Solving the Bowling Ball Problem: Find Final Speed
  • Thread starter Thread starter zekester
    Ball Bowling
The discussion revolves around a physics problem involving a bowling ball that is thrown horizontally and subsequently slides before rolling without slipping. The problem includes parameters such as initial speed, coefficient of friction, and seeks to determine the final speed of the ball.
  • Mixed
  • Participants explore different methods to analyze the motion of the bowling ball, including the use of angular momentum and frictional forces. Some express uncertainty about the implications of angular momentum conservation and the role of friction.
There are various lines of reasoning being explored, with some participants suggesting the use of conservation principles while others question the assumptions made regarding final speed and angular momentum. A few participants have provided calculations and results, but there is no clear consensus on the approach or outcome.
Some participants note potential gaps in the information provided, questioning whether sufficient data is available to solve the problem effectively. There are also discussions about the implications of the ball transitioning from sliding to rolling without slipping.
zekester
A bowling ball is thrown such that at the instant it touches the floore it is moving horizontally with a speed of 8m/s and is not rotating. it slides for a time and distance before it begins to roll without slipping. The coefficient of friction between the ball and the floor is .06. What is the final speed of the ball?
I know how to find the horizontal acceleration but I don't know where to go from there.
Any hints?
There's an hard way and an easy way.
The easy way is to use conservation of angular momentum.
JMD
Angular momentum is not conserved. (The friction exerts a torque.)
Angular momentum is conserved about a point, you have to find the correct point.
and if your looking for the FINAL speed, it's going to be zero.
JMD
Aren't those two statements contradictory? If the final speed is 0, then the angular momentum is 0 which is not true while it's rolling.
Actually once it gets to pure roling without sliding, the friction is no longer a factor (that's the whole point of the wheel!).
ive got a few formulas here:
alpha = (5 * coeff friction * g)/2R
omega = (5 * coeff friction * g * t)/2R
the 8 m/s is beginning translation motion right? but i can't figure out where to begin. I've gone through a few sheets of paper, and i don't think he gave us enough to start with.
okay, using 8 = R*omega, i was able to find a time. i did 8 = R (5 * coeff friction *g * t)/2r. i ended up with a time of 5.4 seconds. but I am stuck now.
heres what i did:
alpha = (5 * mu * g) 2*R
alpha = a/r, so a/r = (5 * mu * g)/ 2*R. with this i ended up with an a of 1.47.
i than used this 1.47 in omega = initial omega(which is zero because it was not rotating) + alpha * time.
i found time using the formula:
t = 2 * initial velocity/7 * mu * g, which equals 3.89 s.
than i went with v/r = 0 + 1.47 * t/R
the r's cancel and i ended up with a final velocity of 5.7 m/s.
have i done everything correct?
correct.. You can also use conservation of Angular momentum, about the point where the ball makes contact with the floor.
When the ball first starts
[itex]l=mrv_0[/itex]
when the ball starts to roll without sliping
[itex]l=I \omega[/itex]
[itex]I = \frac{2}{5}mr^2 + mr^2[/itex]
for rolling without slipping you can find
[itex]\omega = \frac{v}{r}[/itex]
and you can solve these and find
[itex]v = \frac{5}{7}v_0[/itex]
Which is 5.7 m/s
I might have to edit this to get the LaTex to work.
JMD
They are contradictory. I've been ill with the flu and still not thinking clearly all the time. The final speed won't be zero.
JMD
Excellent. Hadn't thought of that.
  • · Replies 60 ·
