don't get it. :frown:
The force of the sun on the probe equals the force of the planet on the probe. In other words (calling the Sun 1, the planet 2, and the probe 3):
F13 = F23
Now write what each force is using the gravity law:
FAB = G MAMB/(RAB)2
When you plug this into the first equation, G and M3 will cancel. You have the distances and the mass of the sun. The only variable left will be M2; solve for it.
Does this help at all?
Okay, this is what I got, and I hope it's right:
F(13)=F(23)
GM1M3/(R13^2)=GM2M3/(R23^2)
M1/(R13^2)=M2/(R23^2)
2x10^30/(1.4x10^12^2)=M2/(1.0x10^11^2)
M2= 1.02x10^28
Was it okay to assume the distance from the probe to the sun is the distance from the planet to the sun- the distance from planet to probe?
Yep.
Of course. I wouldn't call that an assumption; it's a given since they're all in a straight line.
Thank you so much...you're a life saver...
