How to Find the Extremal for This Integral?
  • Context: Graduate
  • Thread starter Thread starter jordan23
The discussion revolves around finding the extremal that minimizes the integral \(\int_{0}^{1} \sqrt{y(1+y'^2)} dx\). Participants explore methods for solving the associated differential equation and consider alternative formulations of the integral.
  • One participant expresses difficulty in isolating \(y(x)\) after deriving a relationship that leads to \(y(x)\) being a function of itself.
  • Another participant clarifies the expression for \(F\) and provides a derivative \(dF/dy'\), suggesting a complicated differential equation arises from the minimization process.
  • A subsequent reply reiterates the complexity of the derived equation and notes that \(y\) cannot be combined, leading to the conclusion that \(y\) is a function of \(y\).
  • Another participant challenges the assertion that the inability to solve the equation implies no solution exists, suggesting that multiple solutions might be possible and that initial conditions could help determine a specific solution.
  • One participant proposes a method to transform the equation into a quadratic form to facilitate finding solutions.
  • A later post questions whether extremizing a different integral, \(\int_0^1 y(1+y'^2)dx\), would yield the same results.
Participants express differing views on the solvability of the derived equations and the implications of being unable to isolate \(y\). There is no consensus on the best approach to take or whether the two integrals will yield the same extremal.
The discussion includes unresolved mathematical steps and assumptions about the nature of solutions to the differential equation. The implications of initial conditions on the solutions remain unclear.
jordan23
I am trying to find the extremal that minimizes [tex]\int_{0}^{1} \sqrt{y(1+y'^2)} dx[/tex]
Because it is not explicitly a function of the free variable x, I can use the shortcut:
constant=F-y'*(dF/dy') to solve for y(x)
My problem is that after grinding through the algebra my y(x) is a function of itself, in other words I cannot isolate the variable I want to.
If anybody can offer some tips on either another way to go about this
problem or maybe argue that y(x) can be isolated it would be greatly appreciated.
Thanks in advance for the help!
(In case the formatting doesn't work, everything inside the integral is raised to the 1/2)
I'm not sure what you mean by "my y(x) is a function of itself"
Assuming that by "F" you mean the integrand: F= y1/2(1+y'2)1/2 then I get dF/dy'= y1/2y'(1+y'2)-1/2 so
F- y'dF/dy'= constant becomes
y1/2(1+y'2)1/2-y'2y1/2(1+y'2)-1/2= const.
That's a rather complicated differential equation for y. You might be able to simplify it by multiplying the equation by (1+y'2)-1/2, then squaring both sides.
right, I think that is the same result that I get. Upon the simplification that you mentioned, and then solving the diff eq, I think it turns out to be:
Kx - x*y^-1/2 + C = 2y^1/2 : c,k are constants
and the y's cannont be combined and therefore y is a function of y.
Hopefully I am just missing something here and there is an obvious solution.
Thanks for the quick response.
I don't understand what you mean by "y's cannnot be combined and therefore y is a function of y." The fact that you (or I!) cannot solve an equation doesn't mean that there is no solution.
If there is not a single solution for y as a function of x then there exist more than one solution to the differential equation. You might be able to determine which is correct for this problem when you apply the initial conditions to determine C.
For this particular equation, Kx - x*y^-1/2 + C = 2y^1/2, you might try multiplying throug by y-1/2 to get
(Kx+C)y1/2- xy- 2= 0. Now replace y by z2 so that the equation becomes (Kx+C)z- xz2- 2= 0 which is a quadratic equation. Use the quadratic formula to solve for z and then take the square root to get y.
Point well taken, good idea. I'll let you know if it works out.
Won't you get the same answer if you extremize
[tex] \int_0^1y(1+y'^2)dx[/tex]
instead?
dhris
  • · Replies 20 ·
