Easier to walk upstairs, but..
by xoops
Tags: easier, upstairs, walk
xoops
xoops is offline
#1
Dec28-05, 10:38 AM
P: 4
Hi all,
This questions is bothering me lately. Why is it easier to walk down the stairs, than up the stairs?
I'm clueless, any help greatly appreciated.
Thanks,
Matt
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
Tide
Tide is offline
#2
Dec28-05, 11:00 AM
Sci Advisor
HW Helper
P: 3,149
It's the same reason why your arms get tired when you have them extended while holding weights. You aren't doing any work on the weight (F dx = 0) but you are doing "biological work" since your heart exerts a force to push blood through your veins. That requires energy.
You do more biological work going up stairs than you do when going down.
Manchot
Manchot is offline
#3
Dec28-05, 11:00 AM
P: 728
We don't "spend" energy to brake, we simply turn our kinetic energy into thermal energy when we collide with the staircase.
xoops
xoops is offline
#4
Dec28-05, 11:10 AM
P: 4
I know everything finally converts to thermal energy... hmmmh, but I'm not yet convinced about non-breaking.
do you think there is a way to do some measurement by amateur? I have altimeter and thermometer on my hand watch.
Tide
Tide is offline
#5
Dec28-05, 11:17 AM
Sci Advisor
HW Helper
P: 3,149
Quote Quote by xoops
I think you'll need more than that. You'll need at least a pulse monitor and some means to measure oxygen intake and carbon dioxide output.
xoops
xoops is offline
#6
Dec28-05, 11:22 AM
P: 4
Ok, I'll arrange it. Can you please explain how'd I try this experiment?
Many Thanks
xoops
xoops is offline
#7
Dec28-05, 11:29 AM
P: 4
..or atleast an equation to calculate it.
russ_watters
russ_watters is offline
#8
Dec28-05, 11:43 AM
Mentor
P: 22,001
Quote Quote by Manchot
You most certainly do expend energy when braking. Any time your muscles are in use, for any purpose, they require energy - and roughly the same energy regardless of whether expanding or contracting, as long as the force being exerted is the same. There are weightlifting techniques designed to maximize that and most trainers will tell you that the way you lower the weight down (slow, controlled) is more important than the way you raise it up. There are even "weightlifting" techniques where you don't even move! (isometrics)
A few suggestions:
-Use a high enough staircase that it takes at least a minute to go up or down.
-Try to keep the same pace going up and down.
"Up" case:
1. Measure your heart rate
2. Go up the stairs (time yourself)
3. Measure your heart rate
[long pause between the two]
"Down" case:
2. Go down the stairs (time yourself)
If you work or go to school in a place with a good candidate stairwell, you may be able to work this into your day without looking too strange to people around you. Ie, when it's lunch time, measure your heart rate at your desk, then get up and walk down the stairs, stop and measure your heart rate at the bottom. After lunch, if you are walking from somewhere and your heart rate is up a little, sit at the bottom of the stairs (in a lobby or something) until it drops to normal, then walk up the stairs.
Homer Simpson
Homer Simpson is offline
#9
Dec28-05, 12:19 PM
P: 191
force = mass x acceleration
Work = force x distance
Like Russ is saying: If you descend extremely slow and controlled there will be much less difference in the upward force required.
Think of an elevator. The tension in the cable is constant while the elevator is moving in either direction (equal to mass of elevator * g) Only when the elevator begins to accelerate up or down from a stopped position does the tension change.
So you have to apply work to go up the stairs. Its the force to overcome gravity x the distance you do this for. However going downstairs you can cheat the workload. Consider just hopping down stair to stair with locked legs. No work is being done here at the muscle level. Its just the impact force with your feet bottoms that does the ‘braking’
russ_watters
#10
Dec28-05, 03:22 PM
Mentor
P: 22,001
That's true - because of the position of your limbs, a fair amout of the impact is absorbed via the shock of the impact. But I suspect your muscles absorb more than you realize and if you actually try top hop with a locked-knee, you'd hurt yourself.
DocToxyn
DocToxyn is offline
#11
Dec28-05, 09:03 PM
Sci Advisor
DocToxyn's Avatar
P: 432
Quote Quote by russ_watters
While I agree that work is being done regardless of going up or down, I need to clarify that muscles only work in one direction. Muscles are contractile only and thus can only pull, they work in pairs to effect body motion like lifting an arm or walking up or down stairs.
skywolf
skywolf is offline
#12
Dec29-05, 05:00 PM
P: 80
the real question would be which one is easier, going up then down
or going down then up?
i would say that going up then down would be easier because the gravity is less higher up
Register to reply
Related Discussions
Is there an easier way? Calculus & Beyond Homework 4
This one is a bit easier... Introductory Physics Homework 5
the Noisy Upstairs Neighbors Beyond the Standard Model 0
To see there is easier than to be there General Physics 7
