Work Done on 5.8kg Particle in 4.4 seconds
  • Thread starter Thread starter pringless
The work done on a 5.8 kg particle over the first 4.4 seconds of motion is calculated to be 380.16 Joules. This is derived using the displacement equation x = 2 + 1.8t - 1.6t² + 0.94t³, where the coefficients represent specific physical parameters. The velocity at t = 4.4 seconds is determined by differentiating the displacement equation, yielding v = -11.648 m/s. The kinetic energy at this time is then computed using KE = 1/2 * m * v², confirming the work done through the work-energy theorem.
  • Understanding of Newton's laws of motion
  • Familiarity with calculus, specifically differentiation and integration
  • Knowledge of the work-energy theorem
  • Ability to manipulate polynomial equations
  • Study the work-energy theorem in detail
  • Learn about calculating kinetic energy using different methods
  • Explore advanced applications of calculus in physics
  • Investigate the implications of time-varying forces on particle motion
Physics students, educators, and professionals in mechanics, particularly those focusing on dynamics and energy calculations in particle motion.
pringless
A time-varying net force acting on a 5.8kg particle causes the object to have a displacement given by
x = a + bt + dt^2 + et^3
where a = 2m, b = 1.8 m/s, d = -1.6 m/s^2, e = .94 m/s^3 with x in meteres and t in seconds. Find the work done on the partciel in the first 4.4 seconds of motion. Answer in units of J.
i've taken both derivative and integral, I am not getting any way correct grr. can someone help
Heres how u do the problem...
[tex]\int dw = \int_{x_{1}}^{x_{2}} F.dx[/tex]; where [tex]F[/tex] is the force and is equal to [tex]m*a[/tex], where [tex]m[/tex] is the mass and [tex]a[/tex] is the accln.
To find the work done by the force in 1st 4.4 seconds you will have to do this:
[tex]x = a + bt + dt^2 + et^3[/tex]. Therefore:
[tex]dx = (b + 2dt + 3et^2)dt[/tex]
substitute this in the work equation to get:
[tex]\int dw = \int_{0}^{4.4} F * (b + 2dt + 3et^2)dt[/tex]
where:
[tex]F = m*a[/tex], and [tex]a = d^2x[/tex] for the 1st 4.4 seconds. Find this force and then substitute in the work integral..
There is another way to this problem:
work done = change in kinetic energy. Find the kinetic energy at t = 0 and at t = 4.4 by finding the velocities at t = 0 and at t = 4.4sec by differentiating the expression for x and then substituting for t.
[tex]work done = W = m(v_{4.4}^2 - v_{0}^2)/2[/tex]...
Sridhar
To find the work done on the particle, we can use the work-energy theorem which states that the work done on an object is equal to the change in its kinetic energy.
In this case, the kinetic energy of the particle can be calculated using the formula:
KE = 1/2 * m * v^2
where m is the mass of the particle and v is its velocity.
Since the particle has a mass of 5.8kg, we can calculate its kinetic energy at any given time using the above formula. However, since we are interested in the work done in the first 4.4 seconds, we will calculate the kinetic energy at t = 4.4 seconds.
First, we need to calculate the velocity of the particle at t = 4.4 seconds using the given equation for displacement:
Substituting t = 4.4 seconds and the given values for a, b, d, and e, we get:
x = 2 + 1.8(4.4) - 1.6(4.4)^2 + 0.94(4.4)^3 = 38.67 meters
Now, to calculate the velocity, we take the derivative of the displacement equation:
v = b + 2dt + 3et^2
Substituting t = 4.4 seconds and the given values for b, d, and e, we get:
v = 1.8 + 2(-1.6)(4.4) + 3(0.94)(4.4)^2 = -11.648 m/s
Finally, we can calculate the kinetic energy at t = 4.4 seconds:
KE = 1/2 * m * v^2 = 1/2 * 5.8 * (-11.648)^2 = 380.16 J
Therefore, the work done on the particle in the first 4.4 seconds of motion is 380.16 Joules.
  • · Replies 16 ·
