Understanding Faraday's Law of Induction
  • Thread starter Thread starter discoverer02
    Faraday's law Law
The discussion revolves around a problem involving Faraday's Law of Induction, specifically focusing on a bar sliding on parallel rails within a magnetic field. The problem requires understanding the forces acting on the bar due to the magnetic field and the induced electromotive force (emf) as it moves.
  • Participants explore the forces acting on the bar, questioning the source of motion and the role of the magnetic field. There are attempts to relate the induced emf and current to the forces experienced by the bar. Some participants express confusion about how to incorporate the induced current into their calculations.
The discussion is active, with participants providing insights into the relationships between the magnetic force, induced emf, and current. Some guidance has been offered regarding the equations governing the system, but there is still uncertainty about the correct approach to combine these elements effectively.
Participants are working under the constraints of a homework problem, which may limit the information available and the assumptions that can be made about the system. There is a focus on understanding the dynamics of the situation rather than arriving at a final answer.
discoverer02
I'm having trouble with the following problem:
A bar of mass m, length d, and resistance R slides without friction on parallel rails. A battery that maintains a constant emf E is connected between the rails, and a constant magnetic field B is directed perpendicular to the plane of the page and out of the page. If the bar starts from rest, show that at time t it moves with a speed:
v = E/Bd(1 - e^{(-B^2)(d^2)t/(mR)})
in diagram the bar is on the left and the battery is set up on the right so the current runs counterclockwise through the circuit.
The first thing that I'm confused about is the force that sets this in motion. From the problem statement and the diagram, the magnetic field is caused by the current running through the wire, so unless some force is applied to the bar it's not going to move.
I begin trying to solve the problem by working with the following equation:
Sum of the Forces in the x direction = -IdB + F_applied = ma
F_applied = mass x some initial acceleration?
Is this the correct approach. I've tried many and I'm got getting the correct answer.
Can anyone nudge me in the right direction?
Thanks
That constant magnetic field coming out of the paper is not caused by the wire. You have a current carrying wire in a magnetic field, which exerts a force on it.
Thanks again for your help Doc Al.
I already tried this approach and didn't seem to lead me in the right direction.
The magnetic force on the rod, in this case, is directed to the left because dF = Ids X B = IdB to the left.
So the forces in the x direction are -IdB = ma
The induced E-field in the rod once it starts moving is v x B = vB.
So the induced emf in the rod once it starts moving is
[tex]\int Efield \cdot ds[/tex]
which is vBd.
The induced current is vBd/R in the direction opposite the current from the battery because the magnetic flux is increasing in the loop because the area is increasing, right.
How do I treat the current already in the loop? Do I include it in the equation of my forces and subtract from it the current created by the back emf? If I do, I'm not coming up with the right answer.
Think of it this way. The EMF across the wire is:
ΔV = E - EMFinduced
EMFinduced = DBv
Current through the wire is:
I = ΔV /R
Force on the wire is:
F = IDB
Acceleration of the wire is:
a = dv/dt = F/m = IDB/m
Write and solve the differential equation. Make sense?
It makes sense.
Thanks.
  • · Replies 22 ·
