Compressing Air for Air Propelled Chair: What Alternatives?
  • Thread starter Thread starter Bunting
    Air
The discussion centers on the feasibility of using compressed air for an air-propelled chair design. It concludes that utilizing a compressor to achieve the necessary flow rate for substantial thrust is impractical. Instead, the conversation suggests that traditional jet engines, which rely on burning fuel to generate thrust through high-velocity gas expulsion, are a more effective approach. Alternatives such as using water as a propellant are also mentioned, emphasizing the need for a more massive propellant for better thrust.
  • Understanding of jet engine mechanics and thrust generation
  • Knowledge of compressor capabilities and limitations
  • Familiarity with Newton's third law of motion
  • Basic principles of propulsion and fluid dynamics
  • Research jet engine design principles and components
  • Explore the mechanics of air compressors and their flow rate capabilities
  • Investigate alternative propulsion methods, including water propulsion systems
  • Study the application of Newton's laws in propulsion technologies
Inventors, aerospace engineers, hobbyists interested in propulsion systems, and anyone exploring alternative methods for creating thrust in personal transportation devices.
Bunting
Im currently drawing up plans for an air propelled chair (which ill probly never make :P). I was intending to pureply use air from the atmosphere, use some sort of compressor, to compress it, then send it flying out the back in order to displace the chair. However. I don't know if there are such machines available. I guess you get compressed air in cylinders for a reason, but i don't know what that reason is!
If I cannot use air, what would you suggest ?
Thanks!
What you intend to design is a jet engine. The reason it will be difficult to do with a compressor is simple: it'll be nigh impossible to build a compressor capable of the flow rate (volume per second) needed to achieve any substantial thrust.
Most people design jet engines to use a fuel -- the fuel burns, releasing large amounts of gas. The gas then exits a nozzle, generating thrust via Newton's third law.
- Warren
air propelled chair
You mean helicopter? Or perhaps hoovercraft?
For better thrust, you need something more massive. Water perhaps? But I think most efficient propellant would be your leg :wink:
  • · Replies 22 ·
  • · Replies 33 ·
  • · Replies 26 ·
  • · Replies 45 ·
