Physics Work and Energy problem
The discussion focuses on a physics problem involving a particle attached to two identical springs on a frictionless table. The force exerted on the particle is derived using Hooke's Law, resulting in the equation F = -2kx(1 - (L/(x^2 + L^2)^(0.5)))i. Participants attempted to apply the formula F = -kxcos(theta) but struggled with the geometric relationship x = (x^2 + L^2)^(0.5) - L, which is essential for solving the problem. The conversation emphasizes the importance of understanding the geometry and forces involved in spring systems.
  • Understanding of Hooke's Law and spring constants
  • Familiarity with basic trigonometry and the Pythagorean theorem
  • Knowledge of vector notation in physics
  • Concept of forces acting on a particle in equilibrium
  • Study the derivation of forces in multi-spring systems
  • Learn about the applications of Hooke's Law in real-world scenarios
  • Explore advanced topics in mechanics, such as oscillations and energy conservation
  • Investigate the effects of friction and damping on spring systems
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking for clear explanations of spring dynamics and force calculations.
FOBoi1122
A particle of mass m is attatched to 2 identical springs on a horizontal frictionless table. both springs have spring constant k and an unstretched length L the particle is pulled a distance x along a direction perpindicular to the initial configuration of the springs, show that the force exerted on the particle due to the springs is
F= -2kx(1-(L/(x^2+L^2)^.5))i
please help us, we've tried to use f=-kxcos(theta), where cos(theta) = x/(x^2+L^2) but we are unable to determine why x = (x^2+L^2)^.5 - L which is needed to solve the problem
This is getting out of hand!
This is the THIRD post of exactly the same question that I have found. The other two were under "General Physics" and "K-12 Homework".
PLEASE, PLEASE, PLEASE do not post the same question repeatedly!
To solve this problem, we can use the concept of Hooke's Law, which states that the force exerted by a spring is directly proportional to the displacement from its equilibrium position. In this case, we have two identical springs, each with a spring constant k and an unstretched length L.
First, let's consider the forces acting on the particle. There are two springs attached to the particle, each exerting a force in the opposite direction. We can represent these forces as F1 and F2. Since the table is frictionless, there is no external force acting on the particle in the horizontal direction.
Using Hooke's Law, we can write the equations for F1 and F2 as:
F1 = -kx1
F2 = -kx2
where x1 and x2 are the displacements of the particle from the equilibrium position of each spring.
Now, let's consider the geometry of the problem. The particle is pulled a distance x along a direction perpendicular to the initial configuration of the springs. This creates a right triangle, where the hypotenuse is x and the other two sides are L and x1 (or x2, since they are equal). Using the Pythagorean theorem, we can write:
x^2 = L^2 + x1^2
Solving for x1, we get:
x1 = (x^2 - L^2)^.5
Since x1 and x2 are equal, we can substitute x1 for x2 in our equations for F1 and F2:
F1 = -k(x^2 - L^2)^.5
F2 = -k(x^2 - L^2)^.5
Now, we can add these two forces together to get the total force exerted on the particle:
F = F1 + F2 = -k(x^2 - L^2)^.5 - k(x^2 - L^2)^.5
= -2k(x^2 - L^2)^.5
To simplify this further, we can use the trigonometric identity cos^2(theta) + sin^2(theta) = 1, and substitute x1/L for sin(theta):
F = -2k(x^2 - L^2)^.5(cos^2(theta) + sin^2(theta))
= -2k(x^2 - L^2)^.5(1 + (
  • · Replies 17 ·
