Is There a Minimum Time in String Theory?
The discussion centers around the concept of minimum time in string theory, particularly in relation to the Planck time and its implications for the nature of particles and their vibrations. Participants explore theoretical implications and the relationship between string vibrations and time, considering both fundamental and larger particles.
  • Edsel Salvana proposes that there is a minimum time related to string vibrations, suggesting that the time it takes for a string to produce a photon cannot be less than the Planck time.
  • Some participants argue that while the Planck length is a minimum size for strings, it does not necessarily imply that all strings must be of that length, as bosonic strings can be larger.
  • There is a contention regarding whether particles that are larger than the Planck length would have longer minimum times, with some suggesting that they must still adhere to multiples of Planck time.
  • One participant posits that all strings are fundamentally identical, and differences in particle manifestation arise from the varying periods of their vibrations, which may require longer minimum times for certain particles.
Participants express differing views on the implications of string size and minimum time, with no consensus reached on whether all strings must conform to the Planck length or if larger particles can exist with longer minimum times. The discussion remains unresolved regarding the nature of minimum time in relation to string theory.
Participants note that the definitions of string sizes and the implications for time are not universally agreed upon, and there are unresolved assumptions regarding the nature of vibrations and their relationship to time in string theory.
koi
Hi guys, I am new here. Just finished reading Brian Greene's book and I wrote this paper. I have no idea if it makes good sense but it sounded right at the time. I am a medical doctor and I know no physicists to review it. If I'm violating some sort of rule, please tell me. Thanks.
The Minimum Time
By Edsel Salvana, MD
String theory has generated a minimum size in terms of
physical distance. Planck length is the smallest
possible distance and is purported to be the size of a
string. However, there has been no postulated minimum
time. Since time itself is a dimension, the question
arises as to whether there is a minimum amount of time
beyond which the string becomes undefined.
To tackle this problem, we return to the definition of
matter in light of the string theory. In essence,
matter (and energy, for that matter) is merely a
manifestation of the vibrations of a string as
modified by a Calabi-Yau space. Yet a vibrating object
has a period during which it makes a complete
vibration. If the characteristics of matter are
inherent in the vibration pattern, then the period in
which one vibration is manifested determines the
character of that matter and no less.
As an example, we look at light. Light is made up of
photons. A photon is a string with a distinct
vibration pattern. The speed of light is 300,000 km/s.
The time in which light traverses the Planck distance
is the Planck time. Yet a photon can only fit in a
space no smaller than a Planck distance since it
itself is a string. By that virtue, the photon is
actually taking up the whole of the Planck space. It
cannot be halfway in, or halfway out or any proportion
thereof precisely because it cannot otherwise be
defined as a string (it cannot be half a photon) and
there is no smaller space. Furthermore, the
characteristics of the photon cannot be manifested
without a complete vibration. By this reasoning, the
time it takes a string to produce a photon cannot be
less than the Planck time because the vibration would
not be complete. Taken in another way, you cannot have
a complete vibration if you do not have a complete
string.
Using this analogy, if at the time of the Big Bang
(zero time), photons were produced, they would have a
period of Planck time at least. That is why all
photons travel at the speed of light (not faster or
slower). There is no “in between” state because the
vibration necessary to generate a photon would not be
complete. Precisely because of this point, all photons
in the universe should be “in synch” with each other
in multiples of minimum (Planck) time.
Whether other particles are subject to this “minimum
time” is self-evident since all particles are made up
of strings. The question is whether certain particles
have a larger “minimum time” because it takes longer
for the string to generate a complete vibration. I do
not think this has to be the case since the minimum
requirement for one vibration would be one complete
string. Nevertheless, if some particles (especially
those slower than light) have a longer minimum time
(the time it spends generating one complete vibration
in a Planck space), these should be greater than (they
are multiples of, since there is no smaller unit by
definition) Planck time since nothing can travel
faster than light and each vibration requires a
complete string.
An interesting consequence of these arguments is that
matter and energy is being “created” in multiples of
“minimum” (Planck) time. With each vibration, a string
generates the same particle over and over again over
time. When a string’s vibration is changed, then the
type of matter (or energy particle) it manifests is
changed. Whether the time to generate the properties
of the matter or energy particle remains the same
(Planck time or multiples thereof) remains to be seen.
--desperately looking for feedback
You have posted conclusions from your theory in a couple of other threads here. I am not the mentor of this board but in my opinion your theory belongs on the theory development board, not this one. This is no reflection on your theory.
But one consequence of your theory needs a comment. You say that strings are the length of a Planck length, and draw conclusions from that. That is not at all necessarily so. Bosonic strings, while very small, are not assumed to have the length problems you cite, and we can say that they are several orders of magnitude above the Planck length.
minimum size
I agree that bosonic strings can be several magnitudes of Planck length. But the point was that Planck length is minimum length. You cannot have 1.5 times Planck length because it cannot be divided. In the same light, you cannot have less than multiples of Planck time because it cannot be subdivided. The reason I posted this theory here is precisely because one of the previous threads spoke about a theory of time in the string context. If you think this belongs in TD, then I have no problem with that.
Moreover, the statement that bosonic strings are larger than Planck length leads me to the second part of my posting. If larger particles do not fit in one Planck space (but 2 or 3 or 4 etc.) then they will have longer minimum times since they have to be as fast as or slower than light. Nevertheless, they have to be in multiples of Planck time because, again, you cannot occupy only part of a Planck length.
A string is a string is a string
Waittaminnit! I take it back. All (ALL!) strings are identical, meaning a light string is the same as a bosonic string. It's the vibrations that are different as modified by a Calabi-Yau space. Perhaps the reason bosons are several Planck lengths in magnitude is because they require more than one period of Planck time to be manifested as a complete string vibration. It's not that the boson's string is bigger than a light string (by definition all strings are the same, otherwise its not a fundamental unit), its because a boson's vibration period is longer, and therefore its minimum time is as well (but still has to be multiples of Planck time).
  • · Replies 33 ·
10K
  • · Replies 20 ·
  • · Replies 0 ·
