Thread Closed
Need Understandable Explanation Of Bell's Theorum
Share Thread Thread Tools
Dec26-07, 08:26 PM   #52
Here is a quote I found in an article on DrChinese' very nice and interesting website.
It is from Alain Aspect, apparently in an 1999 article in Nature and/or on nature.com.
The violation of Bell’s inequality, with
strict relativistic separation between the cho-
sen measurements, means that it is impossi-
ble to maintain the image ‘à laEinstein’
where correlations are explained by com-
mon properties determined at the common
source and subsequently carried along by
each photon. We must conclude that an
entangled EPR photon pair is a non-separa-
ble object; that is, it is impossible to assign
individual local properties (local physical
reality) to each photon. In some sense, both
photons keep in contact through space and
time.
I'd like to highlight the last sentence: "In some sense, both
time."
Alain Aspect is clearly someone who is familiar with all the if's and but's of Bell's theorem.
[Edit:] At the end of the article, he points out that it is meanwhile a matter of 30 standard deviations.
Dec27-07, 10:35 AM   #53
Quote by colorSpace View Post
I'm discussing on the level of plausibility arguments. I take it that the two subsystems wave functions are not independent, and imposes a joint constraint. For example, in order to conserve momentum, when one particle goes from superposition to specific spin, the other particle must then go from superposition to opposite spin.
I was expecting a continued discussion to give me ample opportunity to elaborate on this point. So instead I'm quoting myself in order to clarify this point for the quick reader.
The two subsystems in the quote above are two entangled particles, A and B.
When A acquires a specific spin (caused by measurement), then B is required, due to the dependencies in their wave function, to acquire the opposite spin (when measurement angles are the same).
If one assumes Heisenberg Uncertainty in a non-realist fashion, this means (in my understanding) that one assumes that there is no underlying cause for why particle A acquires this specific spin (out of the two possibilities depending on the measurement angle). This means that there cannot be the same cause already present at particle B, since there is no such cause. Which in turn means that there must be a non-local connection between A and B, since experiments verify that particle B will indeed acquire the opposite spin when measured along the same angle, whichever one that is. (Experiments verify this even when the shortness of the time window between relevant events excludes communication between A and B at speeds comparable to the speed of light).
So in my understanding, as long as one takes it as a given that the wave functions are indeed interdependent in this way (as Quantum Theory says AFAIK), the assumption of Heisenberg Uncertainty to have no underlying cause (non-realism in this regard) implies non-locality.
Dec27-07, 06:56 PM   #54
Recognitions:
Gold Membership Gold Member
3. Perhaps a local non-realist theory would have to be very "hand-waving", as is, in a certain way, the Uncertainty principle. You seem to be indicating that in addition to Heisenberg uncertainty, only explanations similar to those in local-hidden-variable theories would be necessary. However I think many of the common classical explanations have been disproved by experiments in 1998 and later, such as the above, even if this is outside of Bell's theorem.
4. In the case of non-local realism, a specific theory with a physical, detailed, ontological description already exists: the deBroglie-Bohm model, with Bohmian mechanics. (Though I wouldn't know whether it is developed to a level similar to QM).
5. On the other end, apparently a local non-realist theory doesn't exit (yet).
Actually, I personally wouldn't be surprised if non-locality will be found elsewhere, in case that matters... ;) BTW, these "forces", or connections, are said to operate between the particles, rather than between measuring apparati. Which is of course why the particles are called "entangled".
A lot of people (though perhaps not a majority) think that orthodox QM is an example of a local non-realistic theory. It is local because causes and effects are limited to c, and it is non-realistic because the HUP is a complete representation of a particle's observables.
Also, regarding the relative settings of the measurement apparati: it was the apparati that are being ruled out as being in non-local communication (in tests of strict non-locality such as the Innsbruck experiment you mention). The point is that Bell imagined as follows:
"In a theory in which parameters are added to Quantum Mechanics to determine the results of individual measurements, without changing the statistical predictions, there must be a mechanism whereby the setting of one measuring device can influence the reading of another instrument, however remote. Moreover, the signal involved must propagate instantaneously, so that such a theory could not be Lorentz invariant."
Dec27-07, 09:51 PM   #55
Quote by DrChinese View Post
So how do these 'people' address the fact that the correlations, even the obvious ones, depend on the relative measurement angles? Are they even aware of this fact? Or do they maintain a position that has been formed in absence of this understanding, and/or before the experiments of 1998 and later had made the case these things really happen (even when either of the loopholes are closed)? It seems to me that these experiments and related developments (such as GHZ experiments) since 1998 are being ignored in a significant way.
Do they not realize that the experiments themselves demonstrate effects that need to be explained, regardless of Bell's theorem? Or am I perhaps mistaken about this?
I'm having difficulties to see how this quote is related to our discussion. It is not quite clear to me whether this text is talking about possibilities of how a hidden-variable theory might work, but perhaps that's what it does.
Why would it be necessary to rule out that the apparati might communicate non-locally? Usually the loophole that needs to be ruled out is that they might communicate classically. And in any case, how would that be related to what we are, or what we have been, discussing?
Dec27-07, 11:07 PM   #56
The OP seeks an "understandable explanation of Bell's theorem" so it seems best to me if we each elaborate our personal understandings. Then, to assist the OP, we might best begin with the simplest (and very impressive) case: using paired-photons that are identically correlated in the singlet state. [Explaining that typically in QM: Alice tests one of the pair (A) and far-away Bob tests the other (B).] We might add: In Bell's theorem, the photons are akin to identical-twin humans subject to Meadow's theorem! The OP's medical background should then see the error in this approach; a similar error (IMO) lying at the heart of Bell's theorem!
Thus it is that my understanding follows from the assumption that allowable states lie on a loop (ie, a path that begins and ends at the same point). So when Alice finds (via a measurement interaction) that her photon A has an allowable state a then we know (from their birthing correlation) that B also has an allowable state a. (a and b being unit-vectors denoting the direction of the measured polarizations; the loop then being a circle.)
Then, for all of Alice's tests that reveal A -> a, when Bob is measuring for the state b, (ie, B -> b) he is (unknowingly) evaluating the conditional probability:
P(B -> b| B -> a) = cos^2 (a,b); all elements in this formulation being local for Bob by virtue of the photonic birthing circumstances/correlations associated with the singlet state!
Dec28-07, 02:19 AM   #57
Quote by jVincent View Post
Year, thx for the post, however I'm not quite sure how this experiment rules out a hiddenvariable model. I'm a little stumped with what they define as a "classical" model. Why is it that the classical model _must_ be a product of four different functions of the different angles? And why is it that each of these functions must be continues? Most likely I am misunderstanding what they are writing, could you clearify?
Sorry, jVincent, I overlooked that you had replied to my post, since while I was writing a reply to Peter's message a lot of other messages came in.
The mathematics behind these papers are usually very complex, even if in this case the presented results look very simple; they are often shorthands for much more complex expressions, and usually beyond my understanding.
As far as I can tell, the functions for the particles' results have only the measurement angle as a meaningful input (aside from the hidden variables), and if they belong to a local model, they must be independent of each other, that is, the function for each particle can only use that particles measurement angle as an input, none of the other angles. For the cases which allow definite predictions, the result of the last particle is a simple function of the other particles' results, similar as for the spins of two particles where the second is always the opposite of the first.
With multiple particles it is however a bit trickier, so that one can define a set of four experiments such that any possible local-hidden-variable model will make the right predictions only for at most 3 of those 4 experiments, AFAIK. This is because a local model then has more cases to care about than it can accommodate based on having only the measurement angle (and the hidden variables) as an input. The impact of the other measurement angles creates to many different cases, as though it could do something that would be right for any such case. As far as I understand.
As I understand the different in the two views is:
Classical: Spin direction is born at the particle birth.
QT: spin direction is born at time of fist measurement.
But this doesn't seem to be what the experiment is regarding.
That is also my understanding, but I think that is also the assumption in this experiment, except that the hidden variables are "born" at particle birth, and the spin is then an outcome of the hidden variables AND the measurement angle on this particle.
Heisenberg uncertainty implies that the spin does not have a 'predefined' value for the first measurement, and that no hidden variables are recognized. (Even though in the case of Bohmian mechanics, the spin will be pseudo-random, so to speak, instead of random).
This is why I don't understand the attempts to accept Heisenberg uncertainty and, at the same time, to assume that the information comes from the common "birth". If one accepts uncertainty, then that means exactly that there will be no such information available, such as from any common "birth". I would think. From my point of view, this kind of local non-realism therefore looks like a non-starter. Yet I might be missing something, and if so, would like to find out.
Thread Closed
Thread Tools
Similar Threads for: Need Understandable Explanation Of Bell's Theorum
Thread Forum Replies
Understandable, recent physics General Physics 7
Is Griffiths Electromagnetism understandable for first year students. Science Textbook Discussion 14
Why do I find engineering math textbooks much more understandable? Academic Guidance 6
Where can I found explanation on Bell's Inequality ? Quantum Physics 16
The most profound, inspiring and understandable book on physics ever written General Physics 0
