Register to reply
Is friction independent from area of contact?
by shaan_aragorn
Tags: contact, friction, independent
Share this thread:
shaan_aragorn
#1
Jan11-06, 09:25 AM
P: 43
Now, my textbook says that force of friction is independant from the area of contact. But, when the tyres of my bicycle get deflated i have to exert extra force than otherwise. Why?
Phys.Org News Partner Science news on Phys.org
'Smart material' chin strap harvests energy from chewing
King Richard III died painfully on battlefield
Capturing ancient Maya sites from both a rat's and a 'bat's eye view'
Hootenanny
#2
Jan11-06, 09:36 AM
Emeritus
Sci Advisor
PF Gold
Hootenanny's Avatar
P: 9,772
My guess would be that the rubber deforms more when deflated, and therefore more work is done while deforming the tyre. I'm not sure, like I say thats only my opinion.
Gokul43201
#3
Jan11-06, 09:45 AM
Emeritus
Sci Advisor
PF Gold
Gokul43201's Avatar
P: 11,155
The extra force required to cycle with flat tires could be explained independently of area of contact. For one thing, you are doing extra work in pushing a deformation in the rubber around the wheel, with each revolution. It's also not inconceivable that the surface properties of the rubber are different when it is under tension (from the air pressure) from when it isn't (no air pressure).
BobG
#4
Jan11-06, 10:52 AM
Sci Advisor
HW Helper
BobG's Avatar
P: 2,284
You've overlooked a couple things. If the coefficient of friction is held constant, increasing surface area does not increase the force of friction. That's technically true, but in practice:
There are exceptions: Friction and area of contact
The coefficient of friction depends upon surface roughness, molecular adhesion, and deformation effects. A fully inflated tire has greater resistance to deformation than a softer tire. In other words, the coefficient of friction is different for a flat tire than a fully inflated tire.
The hyperphysics explanation about snow bothers me a little. Decreasing your tire pressure also improves your traction in sand, as well.
nazgjunk
#5
Jan11-06, 11:14 AM
P: 83
If you enlarge the area, the weight ofe object is spread over a larger area. Thus, however the area gets bigger, the pressure per square foot/meter/whatever decreases. The total pressure, i.e. the weight remains constant. However, tires need deforming, as said before.
BobG
#6
Jan11-06, 11:43 AM
Sci Advisor
HW Helper
BobG's Avatar
P: 2,284
Just anticipating the next question likely to follow the original one ...
If friction is independent of the area of contact, why do dragsters have wide tires?
This page has two lousy responses, but the third is very good (and very interesting).
Wide tires
In general, tires are a poor example of the principle you're asking about. However, if you understand the idea of static friction, you do realize the reason speeds in the quarter mile have gotten so much better over time has more to do with improvements in tire technology than the ability to build more powerful engines.
(This subject almost makes me homesick for my hometown. Aaah, the smell of burning rubber when they fired up the factory furnaces on Monday mornings. )
Trivia: The study of friction and lubrication is called 'tribology'.
Register to reply
Related Discussions
HELP: contact area of Cylinder inside a larger Cylinder? General Math 6
Collision, friction, contact? General Physics 2
Friction Area? General Physics 2
Independence of friction and area of contact Introductory Physics Homework 3
Time-step independent friction model General Physics 4
