The discussion revolves around the process of calculating the percent by mass of acetic acid in vinegar, including the necessary steps to determine the mass of vinegar based on its density and volume, as well as the method for calculating the percent by mass of acetic acid in the sample. The scope includes homework-related questions and mathematical reasoning.
- Homework-related
- Mathematical reasoning
- Debate/contested
- One participant proposes using the formula mass = density x volume to calculate the mass of vinegar, suggesting a mass of 25.25g based on a density of 1.01g/mL and a volume of 25mL.
- Another participant questions the clarity of the initial inquiry and confirms that vinegar is acetic acid.
- There is a suggestion that the percent by mass of acetic acid is calculated by dividing the mass of acetic acid (0.948g) by the mass of vinegar (25.25g), resulting in a percent of 3.75%.
- One participant raises a concern about obtaining two different answers for the mass of acetic acid in the same sample, questioning whether glacial acetic acid was used in the experiment.
- A participant describes their experimental procedure involving titration with sodium hydroxide and the use of phenolphthalein, indicating that they used vinegar.
- Another participant speculates that glacial acetic acid may have been diluted to create the vinegar used in the experiment, suggesting a potential misunderstanding about the materials used.
- There is a cautionary note about the potential for volume changes when mixing different substances, using the example of mixing ethanol and water.
Participants express uncertainty about the materials used in the experiment and whether the calculations for mass and percent by mass are correct. There is no consensus on the exact nature of the vinegar used or the accuracy of the calculations presented.
Participants mention the potential confusion between glacial acetic acid and vinegar, as well as the implications of using different concentrations of acetic acid in the calculations. There are also unresolved questions about the accuracy of the mass measurements and the definitions of percent by mass versus percent by volume.
