| New Reply |
Alternative theories being tested by Gravity probe B |
Share Thread | Thread Tools |
| Oct2-08, 05:08 AM | #307 |
The predictions are now: GP-B Geodetic gross precession (North-South).
GPB gravitomagnetic frame dragging gross precession (East-West).
You can see for yourselves the present state of the results in a series of slides of a lecture given by Francis Everitt at Cornell University on the 12th November 2007. Gravity Probe B + a Hint of STEP. The pertinent slides are slide 3: Seeing General Relativity Directly and the slide: RNS vs RWE Algebraic 4-Gyro Joint Estimates These last two slides clearly show an inconsistency with the GR prediction at the 1 [itex]\sigma[/itex] confidence level. Einstein expectation: -6571 [itex]\pm[/itex] 1* mas 4-gyro result (1 [itex]\sigma[/itex]) for 85 days (12 Dec 04 -- 4 Mar 05) -6632 [itex]\pm[/itex] 43 mas (* -6606 mas + 7 mas (solar geodetic) + 28 [itex]\pm[/itex]1 mas (guide star proper motion)) We note that this 07 November 1[itex]\sigma[/itex] confidence level result is inconsistent with all the above geodetic predictions except KK, but nobody takes any notice until at least 3[itex]\sigma[/itex]! Garth |
| Oct2-08, 08:39 AM | #308 |
Thanks Garth,
I appreciate being back on the list. The relevant link is to the second paper published, not the first, as it has the equation that directly produces the geodetic effect curvature component, so vindicating PSG and leading to the prediction you quote above. (And showing that matter could be being affected by a kind of refractive medium at the Planck scale, as light is affected). It's at http://journalgp.awardspace.com/journal/0202/020203.pdf If I'm not mistaken, wasn't Jin He's Absolute relativity due to go back on as well? Anyway, it'll be interesting to see what the GP-B team have to say. best wishes, Jonathan |
| Feb19-09, 09:14 AM | #309 |
Gravity Probe B 2009 interim results are arived!!
| Feb23-09, 01:41 AM | #310 |
Current Mission Status
Garth |
| Nov26-09, 08:33 AM | #311 |
Okay - now closing in on the GR prediction;
EDIT - This was deleted somehow from my original post - thank you sylas below. MISSION UPDATE — November 12, 2009 Click on the diagrams to see the present measurements, especially the 'Individual and 4-gyro combined estimates.' and note only 50% error ellipses are plotted. They have certainly made heavy weather of it..... Garth |
| Nov26-09, 09:57 AM | #312 |
Recognitions:
Well, closing in after modeling away ~95% of the initial uncertainty. I'd say, they needed a result, now they have one.
Better wait for some independent data. |
| Nov26-09, 10:42 AM | #313 |
The GR prediction lies just outside the 50% error ellipse of the 4 combined gyros. At this point, I wonder if they learned more about Newton and gyroscopes than about GR! The confirmation is nice even if not to the accuracy they had originally hoped. Cheers -- sylas |
| Nov26-09, 05:55 PM | #314 |
The GP-B folks have made so many adjustments and re-adjustments of the data I have no confidence they can really tell the difference between polhode noise, aberration of light from a moving solar system or other unquantifiable effects. NASA was right to pull the plug on this one. Bad science.
| Nov27-09, 02:35 AM | #315 |
Two unexpected errors have crept into the data, misalignment torques and a varying polhode motion.
A constant polhode motion (wobbling) was to be expected, as each sphere was not perfectly symmetrical, however these motions were found to be damped out and that meant removing the effect from the data proved more difficult. However, adding the variation in spin-down rates to the analysis, the GP-B team currently believes that the underlying reason for both these errors is a single effect caused by "patch effect charges" on the gyro rotors and on the inside surfaces of their housings. The team are confident that they are modelling these sources of noise in the data accurately because they are using two independent methods, algebraic and geometrical, and the results of each method are being compared for consistency. The aberration of starlight is clearly observed as predicted and provides the natural system calibration, over both orbital (the satelite's) and annual (the Earth's) orbits. However the problem is that, given the noise has to be modelled and extracted from the data to find the relativistic signal, should the final signal deviate from GR then few would find the result convincing. Others would be say that they had just modelled the noise incorrectly. Having come this far it would be madness not to complete the data reduction, which is being done through private funding, and the published raw data could provide a mine for others to dig into for years to come - that is if anybody else will be bothered to do so! Garth |
| Nov27-09, 02:49 PM | #316 |
But perhaps the biggest blunder of the experiment was failure to account for the moving frame of the solar system. The aberration of light from this effect is large (larger than the diurnal or annual figures and larger than the relativity effects) but looks like drift and is still unquantified because there is still large uncertainty about the exact speed and exact motions of the SS (it may have several). I do not blame the current program scientists for this problem as it was unforeseen by the original designers of the experiment (note the complete absence of any mention of this effect in the literature). I agree it would be great to thoughtfully take apart and quantify every single signal recorded by GP-B. However, the current team is so focused on finding the relativity effects I believe they are missing the discovery of some very important science about the motion of the solar system. Unintentional bias is hard to get away from in an experiment of this type. Polhode motion is an extremely tricky thing to quantify and predict (no paper supports its prediction with this many variables). In their attempts to cancel it out the GP-B team is probably throwing out vital information about the moving solar system (all in an effort to find the relativity effects). Personally, I doubt if there was any meaningful polhode motion (think about it - those gyros were pretty darn perfect – and polhode is exactly the sort of thing they were designed to avoid!). Most of the “noise” is likely motion of the frame of the SS, and possibly, motion of our local star group relative to the guide star. GP-B is a unique experiment. No doubt some day someone will look at the data with a completely virgin mind and reveal key information about the moving solar system. Until then I hope the data is well preserved for future generations. Walter |
| Nov27-09, 03:44 PM | #317 |
See: Bartel et. al. (2007) VLBI astrometry for the NASA/Stanford gyroscope relativity mission Gravity Probe B, in Proceedings of the International Astronomical Union, 3, pp 190-191; doi:10.1017/S1743921308019005. Cheers -- sylas |
| Nov27-09, 03:53 PM | #318 |
Recognitions:
I understand that the published result does not support scc (correct me if I'm wrong), but I wouldn't see it as confirmation or rejection of anything. It is not reproducible, nobody will go down that road again in the foreseeable future, and nobody can follow their corrections without doubt. It's sad, but I'd say: the experiment failed in this aspect. That's ok, it is bound to happen every now and then. |
| Nov27-09, 03:59 PM | #319 |
Walter, would not motion of the Solar System frame be subsumed into the guide star IM Pegasus' proper motion? This was measured independently by the astrometry team at the VLBI and a report found here: Proper Motion of the GP-B Guide Star.
I was at the 2007 APS meeting in Jacksonville to hear the first results of the experiment and asked the question of Francis Everitt specifically about the desire to find the GR effects affecting the modelling of the noise and hence not finding new physics. Francis emphatically stated that that was what they were not doing but modelling the errors in an independent (actually two independent) ways. The annual aberration of light effect is described here:The Annual Aberration Signal. It seemed to confirm the orbital aberration effect. As far as the difficulty of modelling polhode motion, and no real sphere is ever perfect and free from such effect, they have spent four years now on the problem and so they would probably agree with your statement Edit: Crossed post with both sylas and Ich. Garth |
| Nov28-09, 12:40 AM | #320 |
| Nov28-09, 02:31 AM | #321 |
Cheers -- sylas |
| Nov28-09, 02:06 PM | #322 |
If it is known - please tell me how it is known.
The fact is the motion of the solar system is not known - it is assumed. The major assumption is that its only motion is around the galactic center in a period of about 240 million years resulting in a change in orientation of about .005" p/y (within the precession observable), but no one really knows if this is correct. In fact, this assumption itself lies on the assumption that all changes in earth orientation are local in nature and there is no accounting for the motion of the frame of the solar system relative to the VLBI reference points. This has nothing to do with a possible stellar companion. Good science simply requires that we not make too many unfounded assumptions. Unfounded assumptions is what got GP-B into its current mess. |
| Nov28-09, 05:20 PM | #323 |
The experiment measured the angular displacement of the four gyros against a distant quasar, the core of 3C 454.3. Which, being at z=0.859 was seen to be a 'fixed direction in space'.
The satellite itself measured the angles between the gyros and the guide star IM Pegasi, a VLBI team independently measured the Proper Motion of the guide star, relative to the quasar. Both IM Pegasi and the quasar are radio objects. The actual data being measured were the angles between an gryos' axes and the distant quasar. The earth is orbiting the Sun, the Sun is orbiting the Milky Way and the Milky Way is moving through intergalactic space. The total velocity of these motions is approximately 10 -3c. Using ball-park OOM estimates z = 0.859 converts into a distance of about 1010 light yrs and the galaxy moved about 10 -3 lgt yrs in the ~year data were collected, similarly with the quasar, so the proper motion of the quasar would be OOM 10 -13 rad i.e. ~ 10 -5 milliarcsecs. They hope to measure the displacement angles to an accuracy of about 1 milliarcsec, they have achieved an accuracy of about 10 milliarcsecs so far, so as the proper motion of the quasar relative to the Earth is 5 or 6 OOM smaller than this it can be disregarded. Garth |
| New Reply |
| Thread Tools | |
Similar Threads for: Alternative theories being tested by Gravity probe B
| Alternative theories | Beyond the Standard Model | 4 | ||
| alternative current to hall probe | General Physics | 1 | ||
| alternative theories about the origin of the universe... | Cosmology | 25 | ||
| gravity probe B | Special & General Relativity | 2 | ||
| Alternative theories to General Relativity - great opportunity! | General Physics | 19 | ||
