Work and energy bicycle question
The discussion focuses on calculating the power required by a vehicle to maintain the speed of a cyclist coasting at 3.0 m/s on a level road. The cyclist and her bicycle have a combined mass of 75 kg, resulting in a weight of 735 N. The force of air resistance, which is proportional to speed, is determined from two scenarios: coasting down a 2.0-degree incline at 4.0 m/s and a 4.0-degree incline at 8.0 m/s. The calculations reveal that the vehicle must exert a force equal to the air resistance to maintain the cyclist's speed, leading to a definitive power requirement based on the derived forces.
  • Understanding of Newton's laws of motion
  • Knowledge of gravitational force calculations
  • Familiarity with the concept of work and energy
  • Basic trigonometry for resolving forces
  • Calculate the coefficient of air resistance based on the given speeds and forces
  • Explore the relationship between power, force, and speed in physics
  • Investigate the effects of different inclines on cycling dynamics
  • Learn about the principles of energy conservation in mechanical systems
This discussion is beneficial for physics students, mechanical engineers, and cycling enthusiasts interested in understanding the dynamics of cycling forces and energy expenditure in motion.
templaroftheages
A cyclist and her bicycle have a combined mass of 75 kg. she coasts down a road inclined at 2.0 degrees with the horizontal at 4.0 m/s and coasts down another road inclined at 4.0 degrees at 8.0 m/s. she then holds on to a moving vehicle and coasts on a level road. what power must the vehicle expend to maintain her speed at 3.0 m/s? assume that the force of air resistance is proportional to her speed, and assume that other frictional forces remain constant?
thanks.. if anyone could solve this, it'd be great help
You can calculate the gravitational force from these. Since she is not accelerating, the total friction force must be exactly the same as the gravitational force. You are told that the air resistance is proportional to speed (which you know) and that all other frictional forces remain constant. These two situations give two equations for the two unknowns (coefficient of air resistance and "other frictional forces").
Once you have solved for those, you can put them into the force equation for the level road situation and determine the force necessary to keep her moving at constant speed. Power is work divided by time so: multiply the force by the distance moved in a fixed t and divide by t.
To solve this problem, we first need to understand the concept of work and energy. Work is defined as the force applied on an object multiplied by the distance it moves in the direction of the force. Energy, on the other hand, is the ability of an object to do work.
In this scenario, the cyclist and her bicycle have a combined mass of 75 kg. This means that their total weight is 75 kg x 9.8 m/s^2 = 735 N. The cyclist is coasting down two different roads with different inclinations and speeds. In both cases, the only force acting on her is the force of gravity, which is equal to her weight.
On the first road, which is inclined at 2.0 degrees, the cyclist is coasting at a speed of 4.0 m/s. Using trigonometry, we can calculate that the component of the weight acting down the incline is 735 N x sin 2.0 degrees = 25.5 N. This means that the cyclist is experiencing a net force of 25.5 N down the incline, which is causing her to accelerate. However, since she is coasting at a constant speed of 4.0 m/s, we can conclude that the force of air resistance, which is proportional to her speed, is equal to 25.5 N up the incline. This also means that the work done by the force of air resistance is zero, since it is acting perpendicular to the direction of motion.
On the second road, which is inclined at 4.0 degrees, the cyclist is coasting at a speed of 8.0 m/s. Using the same calculations, we can determine that the net force acting on her is 51 N down the incline. Again, the force of air resistance is equal to 51 N up the incline, and therefore, the work done by this force is zero.
Next, the cyclist holds on to a moving vehicle and coasts on a level road at a constant speed of 3.0 m/s. In this case, the only force acting on her is the force of air resistance, which is now proportional to her speed of 3.0 m/s. To maintain this speed, the vehicle must exert a force equal to the force of air resistance. Therefore, the power required by the vehicle is equal to the force of air resistance multiplied by the cyclist's speed, which
