Engine Questions - Get Answers for Your Car Troubles
  • Thread starter Thread starter xyz
    Engine
The discussion revolves around a question related to cyclic engines in thermodynamics, specifically focusing on which variable among work-heat in, change in pressure, heat input (Q_in), change in volume, and change in temperature might not equal zero over one complete cycle.
  • Participants explore the implications of thermodynamic principles on the behavior of various variables in a cyclic process, questioning the conditions under which certain quantities can be zero.
Some participants have offered interpretations of the variables, with one suggesting that Q_in cannot be zero, while others reflect on the implications of the second law of thermodynamics. There is an ongoing exploration of the definitions and relationships between the variables involved.
There appears to be some confusion regarding the definitions of work, heat, and their relationship in the context of a cyclic process, as well as the implications of the second law of thermodynamics on the problem at hand.
xyz
Hi,there...
question?
Consider a cyclic engine.Which one of the following variables might NOT equal zero over one complete cycle? That is,some of these can be zero, but one will not be, over an entire cycle. Which one? Explain.
a) Work-Heat in
b) the amount of change pressure
c) Q_in
d) the amount of change volume
e) the amount of change temperature
Thanks in advance!
a) work-heat in = - variation of internal energy = 0 (cycle)
b) variation of pressure = 0 (cycle)
c) Q_in = ?
d) variation of volume = 0 (cycle)
e) variation of temperature = 0 (cycle)
So, I think that the correct answer is c) Q_in <>0 ...
c) Q_in = ?
For part a, I think that you are confusing the fact that Internal E = W- total Q. Q means the same as heat, and total Q is the sum of Q in and Q out. If Qin was equal to W, that would violate the Kelvin-Planck statement of the 2nd law of TD, which says it is impossible to construct a heat engine that can absorb energy as heat and do an equal amount of work. So a) can never be zero. But W-Q is always zero for cyclic process.
c) can also never be zero. If there is only supposed to be one answer then by Qin they mean Q total, in which case the answer is c).
Well...if you say so...termodynamics is quite strange for me...
I didn't pay too much attention on part a) because I saw c), which was <>0...so...my mistake...sorry...:frown:
  • · Replies 25 ·
