Can the Dot Product of Electric and Magnetic Fields be Proven as Invariant?
The discussion centers on the invariance of the dot product of electric and magnetic fields within the framework of Einstein's Special Theory of Relativity. Participants explore whether this dot product remains unchanged across different relativistic frames of reference, considering both theoretical implications and practical calculations.
  • Homework-related
  • Some participants question the assumption that the dot product of electric and magnetic fields is invariant, suggesting it may not be true.
  • One participant proposes using the Faraday tensor to investigate the invariance of the dot product, indicating a belief that it may vary between frames.
  • Another participant mentions that the only quadratic invariants that can be constructed from electric and magnetic fields are the dot product and the expression E² - B².
  • There is a discussion about the appropriate mathematical contractions needed to derive invariants, with some participants correcting each other's understanding of the Levi-Civita tensor and metric contractions.
  • A participant shares a specific problem from an electromagnetic theory class that involves proving the invariance of the dot product and the quantity E² - c²B², while seeking guidance on calculating E and B in moving frames.
  • Concerns are raised about the treatment of current density and charge density in different frames, with some participants arguing about the implications of Lorentz contraction on these quantities.
Participants express differing views on whether the dot product of electric and magnetic fields is invariant, with some suggesting it may be while others remain skeptical. The discussion includes multiple competing perspectives and remains unresolved on this key question.
Participants note that the invariance of the dot product may depend on specific mathematical formulations and assumptions about the electric and magnetic fields, as well as the treatment of charge and current densities in relativistic frames.
Ed Quanta
If I were to attempt to prove that the dot product of an electric and magnetic field is invariant under the conditions of Einstein's Special Theory of Relativity, how would I do this? Would the proof be very involved and complicated? Or should I just use hypothetical magnetic and electric fields and demonstrate how the dot product is unchanged when dealing with relativistic frames of reference?
First of all, what makes you think that the dot product is invariant? I don't know for sure that it is not, but I would imagine that it is not. Did you hear or read this somewhere, or is this your own idea?
I would personally use the Faraday tensor (in fact, after I'm done typing, I will do this and see for myself if the dot product is invariant). It shouldn't be too complicated. I will just consider some arbitrary Faraday tensor, Lorentz transform it in an arbitrary direction at an arbitrary speed, extract the components for the E & H fields to calculate the dot products, and then compare the results. I have a feeling the dot product will be inconstent from one frame to the next.
Do you have formulas for how the field vectors change from one frame to the other?
Originally posted by Ambitwistor
[itex]\vec{E}\cdot\vec{B}[/itex] and [itex]E^2-B^2[/itex] are the only quadratic invariants you can build out of the electric and magnetic fields.
i didn t know this but it seems believable... basically, to get a lorentz scalar, we would have to contract [itex]F^{\mu\nu}F^{\rho\sigma}[/itex] with something. i think there are only two choices available [itex]\epsilon_{\mu\nu\rho\sigma}[/itex] and [itex]\eta_{\mu\rho}\eta_{\nu\sigma}[/itex]
the first choice will give you [itex]E^2-B^2[/itex] and the second [itex]E\cdot B[/itex] (i would imagine. i haven t checked it)
i had a question come up the other day... i was trying to remember the formula for the energy density in terms of the electromagnetic 2 form. i know the lagrangian is [itex]F\wedge*F=(E^2-B^2)\text{vol}[/itex], and since energy density is nearly the same thing, with a plus instead of a minus, i thought i could make a similar formula.
of course i was mistaken, energy density is not a lorentz covariant object, so there will be no way to write down the energy density from the field strength in a covariant way.
but can you write the stress energy tensor? i have seen the Noether formula for the stress energy tensor, but i was hoping for a concise formula from the field strength 2 form. i am suspecting that that doesn t exist either, since the stress tensor is symmetric...
As I started writing to work things out, things started to look like the dot product may be invariant. That does surprise me, given the way the magnetic field arises from the Faraday tensor. From my cursory inspection, though, I would rather have expected contraction with [itex]\epsilon_{\mu\nu\rho\sigma}[/itex] to give the dot product. I have:
[itex]E\cdot B[/itex] = (1/c)(F01F32 + F02F13 + F03F21).
(Sorry, I don't know how to make that math looking text.)
Anyway, there are clearly permutations of the indices that suggest nontrivial elements would arise only in the case of a permutation. Are you sure you have the appropriate contractions identified with the corresponding invariants?
That is certainly above my level. I still don't have a satisfactory understanding of what a Lagrangian is.
no, i had them backwards. you are correct... the Levi-Civita contraction gives the dot product, and the metric contraction gives the Lagrangian.
actually, i should have guess more cleverly. the lagrangian should be invariant under the full Lorentz group (i.e. parity transformations, as well as Lorentz rotations), whereas the dot product, since if involves a pseudovector, should transform nontrivially under parity transformations.
the Levi-Civita tensor reverses sign under parity transformations, so i should have been able to guess which is which...
silly me.
I was told to prove the following in my electromagnetic theory class:
1) that the dot product of E and B would be relatvistically invariant
2) that the quantity E^2 - c^2B^2 is relativistically invariant.
We will assume the two relativistic frames S and S' where x'1=x1, x'2=x2,x'3= j(x3-vt) where j = 1/(square root of 1 - B^2) where B= v/c, and t'=j(t-B/cx3).
When defining the electric and magnetic fields in relativistic frames, current density J and charge density p are not separable nor distinct since a static charge distribution in one frame of reference will be a current density in a moving frame.
In the static frame of reference S we will assume a charge density po in a certain volume, were the change in charge dq=po(dV). Thus in the moving frame of reference S', p=poj. This lorentz contraction and thus change of charge density only occurs in the x3 direction since this is the only dimension which is moving in relativistic frame S'. This is all the information we need to calculate E in the frame of reference S.
Since reference S is static, B=0 because there is no current density. So now we can define the current density J (in frame S' only) as (pu,icp) pu corresponds to the three spatial dimensions, while icp corresponds to the dimension of time. My question is this. How do we calculate E and B in the moving frame of reference S' so I can begin to take the dot products of E and B in both references and see if it is indeed invariant. Sorry if I was confusing or unclear.
I wouldn't do it this way.
It doesn't matter what direction; density is density.
Are you allowed to use the Faraday tensor? Just transform that, take the appropriate components, and compare dot products.
Ei = Fi0, cB1 = F32, cB2 = F13, cB3 = F21.
E'i = F'i0, cB'1 = F'32, cB'2 = F'13, cB'3 = F'21.
F'μν = aμαaνβFαβ.
where aμα are the components of the lorentz transformation matrix.
if you are allowed to use relativistic tensors, then it can be even easier.
it is a fact that any tensor expression with all indices contracted must be a (restricted) lorentz scalar. thus, just take the tensor expression above, check that it is equal to E*B, and you re done. you don t even have to check how it transforms, since it is guaranteed to be a scalar.
This makes sense to me -- if you contract with the metric, you get the Langrangian; if you contract with the Levi-Civita tensor, you get the dot product.
I do have to ask, though -- what exactly is a "Lorentz scalar?" What properties does it have beyond those of the usual scalar?
- Warren
the (restricted) lorentz scalar is invariant under (restricted) lorentz transformations. and, i could compare this with "the usual scalar", as soon as you tell me which usual scalar you mean.
Hmmm... I guess I always thought that ANY scalar was unchanged by Lorentz transforms.
And I suppose I mean scalar, as per MathWorld: "A one-component quantity which is invariant under rotations of the coordinate system."
- Warren
yeah, that s about right. so Lorentz scalars are scalars that are invariant under rotations in Minkowski space (the set of all such rotations is called the Lorentz group. hence the name)
- Warren
note that according to this definition, you might think that energy was a scalar.
and it is, under euclidean rotations. but it is not a Lorentz scalar.
once you choose some coordinate system, i can talk about scalars that are invariant under rotations of that coordinate system.
Not necessary, I understand the distinction now. Energy is not a scalar when the group of coordinate transformations in question is the Lorentz group. The best you can say about it that it is the zeroth component of the 4-momentum. Not all "one-component quantities" are scalars -- only those that are invariant under the relevant coordinate transformations.
Thanks as always,
- Warren
I guess my main problem is calculating the 16 components of the electromagnetic field tensor. Once I calculate this, I can just multiply it by the matrix |1 0 0 0 | and |1 0 0 0 |.
|0 1 0 0 | |0 1 0 0 |
|0 0 j iB| |0 0 j-iB|
|0 0-iB j| |0 0 iB j|
This is in accordance to the equation F'= lambda(F)lambda'. Once again I apologize for lack of notation. So in other words, once I can calculate electromagnetic field tensor F, I can calculate the relativistically transformed field tensor F'. And then I should be able to take the dot product of E and B in both relativistic frames,correct?
sometimes a photon with a time-like polarization is called a scalar photon, not because its a Lorentz scalar, but because its a euclidean scalar.
or, when you do Kaluza-Klein reductions, things that are tensors under SO(4,1) reduce to a tensor, a scalar and a vector under SO(3,1). so one mans scalar is another mans zeroth component. it just depends on which coordinates you feel like working with.
Yup.
- Warren
Wouldn't this be just as complicated?
Another thing: How do you know that this is going to give you the dot product? I mean, I can see that going through the calculations would show this, but, how do you know to start with the Levi-Civita contraction in the first place? It seems kind of out-of-the-blue to me. Is there some theorem or something?
... once I can calculate electromagnetic field tensor F, ...
If you can use the Faraday tensor, then you should be able to just say that the corresponding components are the components of the electric and magnetic field, without worrying about the sources. There is no need to calculate these components, you just let them be arbitrary.
... I can calculate the relativistically transformed field tensor F'. And then I should be able to take the dot product of E and B in both relativistic frames,correct?
This is basically what I had in mind, but I think lethe has a better idea. I don't quite understand how you can justify starting with the contraction with the Levi-Civita tensor, but apparently it does give the desired result.
you be the judge
let s have a look:
the Levi-Civita tensor will select all the terms with even permutations of 1234 with a plus sign, and all the terms with odd permutations with a minus sign
[tex] \begin{multline*}<br /> F^{\mu\nu}F^{\rho\sigma}\epsilon_{\mu\nu\rho\sigma}\\<br /> =4(F^{01}F^{23}+F^{02}F^{13}+F^{03}F^{12})=4\mathbf{E}\cdot\mathbf{B}<br /> \end{multline*}[/tex]
and that s all i need to do, it is guaranteed to be lorentz invariant.
Thank you Turin and everybody. I think I have got it now.
Yeah, I'm with you on this one. It just wouldn't have occurred to me to use the Levi-Civita until after I had written it out once. I was just wondering if there was some other reason behind it besides seeing that it does in fact work. Like, "given a ..., contraction with the Levi-Civita tensor ..." I don't really know exactly what I want to hear about this. I just don't like proofs to come out of the azz.
well, this is pretty much how proofs with tensors go. you start with some tensor expression of some rank and you want some other tensor expression of some other rank. there are only a few valid manipulations you can do to these tensors to accomplish this. contracting indices with another tensor is always something you can do. if the space has a metric, then the metric tensor is available for this purpose. if the space has an orientation, then the Levi-Civita tensor is also available. if the space has a connection, then you can also take the covariant derivative.
there are some other stuffs too, but the problem didn t call for any more involved manipulations. maybe you are very familiar with raising and lowering indices with the metric tensor, and not so familiar with raising and lowering indices with the Levi-Civita. most people are. well, let this thread be a lesson to you.
it is worth noting that when i was considering what possible quadratic scalars i can make out of [itex]F^{\mu\nu}[/itex], i also had to consider [itex]F^{\mu\nu}F^{\rho\sigma}\eta_{\mu\nu}\eta_{\rho\sigma}[/itex]. this is another possible scalar that i could make out of the field strength, but i didn t mention it above because it vanishes (the field tensor is antisymmetric and hence traceless)
and, as you saw, i didn t know to start with the Levi-Civita in the first place. in fact, i made a mistake and thought the answer would be to start with the contraction with the metric tensor instead.
it wasn t until you pointed out that i was wrong that i realized this.
even so, i had from the beginning recognized the contraction with the Levi-Civita as one possible way of obtaining a scalar.
and in fact, as i argue above, there is evidence why i should have known before hand to start with Levi-Civita (Levi-Civita changes sign when you reflect it in the mirror, and so does E*B)
and i ll just say one more reason why i like my proof a lot:
i have never been able to once and for all put to memory exactly what the elements of the Lorentz transformation look like. if i don t know the elements of the Lorentz transformation, i can t figure out how the electric field and magnetic field transform.
so i can t compare the dot product in two frames, without either going to my book to look up some formulas, or else going to first principles and deriving the form of a Lorentz tranformation ([itex]\Lambda^Tg\Lambda=g[/itex] is how it goes, i think?)
this is a very nice feature of the tensor index notation. all you have to do is figure out how to get rid of all the indices, and you are guaranteed to have a Lorentz scalar.
Lethe, this thread is a lesson to us all.
This
is so clear, and so handy, and I never would have thought of it by myself. I have now stored it in my brainbox, and I hope I can find it again when I need it.
Thanks.
This ... is so clear, and so handy, ...
Did you ever expect any less from the man himself?
That is the first I have heard of this. What about:
[itex]\eta_{\alpha\sigma}\eta_{\beta\tau}...\eta_{\kappa\epsilon}\eta_{\mu\eta}F^{\alpha\beta}F^{\gamma\delta}...F^{\kappa\lambda}F^{\mu\nu}[/itex]
Is this not considered distinct from other contractions involving the metric, or is it considered just another version of the same type of contraction. I don't understand how there can only be a few (or even a finite number of) valid manipulations.
(For some reason, It won't let me edit that itex stuff. There are a few typos in it.)
What does it mean for a space to have an orientation or connection?
I am not really "familiar" with anything that has to do with tensors. My major prof is so hung up on the facility of the notation that it has been slow going trying to understand the meaning behind any of this stuff. For instance, I thought that raising and lowering (what he calls "index gymnastics") was defined by contraction with the covariant and contravriant components of the metric tensor. This is the first I've heard to the contrary, and now I am utterly confused. I thought that I understood raising and lowering of the indices of a component to be changing that component between contravariant and covariant. I don't understand how the Levi-Civita symbol/tensor can do this, since it doesn't contain any dot products (or does it?).
As always.
I got a hold of an undergrad math meth book by Arfken. In the chapter on tensors, it is said that the Levi-Civita symbol isn't really a tensor, but a pseudo-tensor. Any comments on this, and how it relates to the discussion? Does this mean that the dot product in question isn't really a scalar, but a pseudo-scalar? Is this only the case for the Levi-Civita symbol in 3-D, and in 4-D it is a true tensor?
  • · Replies 20 ·
  • · Replies 30 ·
  • · Replies 144 ·
12K
  • · Replies 45 ·
9K
  • · Replies 32 ·
