| New Reply |
Alternative theories being tested by Gravity probe B |
Share Thread |
| May20-07, 01:32 PM | #205 |
Alternative theories being tested by Gravity probe BPervect said you were busy with PhD thesis and he was urged to step in and fill the gap. Does this mean that the thesis is done now? or pending approval? In any case congratulations on forthcoming PhD |
| May20-07, 01:52 PM | #206 |
| May20-07, 02:22 PM | #207 |
To SpaceTiger: Hi, what makes the calculation so strong is that it is neither a modification nor a generalisation, as you seem to be saying. The theory hasn't been changed - instead the calculation works straight from the already published conceptual picture, and proves in an unambiguous way what the prediction should have been. The theory is still under development, but not in this area - the numerical value of the curvature component doesn't go into the calculation, it comes out of it. Jonathan
| May20-07, 02:55 PM | #208 |
| May20-07, 04:21 PM | #209 |
Hi, I messed up in the first one for the following reasons!
In the first paper I pointed out a number of ways in which PSG mimics GR, but unfortunately missed one way. Having missed it, I wrote "There is no space curvature in PSG, so it should not mimic GR to the extent of causing a straight line parallel transported through a gravitational field to change its orientation. This removes the curvature component, which is two thirds of the predicted geodetic effect from GR.." At that point I thought what some think - that only curvature will produce the geodetic effect. After the effect was measured I did a calculation using two points on the spin axis of one of the gyros on GP-B - the centre, and one end, at the surface of the sphere. Worked out their positions after half an orbit, with very slightly different speeds (due to different heights in a Planck scale refractive medium that affects matter). It's a thing that I'd tried last year but never completed - out came the curvature component of the geodetic effect, it gave 4.4 arcsecs/yr. Sad I'd missed it, but happy that it vindicates the theory, as I think it does. But I await the views of others, and would appreciate any thoughts you might have. |
| May24-07, 05:44 AM | #210 |
Hello,
Well it seems that if there was a problem with the calculation it would have been pointed out - Garth and probably SpaceTiger have read the paper, hopefully others. It's a very simple idea - matter is slowed in its motion through the field by the same factor as light is slowed (and for that matter as time is slowed), which is sqrt [1 - (2GM/rc^2)]. When one applies that to local matter within an orbiting object, one finds the object turns - the calculation shows this is exactly as in the geodetic effect, both numerically and in terms of direction. I'm all for GSCC, glad it's back on the list - experiment can help shape theories. For PSG it has helped shape the interpretation rather than the theory, and I'll take the lack of criticism as positive. The wider question this has bearing on is what possible interpretations for the geodetic effect do we have, now that it has been measured directly. Is curvature the only one? Thanks, best wishes Jonathan |
| Jun14-07, 02:31 AM | #211 |
Latest June Mission Update from the GP-B team.
Nothing new to report on the results. 2. THE EFFECTS OF GENERAL RELATIVITY ARE CLEARLY VISIBLE 3. FIRST PEEK AT RESULTS PRESENTED AT APRIL APS MEETING; FINAL RESULTS IN DECEMBER (geodetic precession = GR to 1% - however present estimate ("hint") of result ~30 mas too high but error is still ~100 mas) 4. THE TWO SURPRISES & THEIR IMPACT ON THE EXPERIMENT 5. NEXT STEPS-MOVING TOWARDS A FINAL RESULT i. Fine calibration of the gyroscope/telescope scale factor ii. Refining the analysis of the misalignment torques iii. Extremely precise VLBI measurement data will be substituted for the current 1997 Hipparcos [star] Catalogue values for the proper motion of IM Pegasi. We continue to wait and see! ![]() Garth |
| Jun15-07, 01:15 AM | #212 |
But these minor corrections are just that, Garth, minor. I fail to see how they can affect the conclusions. The results are GR concordant and will remain very much so, IMO.
| Jun15-07, 01:32 AM | #213 |
I was just reporting what the GP-B team said at the conference, in the mist of the errors presently being reduced they saw just the hint of a non-GR signal. See APS talk by Francis Everitt page 21, you will see the successive error ellipses honing down on a value about 30 mas away from the GR prediction.
Perhaps it was wishful thinking on their part - we shall wait and see! Garth |
| Jun15-07, 01:57 AM | #214 |
Does every one consider this test (clean) it seems to me like trying to make some sense out of white noise, i mean it is not like a some number registers on a dial, if the test was repeated with the same results it would be more
convincing. Or is this the one test that has been done with so much care that no other conclusions are probable. |
| Jun15-07, 02:15 AM | #215 |
They have a problem, which they freely admit. The presence of this noise almost ruined the experiment, however it is not white noise and the spurious signal can be extracted objectively.
The two unexpected effects are linked. First the electrostatic patches have put an extra torque on the gyro rotors that perturbs them, secondly the energy used up in this perturbation gradually reduces the polhode motion (wobble) making that more difficult to model. However once they have accurately modelled the geometry of the patch effects, which are different for each of the four gyro rotors, they can subtract that from the precession signals and accurately model the polhode motion. It is this that they are completing at present. You can read all about it by following the links on their website. ![]() Garth |
| Jun16-07, 06:13 AM | #216 |
Just to make clear what the present situation is:
(mas = milliarcsec) The geodetic N-S precession is predicted by GR to be - 6606 mas/yr, however there is a solar geodetic precession N-S component of + 7 mas/yr and the proper motion of IM Pegasi +28 mas/yr to take into account, resulting in a net expected N-S precession of -6571 [itex]\pm[/itex]1 mas/yr. The frame-dragging E-W precession is predicted by GR to be -39 mas/yr, the solar geodetic precession E-W component of -16 mas/yr and the proper motion of IM Pegasi -20 mas/yr to include, resulting in a net expected N-S precession of -75 [itex]\pm[/itex]1 mas/yr. From pages 20 and 21 of Francis Everitt's April APS talk, we find: A series of error ellipses on the N-S v E-W precession plot with centres respectively at (-6584 [itex]\pm[/itex]60, -83 [itex]\pm[/itex]22 mas/yr) June 2006, (-6597 [itex]\pm[/itex]17, -92 [itex]\pm[/itex]15 mas/yr) December 2006, (-6595 [itex]\pm[/itex]12, -98 [itex]\pm[/itex]7 mas/yr) March 2007 and (-6603 [itex]\pm[/itex]8, -98 [itex]\pm[/itex]7 mas/yr) March 2007. It was this last reading for the geodetic precession that Francis Everitt reported at his April APS talk. If we also include that 'glimpse' of the E-W precession as well we have net values of: (-6603 [itex]\pm[/itex]8, -98 [itex]\pm[/itex]7 mas/yr) whereas GR predicts: (-6571 [itex]\pm[/itex]1, -75 [itex]\pm[/itex]1 mas/yr). In other words the actual readings are larger than GR predicts by 32 mas/yr in geodetic precession and 23 mas/yr in frame-dragging precession. However, they reported an overall error, which is still being reduced, caused by residual gyro-to-gyro inconsistencies due to incomplete modeling of ~ [itex]\pm[/itex]100 mas/yr. This renders the present geodetic 'glimpse' as being consistent with GR to within about 1[itex]\frac{1}{2}[/itex]%, whereas the frame-dragging precession is at present swamped by noise. The running now stands:
The predictions are now: GPB Geodetic gross precession (North-South)
We await the GPB gravitomagnetic frame dragging gross precession (East-West) result.
Note: in the above list only the Kaluza-Klein gravity theory (KK) is able to produce a geodetic precession larger (negatively) than GR if 0 < b < [itex]\frac{1}{18}[/itex], (by a maximum of 11.5 mas when b = [itex]\frac{1}{72}[/itex]), but it cannot produce a frame-dragging precession larger than GR. Garth |
| Jun17-07, 04:00 PM | #217 |
About the apparent extra 32 mas/yr - there's a '96 paper by Kenneth Nordtvedt, which shows that the analysis of the lunar laser ranging data done in the '80s also gave a precession slightly greater than the geodetic precession. Nordtvedt's explanation probably wouldn't cover both anomalies, but if he's wrong… I haven't got time to look into it, but Garth, you might want to see if in relation to context the two are equivalent. It would then be a new anomaly.
The paper is "On the 'geodetic precession' of the lunar orbit", Class. Quantum Grav. 13 (1996) 1317-1321. J. |
| Jun18-07, 02:03 AM | #218 |
Kenneth Nordtvedt, Classical and Quantum Gravity, Volume 13, Issue 6, pp. 1317-1321 (1996) On the `geodetic' precession of the lunar orbit Kenneth Nordtvedt, Icarus Volume 114, Issue 1, March 1995, Pages 51-62 The Relativistic Orbit Observables in Lunar Laser Ranging I make two further comments: 1. The analysis of the Moon's orbit is very complicated having to take into account tidal reactions as well as planetary perturbations and other effects. When trying to test for something like the geodetic precession how sure are we that all other effects have been correctly accounted for? 2. All measurements of orbits, geodesics, through empty space cannot reduce a degeneracy between GR and a conformal gravity theory in which the action reduces to that of canonical GR in vacuo. There is therefore the possibility that the geodetic precession may be equal to GR in such observations as these above yet different from GR for the GP-B gyros. It is this point that has not been taken into account by Kenneth Nordtvedt when he said the experiment was worth doing when it was first proposed in the 1950's and begun in the 1960's, but now it is a foregone conclusion. If the final results of the two precessions are exactly equal to GR then we can rule out such conformally equivalent gravitational theories. However if the final GP-B results are different from the GR predictions, while other tests of the geodetic and frame-dragging precessions measuring the orbits of planetary bodies, binary pulsars, or satellites, are equal to the GR predictions, then that would indicate a conformally equivalent non-minimally connected scalar field is at work. We wait to see. ![]() Garth |
| Jun18-07, 04:30 AM | #219 |
I meant look at the numbers at a shortcut (this can help!). Then only look further if the two discrepancies come out roughly the same, when allowing for orbit differences. But it might be worth waiting for all possible sources of error to be removed from the GP-B data first.
| Jun29-07, 01:37 AM | #220 |
This paper on today's physics arXiv claims to correct the GR prediction for the frame-dragging precession: Correction of the Frame Dragging Formula due to the Precession of the Coordinate Axes near a Rotating Body.
Furthermore, the present 'glimpses' of the GP-B frame-dragging result, if anything, are greater than the GR prediction! Garth |
| Jun29-07, 02:19 AM | #221 |
Will there ever be closure to this test? i do not mean the scientific impossibility of proof beyond doubt, just doubts have been quashed
to a CL that is acceptable. |
| New Reply |
Similar Threads for: Alternative theories being tested by Gravity probe B
| Alternative theories | Beyond the Standard Model | 4 | ||
| alternative current to hall probe | General Physics | 1 | ||
| alternative theories about the origin of the universe... | Cosmology | 25 | ||
| gravity probe B | Special & General Relativity | 2 | ||
| Alternative theories to General Relativity - great opportunity! | General Physics | 19 | ||
