Determining Speed at Points A, B, and C
  • Thread starter Thread starter roy5995
    Points Speed
The discussion revolves around determining the speeds of an electron at various points (A, B, and C) as it travels between two parallel plates with a specified electric potential. The subject area includes concepts from electromagnetism and kinematics.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the application of the Work Energy Theorem and question the implications of the electric potential and charge on the electron's motion. There are discussions about whether the velocity remains constant and how the separation distance of the plates affects the electric field.
Participants are actively questioning assumptions about the motion of the electron, including its initial and final velocities, and the effects of the electric field. Some guidance on the Work Energy Theorem has been provided, but multiple interpretations and uncertainties remain regarding the setup and conditions of the problem.
There is a mention of the separation distance of the plates (5.0 cm) and its potential impact on the electric field, as well as the initial conditions of the electron starting from rest. Participants are also considering whether the potential energies at various points can be assumed to be zero.
roy5995
Two parallel plates A and B are separated by 5.0cm. The electric potential between the plates is 200V. An electron starts from rest at time t_A and reaches plate B at time t_B. Then the electron goes through an opening and reches point C at time t_C.
What are the speeds at t_A , t_B and t_C?
A_B__C
If i use the equation
v=sqr root of [2qV]/m
q=1.602*10^-19
V=200V
m=9.1*10^-31
v=8.4*10^6
I can find velocity. but this means that the velocity will remain the same throughout the whole trip.
Will the electric potential or charge change during the whole trip?
Does the 5cm that the plates are separates affect anything?
You are applying the Work Energy Theorem which considers final and initial velocity
Moreover why should e move from + plate to - plate starting from rest all the forces are against the motion
Sorry, you're right, the diagram sould look like this
A_B__C
What is the work energy theorem?
What equations can i use to find the initial and final velocities?
Or should i automatically asume that those velocities are zero?(b/c their potential energies are 0) and that the velocity in the middle (plate B) is 8.4*10^6m/s?
Once the electron passes through the positive plate, would it be attracted back to the plate?
How does the 5.0 cm that the plates are separated affect anything?
Work Energy Theorem States that
[tex]\Delta K = W_{conservative forces}+W_{non conservative forces}[/tex]
[tex]\Delta K = K_f-K_i[/tex]
With the small distance separating them signifies that the electric field lines are concentrated and are almost parallel to it. Which helps in maintaining uniformity.
  • · Replies 25 ·
  • · Replies 18 ·
9K
  • · Replies 26 ·
15K
  • · Replies 43 ·
